26 tall vs 28 tall in the 1/4
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
I have a 92 Camaro LS with 4.11 gears a manual th400 with moser 9. It ran 11.598 at 121.58 with 275/40/17 radials due to not letting me run slicks. I want to add my other setup of 28x10x17 Hoosiers but would like to see if you guys have done this and know the difference. My 60ft had some traction issue but not much. But wondering Mayhem here to test isn’t open for another month.
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Re: 26 tall vs 28 tall in the 1/4
Here is time slips Current tire is Drag Radials 275/40/17 thinking of putting my slicks Hoosiers 28x10x17
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I always suggest to stuff the tallest tire possible inside the fenders then adjust the gear ratio to compensate for the gear ratio to provide best 1/4 mile performance.
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Issue is I spent the money for 4.10 gears on my Moser 9 rear. I had 28x10x17 drag slicks but one needed repair and used Radials during my Personal Best. Im just wondering if using Slick would give me a fast 1/4 and slow Trap speed or vice versa. But 28 is probably the tallest that fit good.
Car: 87 IROC L98
The advantage of a slick is traction off the line. Little to no tire spin off the line means quicker 60' times which means quicker ET. The softer rubber compound will grip the pavement better than a radial even with poor track conditions. The downside is slicks will also wear out a lot faster. Drag radials are nice as they have less rolling resistance than a full slick but still have a soft rubber compound and will wear out just as quickly. Even faster if driven on the street.
Buying someones old slicks may seem like a deal but old slicks usually means the oils in the rubber that make the tire sticky when heated up have dried out. You may still have a lot of rubber but if they can't be heated up, they won't get as sticky.
Street tires and radials are designed not to heat up so trying to heat them up in the water box just wears the rubber off and makes them slippery.
Using a 28" tall tire instead of a 26" tall tire is like doing a gear swap. I'm not doing the math but you had 4.10 gears with 26" tall tires. Putting on the 28" tall tires make the car feel like it has 3.73 gears (not accurate but only for example). That means the torque multiplication to the taller tire is decreased making the taller tire less likely to spin off the line. You have a faster ET because you didn't overpower and spin the wheels as much.
How much gear and what size tire depends on your rpm range and what the rpm of the engine is as you cross the finish line. If everything is set up to give the best performance, you should cross the finish line just as the shift light comes on or slightly after the light comes on.
I've played with different gear ratios to get the best performance. With a 32" tall tire, 4.86 gears and shifting around 7400 rpm. I cross the finish line just after the shift light comes on. The engine is capable of shifting at a higher rpm but that would mean going to something like a 5.00 gear. I tried some 4.57 gears one weekend but the converter stall didn't like the gears and I run much slower. Put the 4.86 back in the the car picked right up again.
There's no exact formula to say what works since all vehicles are different. You run what you have and live with it or you experiment with different parts to get better performance.
Orr89RocZ
12-09-2014 08:14 AM
bad camaro RS
Aftermarket Product Review
12-19-2000 08:08 AM
Fastbird
10-03-2000 06:12 PM
