A quick RAM - AIR question.
Car: 2003 SVT Mustang Cobra
Engine: 4.6L DOHC Supercharged
Axle/Gears: 3.55
I had a strange idea. I was thinking about knocking out my fog lights on my '87 T/A and using the holes as RAM AIR. Would this work? One foglight is already busted so I might as well get rid of the other. Could I just route a hose into the air filter box?
It's all fun and games 'till someone looses an eye....then it's fun yu can't see!!
1987 Pontiac Trans Am
-305 cid motor (soon to be gone)
-Flowmaster Muffler
-Yokohama Tires
-3" Exhaust Tips
-180 degree Thermostat
-JVC Head Unit w/ Kicker subs!
-Flowmaster Muffler
-Yokohama Tires
-3" Exhaust Tips
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
thats what I did!
I used some alum heater vent ducting and fabbed up a box and funnel type thing that mounts flush against the pass. side fog light molding. then routed 4 inch flexible aluminum dryer tubing from the back of this funnel up through the fender hole next to the charcoal evap canister. then I had to twist the airbox around so the intake tube was facing the fender hole BEHIND the evap canister which is now unbolted from its mounts to allow the 4 inch hose to mate with the air box tube.
lastly just plugged up the drain hole in the airbox and made everything air tight.
I plan to have comprehensive pics of this on my website and maybe send them to this site for their tech since i couldent find instructions for a ram air that used the T/A foglight molding.
email me if you have quest.
see-- no pass side fog light.
<img src=http://www.geocities.com/transam617/spread2.JPG>
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax exh, urethane motor+trans mounts,
SSM frame con, Bilsteins
very trick homemade ramair, Accel 300+ ignition system.
Axle/Gears: 3.55
MY GOD, YOUR CAR IS BEAUTIFUL!!
It's all fun and games 'till someone looses an eye....then it's fun you can't see!!
-305 cid motor
-700-R4 Transmission
-K&N Air Filter
-Flowmaster 40 series
Muffler
-Yokohama Tires
-GTA Rims
-3" Exhaust Tips
-2.73 Posi Rear End
-And a COOL LOOKING Flowmaster sticker on the dash!
WOO-HOO!!
*Long live the F-Body!*
-305 cid motor
-K&N Air Filter
Muffler
-Yokohama Tires
-GTA Rims
-3" Exhaust Tips
-2.73 Posi Rear End
WOO-HOO!!
L98GTA87
Aug 11, 2015 06:55 PM
