5.3 what turbo?
Old 01-09-2019, 11:24 AM
Car: 1988 camaro
Engine: 5.7 Tpi
Transmission: Manual
Axle/Gears: 3.42?
5.3 what turbo?
Trying to get advice on what turbo to run for a single set up. I found this one for a good deal, looking for around 600hp.
Here's the specs
Compressor Inlet: 4.00"
Compressor Outlet: 2.50"
Compressor Cover: Anti Surged 70 Series Cover
Compressor Wheel Diameter: 65mm / 91mm
Turbine Wheel Diameter: 62mm / 70mm
Exhaust Trim: .84 AR
Turbine Flange Type: T4 Divided Flange
Twin Scroll Design for Faster Spooling
LastThirdgen is offline
Old 01-09-2019, 01:11 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: Twin Turbo 401
Transmission: TH400
Axle/Gears: 4th gen 12 bolt 3.42
Re: 5.3 what turbo?
600 at the tire? Thru what trans?
or 600 flywheel?
might squeeze 600 flywheel out of that single 65mm. Turbine is touch smaller than i’d like. Will spool fast. Would prefer a larger a/r
600 at the tire i would go bit larger esp on turbine side. I like s366 borg stuff, or the turbonetics hurricanes- 7268 is fantastic
a single on3 t70 or t76 on a budget works decent. Could see 500’s whp. Their 7875 is much better fit and will do over 600 whp
Orr89RocZ is offline
Old 01-09-2019, 08:18 PM
Car: 1988 camaro
Engine: 5.7 Tpi
Axle/Gears: 3.42?
Re: 5.3 what turbo?
Car: 1988 camaro
Engine: 5.7 Tpi
Axle/Gears: 3.42?
Re: 5.3 what turbo?
or 600 flywheel?
Thanks for the info!
Hopefully through a t-56 when I get my hands on one. I honestly just threw out that number as a max. Just want a reliable 5.3 that I can beat on for awhile and I figure these engines are good for much more bone stock
Old 01-10-2019, 07:05 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: 5.3 what turbo?
Had several friends push them well over 600 and closer to 800. They will hold if you tune right
Old 01-10-2019, 02:03 PM
Kingtal0n's Avatar
Car: 240sx
Engine: whatever works
Transmission: 4l80e this year
Axle/Gears: 3.512
Re: 5.3 what turbo?
I choose S364 Borg Warner for a 5.3L in a street/strip (mostly street)
Works well in a stock 5.3 w/ cam upgrade. Runs right through the center and off the right side like a factory turbo would.
So basically it spools like a stock turbo would on a stock engine, which is what you want in a daily driver. Works well even when 'warming up'. Doesn't require pre-heating, nitrous, or a two step to make boost, etc...
Also 840~ (brake) horsepower capable, which is more than most OEM bottom end 5.3 engines will support anyways.
heres a video and data log of the turbo at 3-7psi of boost on a stock 5.3L (no camshaft yet) just test and tuning it with (silent, street) full exhaust
Kingtal0n is offline
Old 03-15-2019, 03:40 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: 5.3 what turbo?
im gonna run a 7875 on a bone stock 5.3 . 10-12 lbs . hoping to have it running at the end of summer
freaky is offline
85berlinetta19
11-25-2001 06:44 PM
ChillPhatCat
10-29-2001 10:05 AM
G92Joe
10-21-2001 06:56 PM
Dan W
08-24-2001 07:29 PM
91bluebird305TBI
03-23-2001 01:15 PM
Quick Reply: 5.3 what turbo?
Advertising
Featured Sponsors
Vendor Directory
Contact Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
