Air/Fuel Ratio on Procharged engine
Hi! I got a 383 procharged engine, have just fired it up
Air fuel ratio is around 14.7-14.9/1 is this to lean? I run a Q-ban 750 blow thrugh carb. msd boost retard ignition.. intercooled P-1SC
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: Air/Fuel Ratio on Procharged engine
For just crusing around that is good, for wide open throttle that will kill your engine. Shoot for 10-11.9/1 for wide open throttle.
Yep, idle/cruise 14 or so is fine. Under 6 psi I like to act like a n/a motor 12.5-12.8 or so air fuel. 6-10, 11.8-12.5 or so. Above 10psi, I'm running 11.5 or richer just to be safe. 15-18 psi right now i'm rich at around 10.5-10.7 or so on pump gas no problems. I want to shoot for 11.5 if it will take it. 11 to 1 wouldnt be bad tho.
Car: Used to drive a camaro
Good note to mention and it's really adressing the OP's question. A WB02 reading is only as good as the sensor. I've started reading some on optimum placement along the flow path. There's a temperature envelope that we have to be aware of, being on the wrong side of that leads to false readings and failure.
thanks!! My Carb card says:
Primary Main Jet:76
Secondary jet:86
Pri Idle Air Bleed:70
Hi Speed Bleed:31
Pri Nozzle:33
Sec Nozzle:33
Needle / seat:130
Power Valve:4.5
Yesterday i changed The primary jet from 76 to 78, and Secondary Jet from 86-->90.. A/f ratio has gone down From 14.9 to 14.8...NOt really much.. I Clarely have to Swich out something else, Even bigger Jets?
Primary Main Jet:76
Secondary jet:86
Hi Speed Bleed:31
Pri Nozzle:33
Sec Nozzle:33
Needle / seat:130
Power Valve:4.5
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
For those of you that are fuel injected. What kind of fuel system are you running? Would the Racetronix Walbro (for GN) pump I'm running be enough to fuel my 383 with a P1SC at ~12psi?
If its a decent cammed/heads 383, it may be approaching 600whp on 12 psi. That usually requires 2 pumps.
An option to try is to get a boost-a-pump kit which just runs hot voltage to the pump to get higher output. It may wear out the pump faster in the end but may support 550-600whp.
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
My buddy is running a 355 w/ an F1 @ 15lbs, has a single walbro w/ a KB Boost a pump, not running out of fuel.
Any advice on the best way to set up a dual pump system. I guess I'll go ahead and start looking for a double pumper hanger for my tank.
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i run an internal 255 and the supplied procharger pump external, i have no fuel issues, 42lb injectors 14psi boost, i dynoed 380/420 to the wheels
Is the boost-a-pump the same as a hot wire kit (I have one of these already)?
http://www.kennebell.net/accessories...boostapump.htm
Dual pump system you can run just like how NoboostNoGo has done in his build thread. I had Lonnies Performance make my kit for my 4th gen tank. turned out nice but it wasnt that cheap.
You can run the second pump with a hobbs switch which will activate upon a certain boost pressure. I'd get one with about 5-6 psi activation. Other way is to run the pump with a WOT switch so both are on no matter what boost your at. Or you can do it with a window switch to come on at a certain rpm, but out of these 3 ways I like the hobbs switch.
Some have wired them so that both pumps are on the same time but I dont like that since you dont need the pumps running constantly. This will heat up the fuel alot more and wear out the pumps faster.
Yea noboostnogo setup is pretty awesome!
Jay_Rich's setup is great also!
Great pics and info on both of there threads.
Car: 1986 IROC-Z28
Engine: 5.7L L98
Transmission: 700R4 OD
Axle/Gears: B&W 3.27 Posi- :D
Oh man! Orr89RocZ i just went throught your build thread that is very good looking for custom done and i notice your in houston too. im N/W ( unfortunately where everyone thinks a cold air makes a honda go 200 mph lol) i hope i see this thing around sometime!!!
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I've done 2 setups with dual pumps in 3'gen tank.
picture of first one
https://www.thirdgen.org/forums/powe...ps-inside.html
http://medlem.spray.se/gta324/mods/misc/pics/dual.jpg
second one, ( when I needed bigger lines)
http://s373.photobucket.com/albums/o...Fuel%20System/
I activate my 2'pump @ 2psi or by a switch......
