Vortech belt help needed
Car: 88 IROC
Transmission: pg
Axle/Gears: 9" w/3.89
Ok everytime I go to put the sc belt back on it such a pain in the ***!! I have the standard 6 rib set up and I have put a smaller pulley on (2.95) and I'm using a 59.2in. long belt. My question is how do you guys go about putting your belts back on? I have had the belt on before. It just always take's 2 people to get it on. Please tell me there is a easier way. Thanks in advance
Car: 84z28
Engine: chevy 388
i allways buy a belt a little bigger and dont have any probs putting it on.
you can see my simple site at:
http://darcom.org
http://darcom.org
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
1/2 inch drive breaker bar, and an 18MM wrench
Loosen the idler pully bolt for easier access to the tensioner bolt.
Put the belt on,. and pry back on the breaker.. Tighten the tensioner with an 18MM wrench, tighten the top pivot, then tighten the idler pully.
-- Joe
-- Joe
1992 Trans Am
May 10, 2023 07:19 PM
