eaton M90 supercharger
Car: 87 Iroc
Axle/Gears: stock posi
hey guys, will a chevy eaton M90 supercharger work on my 5.0 liter?
Car: 1985 IrocZ
Engine: Carbed 383
Transmission: Tremec T-56
Check out this thread https://www.thirdgen.org/forums/part...ged-305-a.html
Car: 92 Camaro Z28
You would be better off with a M112, off of a Lightning..... They can be had pretty cheap. check out the lightning boards. I remember a P&P M112 selling for $300.
Ray
2000 Pontiac GTP 12.89 @ 111 mph
2002 Ford Lightning 13.40 @ 102 mph
1992 Z28 Turbo No times Yet
Ray
Car: 92 Camaro Z28
There is a member that used a Lt1 intake to do it... Email " rooster433 " He has a sick M112 setup on a 3rd gen.
Here is a pic of his setup...
Ray
Ray
Car: 1985 IrocZ
Engine: Carbed 383
"You would be better off with a M112, off of a Lightning..... They can be had pretty cheap. check out the lightning boards. I remember a P&P M112 selling for $300."
For a 305 you would be better off with a m90. The m90 is much easier to mount than the m112. The way the m112 is designed it would be very difficult to mount, not saying it cant be done because but youd have a hard time fitting it under the hood. You can put out anywhere from 3-10 psi with the m90 and if the 305 is stock, that is more than enough.
Car: 92 Camaro Z28
If you are staying with a stock 305 then Yes "1badrocZ" is correct, the M90 would be a better bet. If you go the M90 route.... get the Gen V M90. Get with " Ed Morad / GTPED@msn.com " he sells very low milage Gen III M90's and Gen V M90's, pretty cheap!
Ray
Ray
The other side of the issue is “do you really need it?”
This setup has run high 10’s @120mph in a 4 door ford LTD on a 26x9” slick and a worn 302 that makes it’s own smoke screen out the PVC breathers… with light modifications you can get an M90 to move quite a bit of air… I’m considering putting that M90 on the 350 in my truck…
Car: 1985 IrocZ
Engine: Carbed 383
"Why??? They’re basically the same design, one just has a longer main case, the rest of the dimentions are the same."
I always thought the m112 would be hard to mount since the air exits the SC from the bottom, but i guess it could be flipped up side down. It would probably take a bit more work than a m90 but yes it would be very unique. I know i had the hardest time getting that m90 to fit under the hood.
Crud… I forgot to add the picture to my last post that I was talking about, added/edited now…
No, they’re not. They all have inlets and outlets on the same side of the case, inlet on the back, outlet on the side (top, bottom… whatever depending on what direction it’s mounted in). There are slight differences in configurations, especially the inlet on the M112’s but those are just additions to the casting to reposition the inlet flange, you could in theory but whatever is added off and you’d have an inlet on the back of the case to one side of the bearing bosses.
1badirocz... thats a mean setup you built! props to you! however, i am looking to build a roots style setup for show and go and dont want it hangin off like that... recently i have been thinking about just going ahead and buying the magnacharger gen 1E but im still trying to find all options
www.MagnusonProducts.com - Magna Charger Announces Gen 1E Supercharger System for Small Block Chevy Engines with Vortec Style Heads
Re: eaton M90 supercharger
i have a 92 pontiac trans am with a 305 5.0L and edlebrock intake manifold, i was wondering what manifold would be required to mount an eaton M90 Supercharger to it. and what modifications would be required to use stock serpintin belt pullys. any advice would help!!!
You're likely looking at side mounting it rather than engine mounting it without a custom intake. Go to www.toohighpsi.com he did a twin M90 T-bird that will give you an idea of what I'm talking about.
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
None exist, break out you8r welder and fab tools. If you have neither, then skip the M90 or any other OEM supercharger
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
You may want to listen to all the noise they make before install one. If you like loud things then this is the SC for you.
UltRoadWarrior9
04-28-2020 10:39 PM
toronto formula
11-10-2015 06:17 AM
dbrochard
10-03-2015 12:43 PM
UltRoadWarrior9
09-02-2015 08:24 PM
