Is this cam ok
Old Sep 10, 2004 | 08:35 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Is this cam ok
I plan on boosting for my final mod, but first I would like to play around with the engine.
I have ported/siamesed plenum, runners and manifold. I am going to be getting AFR 180cc heads and comp cams XR269HR cam. Is this cam going to work with boost? I plan on about 5-9 lbs.
The cam specs are:
Duration At 0.05 218 224
Lobe Lift 0.33 0.335
Lobe Separation 112
Old Sep 10, 2004 | 08:38 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Supercharging or turbocharging? They require different cams.
Old Sep 10, 2004 | 09:08 AM
Sorry. Turbocharging.
I haven't full decided if it will be turbocharged. I just want boost.
If I am going to boost the car, what would be better for my climate? I live in Dallas where the heat gets to 100+ for the summer, and usually gets to an average of mid 30s - low 40s. We are about 600ft abouve see level, so the oxygen is pretty dense.
Old Sep 10, 2004 | 04:26 PM
ttt
Old Sep 10, 2004 | 04:39 PM
83 Crossfire TA's Avatar
The cam is a great middle of the road cam. Not exactly optimum for anything in particular, but will work in mild NA and boosted apps better then most.
What’s better for your climate depends more on your packaging then anything else.
Old Sep 13, 2004 | 04:52 PM
Don't want to sound stupid, but what do you mean packaging? Are you talking jet hot coating?
Old Sep 13, 2004 | 06:35 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
I HAVE THE COMP 305 CAM SPEC ARE 510/510 LIFT 220/230 DUR WITH A 114 LOBE SEP.
Old Sep 14, 2004 | 11:34 AM
How much are you boosting?
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
