Swiching over to the dark side.
#51
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Swiching over to the dark side.
They contacted me today to let me know the order is sent off to strange and to exspect the rear end in 2 or 3 weeks. Helps that im buying a strange brake kit from them so I dont have to send in any backing plates.
Raced yesterdy. Ran 11.682 11.672, 11.669, 60 foots were. 1.589 1.592 and 1.599. 10 bolts still taking the lashing quite well. Hopefully it stays together so i can sell it in a month and recupe some money. Lost 1st round. .006 red light. Pissssed me off perty bad but it just wasent my day. I ran a 11.672 on a 11.66 dial. The car is so easy to dial in because its consistant. Im just off on the tree still.
Time trials my Rts were, .052 and a .063 Those are not good but i was happy with them considering my Rts since I have done this V8 swap and because i know my car wont run more then 1 hund off its dial in if not dead on. Then I go out and go .006 red. Very flustrating.
Ive been racing for 15 years now and this set up is hard for me to dial in .020-.030 rts constantly. Im getting better but I feel like im a rookie all over again. Racing a turbo V6 car for the last 6 years is so much different then a V8 that pulls the tires off the ground and leaves so fast then seems slow as helll down track... Ive got to figure this puppy out and I think seat time is the only thing that will help at this time.
#52
Someone is going to say it, might as well be me - OLD AGE, things slowing down maybe???
Seriously though - you're doing one hell of a job with your combo. (no smiley for PROUD)
#53
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
That's why us old guys like delay box racing. Start getting slow on your reaction times, add some delay into the box to compensate.
#54
Car: 1991 Camaro RS
Next year I do plan to run sportsman but pro as well. Pro I can have a brake and 2 step. Much harder class but I'm ready for the challenge and I can double enter the car each race so I'll have lots of seat time.
Sometimes I swear I'm getting old, because back in the day id race anything and pull a decent....050 and under light. Didn't matter what it was. 12 flat sportsman car or a ford escape that ran 18s that you had to deep stage and then go when the 3rd amber just came on....
Id love to be at that point where I could use a box. Hopefully in 5 or 10 years or so the car will be at that point. I want to make the engine last one or 2 more years before a major rebuild. Then I can upgrade the motor better so it can be a 9.90-10.50 car or so. Then be a dual pro/super pro worthy car. Just takes time and I have to go though the steps as my budget allows. Thankfully I have a decent suspension set up (the butt end at least) , a 750hp worthy trans and a bulletproof rear end on its way.
#55
Car: 1991 Camaro RS
Well I almost have all my parts rounded up for the fall/winter build.
2-3 weeks wait on the s60 still
I have the driveshaft from strange, the 240/246@.050 dur.. 541/.544 lift cam, Victor jr. Intake tall one, my 8 inch 4800rpm ptc converter and now a set of afr 195 competition ported cnc sbc heads on the way.
A good friend is a vendor for afr, he's been trying to convince me to buy some for a bit now. I possibly have some one who wants my old dart heads so it prompted me to look at new aluminum heads for flow and over all weight savings.
I was amazed that he got 195s on his 383 and picked up 5mph and dropped .4 in at in the 1/4 mile after switching from dart platinum 200cc heads. He runsna 11.50@117mph 383 thirdgen. I guess afr is very good at flow vs cross sectional and volume of the runners. I remember back when 220s were the only thing my friends and I would ever put on a 383. Now 195s can flow 300 cfm even at low lift. Quite amazing. Now if I was reving to 7k i would have upped to the 210s all day. Of if I couldn't have gotten the competition cnc porting I would have done the same.
After deliberation for hrs with a few vendors and close gear heads I settled on the 195s. But these are the competition porting not the street version. So they flow upwards of 300cfm at .500 he also set me up the the correct springs to run with the cam I have.
I got them for 100 bucks more then summit sells the street style heads for so I was very pleased. It should get me to my high 10 second goal and ahead a solid 60lbs. Those old school dart heads I have.. which are stock casting and iirc 15 years old, weight app. 64lbs a piece. Heavy things. The afr 195 are app. 28lbs each.
#56
Car: 1991 Camaro RS
The heads are here and look like works of art. Hopefully they perform like they look. All this new stuff won't be going on the car for at least a month if not this winter.
Still waiting on the s60 first. No sense in adding any more hp without swapping that out first.
#57
Impressive.
#58
Engine: 4++,350 & 305 CIs
"2-3 weeks wait on the s60 still"
You may hear that every 2-3 weeks for awhile. Or you may get lucky
#59
Car: 1991 Camaro RS
Yaa we shall see. It was 4 weeks from mwc then strange emailed me Monday said 2-3 weeks. I was a week ago Monday that i made the initial order.
Long as I get it by next spring I'll be fine.....
#60
Car: 1991 Camaro RS
I just got a phone call with my tracking number the S60 is on its way it took a little under 3 weeks total I'm very excited to get this rear end in a few days I'll make sure update with some pictures
#61
That's great! I know guys that have waited for 6-8 months for things that were "instock" from them.
#63
Car: 1991 Camaro RS
It's a thing of beauty!! I may try to swap this puppy in this weekend since the points races are over for the year I ended up in 15th out of about 45 people I didn't make the cut for Indy by 3 round wins but I feel I did quite well this year for being a new set up.
#66
Nice A$$ (I mean rear-end).
#68
Car: 1991 Camaro RS
Well no updates. Had a few personal and family issues arise. Suxs because I got the call a week ago to represent Milan dragway as a alternate for the division 3 bracket finals in indy!!! I sadly had to turn it down because I just cant swing the time off of work right now. Family comes first no matter what. I've had to travel from where i live in Ohio out to Nebraska 2 times now. That's a long haul for me.
But the fact that I earned that chance is amazing. I racked up 99 points this year. It's the first year I didn't mess with the car really and tired my best to do well. Only missing one race.
I have a feeling next year will be even better.
I plan to race 1 or 2 more times this year for fun when I can.
I still have alot of stuff to do to the car this fall and winter. The s60 is waiting for me, the afr heads, the ptc converter, the Victor jr intake, and xe284 cam as well. Hopefully those things take the car from a 11.60 car to a 10.90 car as I plan to double enter alot more next year and run spt and pro.
Pic of the cool numbers I finally got on the car.
#69
Car: 1991 Camaro RS
The ole 10 bolt is out. took about a hr to remove it and i got the s60 ready to toss in along with the head swap. Figure i may as well do a bit of racing with them before winter.
#70
Car: 1991 Camaro RS
Im also tossing on the afr heads and the victor jr intake i have. As you can see the old darts weighed about 57lbs each and the new afrs 27lbs each. So at the minumum im saving a good 60lbs up front and hopefully adding detination resistance with the aluminum heads. Hope to have it all buttoned up rear end and all monday or tuesday afternoon so i can race it next weekend.
I just need head gaskets still. .027 to be exact as the piston is .013 below the deck so I want to aim for the perfect .040 quench if i can. May as well get mls gaskets so i dont have to worrie about getting new ones evertime.
#71
Car: 1991 Camaro RS
Well the s60 is almost in. Just need to attach the tq arm. The drag bar. Then hook up the brake lines and bleed them. So far this rear end was a cake walk to install. The driveshaft I got from strange was a easy fit.
Going to finish it up after work and also finish up the head swap.
I have the drag version so it's not nearly as heavy as I thought it would be. About 30lbs more then the 10 bolt I took out. Helps I have a race spool and axles.
#72
Strange Engineering Make some NICE stuff !! they are about 45 minutes from my home they have great quality, fast service , offer Big discounts for current military & Veterans I have slammed insane 4700 RPM Nitrous Clutch Dumps at my Strange 12 bolt launches like a champ every time
#73
Car: 1991 Camaro RS
I just need to lash in the valves, set the timing and toss a carb back on and the heads and intake are good to go.
#74
Car: 1991 Camaro RS
It tis alive again.
I still have to finish the rear end up and beat the crap outta the inner fenders as before i had about 1/2 inch of clearance back there and now i have about 1/8 a inch so i need to massage it a bit to fit the 10 inch tires in there but its coming along well.
The new intake and heads definitely look nice IMO
#75
That #1 plug wire looks out of place. But it won't burn on the headers.
#76
Car: 1991 Camaro RS
#77
Car: 88 Firebird GTA
Engine: 385
Transmission: manual 350 Turbo
Axle/Gears: 4.30 9 inch
Edlebrock says a 2 inch carb spacer will optimize the setup on that intake. If you have room, might give that a try. It did help on my similar setup.
#78
Car: 1991 Camaro RS
2 more inches holy crap. Lol well this is the victor that has the 1 inch taller the the normal victor jr. So I think I will try this for a bit. You can clearly see the spacer added to the casting here. Most all victor jrs are not this tall. It's a more expensive one as well.
but thanks for the tip. I will probly be running a adjustable ez plate or something close, next spring which is one more inch higher. I can manage about 2 more inches in there tops then the carb will betoo close for comfort to the 4 inch cowl. Right now the 4 inch filter fits in the cowl like a glove.
#79
Engine: 385
Yep. Mine is not a Super Victor. Just the Victor Jr. Good luck with your upgrades.
#80
Car: 1991 Camaro RS
#81
Car: 1991 Camaro RS
S60 in and everything is adjusted right. Can feel a major difference with the 4.10 gears over the 3.23s that were in the 10 bolt. Have to work tommorow so no racing but hopefully next Sunday if I don't work we are racing.
#82
That is beautiful.. I hope it works as good as it looks.
#83
Car: 1991 Camaro RS
Thanks. I know setting up the angles of everything was time consuming. Took me a good hr or so to set the drag bar, pinion angle, and the lca position.
This rear has disk brakes so I added a proportion valve and once I got it dialed in, i have much better control over the brakes. Stopping from 115mph week after week is tiring with the stock stuff. I still have to swap the front stocker set up to the areospace kit I have which should really help alot!
#84
Car: 1991 Camaro RS
Well im glad i spent all the money i did on the rear end, heads, also I have a xr286r roller cam going in as well, retrofit kit. Because my wife and I are officially expecting out first little fasteddi or eddiette...lol We are very excited. We are both closing in on our mid 30s and the time is now or never. Its a awesome thing.
But thankfully i built on one bad street 385 this year. I plan to finish up the roller conversion this winter as I already have all the parts. Just havent taken it out of service yet, hoping for one nice sunday to race and try the new heads, intake, and rear end out.
#85
you've definitely put together a solid combo man, and it's good you spent the money on the big ticket items now. i can tell ya from first hand that having babies is awesome, but it definitely takes it's toll on the budget and garage time. you have to work twice as hard to be able to spend half the time tinkering.
congrats man!
congrats man!
#86
Car: 1991 Camaro RS
congrats man!
congrats man!
it's a blessing to have a little one on the way. Jr dragster time! Haha. I'm looking forward to this more the I could have imagined.
#87
Engine: 385
A suggestion for the younger amoungst us. Kids grow up faster than your hot rods. When my youngest was a year old, I made a contribution to a college fund. When he was 2, I made a second contribution. I was able to lock in a 9.5% treasury rate. I never made another contribution. 15 years later, there was enough there to pay for college at a state college. Nope, not Harvard but good enough. I am following the same path with my grand-daughter using a different type of account. It's up 35% since we started. Doesn't take much to start. Compounding money is a bigger power adder than a turbo.
#88
Car: 1991 Camaro RS
I winterized the camaro yesterday. Doing my solid roller cam swap soon. Gotta finish up putting on all the parts I already bought before the baby comes as I know he or she will take up alot of our spare time, which is a awsome thing. We are 9 weeks along so we have lots of time for planning exc.
So here it sits but it's always fun to go out and admire it..lol
#89
Congrats on the new addition!
You may think you have time b4 the baby comes buuuuuut it goes fast and then its faster after they are born.
#90
Car: 1991 Camaro RS
Here is my year in review for 2017. A much better season then last year when I never even made it to a race because of my moms battle with stage 4 nscl lung cancer. This year was a ton of fun and i won more rounds this year then ever before.
#92
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
Good way to wrap up the year! Good video.
#93
Car: 1991 Camaro RS
Starting the cam swap today after work. Hope to have that done soon before I have no free time anymore.. I really think the mechanical roller will be a night and day different over the hydro flat t xe268
#94
Car: 1991 Camaro RS
I haven't updated in a bit so I thought I may as well.
Car is running great and about ready to go race in 2 weeks if the weather cooperates.
So here is where all the modifications from the end of last season went.
The victor jr 2999(1 inch taller then norm), the afr 195 race ready heads(300 cfm), a 2 piece billet timing cover, mls. 027 gaskets to bring quench to .039. Compression fell to 11:1 with 65cc heads, comp xr288hr (236/242 dur@.050 110lsa) roller cam, roller conversion, the 4.10s s60 race rear end package, manual steering box, ptc 4800 8 inch custom converter. All those things went in quite easy. I have a good tune to at least get it down the track, then I can dial it in better. >
I've driven it around a bit here and there. Pretty friendly on the street and fun to drive. Pulls about 13 inches of vac at hit idle 11 inches in drive. Smooth on a gauge with a liquid fill.
Not expecting a terribly fast number come race time but 11.20-11.30 or so would be nice considering my times last year with much less heads, cam, gear, exc. Best of a 11.62@115mph (xe268 cam flat t hydra) performer intake, 3.23 gear, very old as cast iron dart heads.
Car weighs in at 3360 race weight.
#95
Car: 1991 Camaro RS
Car blew away my expectations. 10.73@125mph was the best. 1.47 60 foot was the best of the day.
2nd time trial 10.73@125 red rt.
10.80@124mph .029 rt lost first round. Goofed up dial in 10.80 on a 10.71. Opps that wont happen again
#96
Car: 1991 Camaro RS
Out of car 10.73@125mph
#97
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Fantastic! Be sure to drop a note in the 1/4 mile thread.
#98
Car: 1991 Camaro RS
Not a car but a update on my new baby girl. Future jr dragster champ here lol.
#99
Car: 1984 Z28
Engine: 454
Transmission: Th400
Nice car and you are doing good job driving it. Seems like you still may be spending a little too much time on going quicker, instead of staying consistent. As long as you are having a good time!
#100
Car: 1991 Camaro RS
Being that I'm in the 10s and I cant slow it down easily to 11.50 or slower I'm now in the Pro class so it's much harder to do well. And with the baby its tougher to make it to every points race so right now I go every few weeks, but we are going this Sunday. We have a motorhome so that helps. I've only made 6 passes now with this set up and its consistent for the most part. I dont plan to mess with it this year. Just keep racing and hopefully some round wins fall in line lol
