Single plane conversion, with Procharger install
#51
Re: Supercharging the 383 FIRST TPI
Orr.
Didnt mean to say that it was different in theory, but in actual tuning, i did find getting the timing curve with the peaky power band of the First difficult ( for me at least) , but that could have been more of an issue with my intake/cam combo than anything else, something about it just wasnt right. So far with the time spent tuning this single plane combo, i find the linear power band a little more forgiving. Time will tell.
I really wish i had installed the supercharher with the First as acomparison because i tgink it woukd be one of the few boosted ones out there, but i know i would have had major issues with detonating, and i wasnt in the mood to fight that battle, combo was just wrong for boosting. Would have been fun, except there would have also been major traction issues, lol
#53
Car: 1987 T/A
Engine: 383 W/ FIRST Tpi
Axle/Gears: GM 10 bolt 3.73 auburn posi
Hey,
All done, finally!
I pretty much just got it done this past weekend, it was a long , slow build due to the typical issues , and of course this thing called running a business..
Anyways, to summarize the build, her are some more details.
I did decide to switch out the FIRST intake. Yes I know the FIRST lovers are crying right now, especially considering this started off as a FIRST build and SC project, unfortunately, I had enough of the intake, and its tb, I just felt like it was time for a drastic change since I was tearing into the engine.
I ended up going with the Edelbrock set up. Here were my changes:
-Victor junior E
-3848 edelbrock elbow
-3869 edelbrock LS2 Throttle body
-224/230 114ls cam
-62lbs injectors
-compression drop to 9:1
-D1SC/ intercooler
-self rebuilt/upgrade t56....
I ended up going with a thicker head gasket that allowed me to drop my comp down to 9:1. Yes, i removed my quench zone completely, actually, i killed it, which seems to make a big difference in battling detonation issues and quench zones being borderline or just out of the optimal zone, by running a huge gap, it looks like i am safe .....so far. I did run the engine for 2-3 weeks naturally aspirated just to work out the bugs and get things in line before boosting, I went up to 34 degrees timing with zero knocks, and today for the first time ran 6-7 psi of boost with zero detonation, things seems to be going good , so far, so good! I ran into wideband issues, so stopped the tuning early today which sucked bad with cool, clean air........tomorrow.
Regarding the intake swap. The verdict is still out on the single plane over the FIRST. Like I said, running NA for the last couple weeks skews the results, but as it is right now, i do definitely miss the low and mid range pull of the FIRST, it was an absolute blast to drive on the streets, but the lack of rpm was starting to bore me .
Running the single plane with no comp isnt a fair trial, but as i added the boost into the engine today, i feel like this set up is really starting to work, nothing like the sound and feel of a screaming sbc under boost!
Onto the fitment issues. I ended up with a 1" spacer under the elbow to give me a spot to port some vacuum lines into , as well as to clear the fuel rail. This intake/elbow combo is definitely not Firebird/trans am friendly, I maxed out the under hood clearance, and i mean maxed out, to the point that i am considering a cowl style hood if i keep this combo around for long, I really want to turn the elbow around, but there is no way with the factory hood, idk what to do, will see after this season, might be time for a miniram......
I look forward to continuing to improve this combo, but i will admit it was a lot of work (as are most), but it is finally starting to come along nicely. My efforts were multiplied by tranny issues and clutch problems when i reinstalled my newly rebuilt by CENTERFORCE DFX, which has been a royal PITA since day one, after 3 "in and outs" im done with it and just reinstalled my df centerforce which has been flawless. I do have a Mcleod twin disk/ aluminum flywheel combo to drop in if i burn this clutch up this summer, if not, i will do it over the winter, i just want to drive the car for now.
Look forward to dialing this combo in, going to be fun!
My one issue coming up soon might be fuel delivery issues, i am only running the Walbro 255lph. I will have to wait and see how it goes while i dial it in some, i think im ok for 6-8 lbs, might be an issue for 10-12lbs.
Here is a pic of my tight engine bay.. Plumbing is still half fast, but i will clean it up as i go along , i want to weld most of it together once i know it works.
All done, finally!
-Victor junior E
-224/230 114ls cam
-62lbs injectors
-D1SC/ intercooler
#54
1 Post
Car: 1987 Trans am GTA
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Wow this seems like a cool project! I know this is a bit late, but how did this work out for you? Too bad you did not keep the FIRST on and try it with the boost! I have 2 383 CI upcoming projects with supercharged FIRST intakes. I would have like to see how they matched up to your build. I took some time and read through your original build post that you gave the link to and WOW it seemed like you sure did have your struggles getting the numbers you wanted out of the FIRST!? I am not sure what to make of that? I am not sure why that fell short for you on the dyno? Seems like the ET'S were where you wanted in the end if I was reading it correctly? It just fell short on the dyno numbers? But drive ability was OK? I am not sure what the deal was with the throttle body? You stated you spoke to me multiple times, I am really surprised that did not come up in conversation, because I would have had you send it in for inspection for sure! The last thing I would want is you using it if it was not functioning properly! We have a "LIFETIME" guarantee, so we own it if there is an issue. I feel as though we have let you down, for that I do apologize! I would also like to offer you a refund on your purchase of some sort, even if it has been over 6 years and you modified it. That is if you have not sold it already to someone else? If you did PLEASE have them contact me so we can sort through the TB for them, FREE of charge again "LIFETIME" even if not the original purchaser! I feel that you put forth the effort to make it work for sure and in the end if you were not 100% satisfied with the way it performed and being that you basically laid everything out throughout your build, I think we can make an exception to the rule here for you! I know this post has already been over a year gone by, so I am REALLY late to the seen, but I wanted to throw this out there for you anyway, just in case you still have the FIRST Tpi around! Not to mention I do not know how I would get a hold of you any other way at this point? Just let me know and I will take care of it for you some way some how. I am glad you found a combo that will work better for you and I sure hope you have been having many miles of fun with it!
Thanks for reaching out, you were always there to help and take care of your clients, appreciate that very much. All in all , aside from a few little issues with the TB, I had no complaints with the intake, it was a lot of fun. I didn't get the hp or torque numbers I was expecting, but the E.t's were close. I really wanted to try boosting the First, but I had too many worries with my combo at the time. I think the fellow that bought it from me is planning on boosting his combo with the First. I will let you know! You can p.m me anytime for my email if you want.
#55
Car: 1987 T/A
HI Ken,
#56
1 Post
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
Well... after a long and busy summer, i finally made the time to fix the belt issue on the procharger. Once i got the alignment issue corrected with some shimming and adding a brace from the header flange back to the bottom of the plate, which helped to stiffen the plate assembly very well, i can keep the belt on, and in one piece to finally make a little bit of boost!
I was able to make it out to the track and make some
runs, everything worked very well and i was able to make 7-8 lbs of boost on my 4.00" pulley.
Anyway, managed to pull a 12.05@ 124 with 2.1 60's....
i had to launch softly and conservatively since i just finished putting a new ring set in the rear after killing the last one, i didnt want to break it again. I think with some more timing and some harder launches, I should be able to manage 11's soon. Im happy.
next step is a move down to a 3.75 pulley , and see if i could squeeze a couple more lbs into her...i do think my fuel system is getting close to being maxed. I have the walbro 255lph unit and i believe they are starting to get tested in the 500-550 rwhp range, and ii think i might getting to the level , especially with some added boost. Will see soon
#58
Nice! Thats making power! I would change to a 400 lph pump. You have got to be very close to macing that 255 out. Keep in mind the blower requires alot of power to turn. Those trap speeds show close to 480-500 whp depending on car weight.
#59
1 Post
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
I know i should be around 500whp, getting worried about the pump....I do want to move down to the 3.75' pulley, and im certain i will starve the engine of fuel. What is a good 400lph pump that is an easy swap?
edit* i got it ORR, is see the walbro 400-450lph. thx
#60
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
http://www.dragzine.com/news/lose-po...-loss-testing/
Good read
-- Joe
#61
1 Post
Engine: D1sc 383
Transmission: t56
Axle/Gears: 4.11
trying to change the original thread title and cant figure it, anyone know how?
#62
I think after a specific period of time it doesn't allow you to anymore, for whatever reason...
- Rob
