Repinning TBI to Speed Density TPI
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Wanna go MPFI? Can't find a decent harness anywhere?
1228746 to 1227730 For TBI F-body
1227747 to 1227730 For TBI Truck/Caprice.
I originally wrote this 2 years ago. I recently upgraded to a '91 Firebird, and had use for my own article.
Lets start:
Gathering parts:
1) 8 Injector plugs and some wire
2) 1227730 ECM _AND_ v8 memcal!
3) 1227730 ECM connectors
4) MPFI Fuel pump
5) MPFI Fuel hoses if needed for your application (TPI)
6) IAC, TPS connectors for some applications.
7) MPFI Manifold, throttle body, injectors
8) New fuel filter
Step 1: Fuel pump
You will need to remove the fuel tank, and fuel pump sending unit. Replace the TBI fuel pump with a MPFI fuel pump. This is a good time to contact APE and get a Walbro 255lph in-tank pump. The connections + sending unit for TBI/TPI are the same.
Step 2: Fuel hoses in engine bay
The TBI fuel hoses are a little shorter than the TPI hoses. The fittings are the same, lines are the same, fuel filter are all the same. If going with TPI, you should really get the correct length hoses.
Step 3: Intake manifold
You should choose your intake prior to repinning the harness. Once your intake and sensors are in place, you will know how long to extend wires (if you have to). I am using a singleplane intake with center-mounted throttle body. The wires end up being pretty much in the correct spots.
Lets start:
Gathering parts:
4) MPFI Fuel pump
8) New fuel filter
Step 1: Fuel pump
Step 4: 1227730 conversion
Splice the right bank injector wires to 4 injector plugs. All the grounds go together to one wire, all the positives go together to the other wire. Now, splice the left bank in place to the left 4 injector plugs. If using TPI plugs, the green plugs go on right side, the red plugs go on left side.
Remove the ESC module. Cut the connector off, and splice wires C and E together. Tape up, and hide someplace neat.
Connect MAT, TPS, CTS, and IAC. Extend wires if needed.
Step 5: Repin
Now, repin ECM connector using following table:
Step 6: Calibration changes
At minimum, you will need to change the VSS constant from "magnetic" to "optical" because the 4-out buffer box outputs 2k pulses per mile, vs the 4k pulses per mile that the $8D calibration expects.
You may need to disable VATS, EGR, etc depending on how you did your swap.
Step 5: Repin
People typically don't source '749 ECM's much anymore. They *MAY* have the IAC wires differently. Consult your schematics and test as needed. Most people use a '730 donor ECM and run whatever code mask they need ($8D, $59, etc).
This assumes you've swapped out the fuel pump, and hooked up the TPI intake. This covers the wiring. An issue with some people is locating a good harness, then getting it in the car.. This should make that process a 45 minutes job. (once you've got the TPI setup actually in the car)
****! so this means I can just take out my TBI computer box , slap in a V6 computer box w/90-92 L98 Prom chip, re-pin the harness (in under an HOUR?) and voila?
pictures? Sorry, its VERY hard for me to picture things from text, I'm a visual person.
I'm having a hard time locating a good harness and was thinking of just saving up for the TBI to TPI wiring harness from hotrodlane.cc but that is over 700 dollars for shipping which is completely ridiculous!
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
A lil bit more than hour, but yeah it is that easy. I went from MAF to SD on my IROC in about an hour with only one screw up. lol
The only real problem with the TBI harness is, as mentioned already, the injector connectors, also you'll have to lengthen the TPS and the IAC wires. I beleive that the CTS wire is long enough already. Another thing is too, you'll have to change your knock sensor to the 90-92 style, or put a 6.1k ohm reisitor in the loop for the KS and you'll have to jump out pins C and E ( I think those are the two) together of the ESC behind the two relays on the firewall behind the power brake booster. Then take out the ESC module and toss it.
So its about 2.5 hours worth of work to go from a TBI harness to a SD harness.
Kat
Kat
have a 1992 RS...so the knock sensor is covered.
So how in the world do it take two injector wires and create 8 injector wires from that is my main question.
Yeah a few wires may need to be extended.Thats why I said get some wire.
I'ts about an hour to repin carefully. A little more time under the hood connecting stuff. But thats all trivial.
$700 for a conversion harness?? ouch..
-- Joe
Josh52784 (04-22-2022)
ohh ****ing sweet...Disregard the other thread...Thats all I wanted to hear. Any type of electrical wire works? Happen to know what guage?
By re-pinning:
You mean the two blue connectors that connect to the TBI ECM Box?
1)So I would cut off the two blue connectors from the 730 ECM box at the junkyard,
2)remove the box and two blue connectors from the yard V6 car
3)Go home, remove the TBI ECM
4)slip out all the wires from the TBI connectors
5)insert the TBI wiring harness wires into the 730 connectors
6)attach the V6 ECM with L98 prom inside and be done with it.
Is that what you're saying? Sorry for acting like a dumbass but I really don't want to be confused when I do this.
By re-pinning:
-- Joe
Jumper together you mean just twist the wires together and crimp it down?
Then I toss out the ESC connector? TPI makes no use of that in their distributors?
Cut wires C and E from the module, splice them together. Then remove the module and throw it away.
I think its on the drivers firewall near the fan relay if I can recall.
Big flat thing.
-- Joe
I've been studying this also.
How should I control the fans, especially since I switched to dual fans.
Just lookat the schematics.
-- Joe
I forgot to mention that I removed the AC system. Would that change anything?
-- Joe
Originally posted by anesthes
Not really. If you use the '730 to control fans, you'll just need to jumper a wire but no biggy..
-- Joe
-- Joe
I have the dual fans also. I have one fan running off a relay hotwired to the ignition so that it runs as long as the ignition is on and the other fan is hooked up to the fan switch. When I install the TPI harness, do I still have to hook up the second fan to the ECM?
Personally, I like the fan control on '730. You can set each one to turn off/on at different temps and MPH.. Off at 80mph, back on at 50, and so on.
-- Joe
Car: 1991 GMC K5
Engine: 350 TBI stock
Transmission: 700R4 stock
OK, to bring back a somewhat old topic. I will be doing this conversion on my '91 GMC TBI soon. If you are not familiar with the truck systems (as i am not familiar with the car systems) I believe it is the same style as the old f-bodys... two barrel TB... same as the '87 truck injection. Are the procedures the same as for the cars? Wires may have to be lengthened, but that is not a problem. Seems like i may only need a newer style knock sensor? Is this my first post? If so, Hello to all From CK5!!! They sent me here!!!
Just make sure you do it the '747 way.
-- Joe
-- Joe
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Kat
Kat
I have a 730 ECM just sitting here, I wanted a new harness, but you are saying I can relatively easily just switch over to SD? My LT1 intake already has the SD port on it and rigged up. If I can find a way to swap to 730 easy, i'll kiss you.. well maybe not because I don't swing that way, but you get the idea.
Mine took about the same amount of time. Its kinda easy.
-- Joe
-- Joe
Car: `91 rs
Engine: 352 TPI
Transmission: TH700 R4
pictures
Do you have a way of refering to wire colors when repinning for tpi? I`m having a hard time understanding the repinning table you have listed.
Car: 1991 Camaro
Engine: 383
This forum answered alot of question, but i have one more...Why would you use the v6 ecm? I have 91 305 TBI. Thanks this would help me save money instead of buying the new harness/computer/sensors
John
John
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
This deserves a bump...
especially now that it's lost behind all of the posts of people who can't use a search function
I'd like to hear from some folks (in this thread) who have done it, maybe share some tips.
-- Joe
-- Joe
I'm experimenting with a dual fan setup from a fwd Oldsmobile 88 and 3800 v6 as a cheap way to incorporate the dual fans. It takes some custom fabrication, but that's for another post.
Another tip I have is an easy way to get injector wiring is to take the quad 4 harness. It's got a 3 pin connector I just cut off. The length is near perfect, and it sure beats trying to pigtail a bunch of v6 injector wires together.
If you're doing a 5.7L swap, look for injectors out of a 91-94 series I 3800 or a 95-up series II engine. The earlier ones are 22lb/hr while the later ones are 24lb/hr. http://dtcc.cz28.com/gminfo.htm is part of a frame that has a ton of info.
The biggest thing to remember is interchangability. Mass Production has it's advantages in similar parts. (i.e. injectors, sensors, etc.) If a part looks the same, it most likely will work.
Oh, one last tip I have is mock up your system outside of the car first to get your wiring lengths right (especially on the TPS)
What speedometer do you use then? I'm putting this into an originally carbed car, but have the electric speedo... I assume I can use the same one?
also have a fuel pump question. I have an 86 carbed motor. Do I need a different sending unit that holds the pump as well, or does the fuel pump mount to the carbed unit?
Car: `91 rs
Engine: 352 TPI
pin removal
How would be the best way to remove the pins from the harnesses? Also, is there a way to make a adapter harness using the connectors from inside the tbi ecm?
Re: Repinning TBI to Speed Density TPI
Wanna go TPI? Can't find a decent harness anywhere?
1227746 to 1227730 For TBI F-body
Since i've repinned before (maf to speed density) I think its tons easier than running a new harness.
I grabbed Mike Davis's '730 swap, and hacked it up a little changing it to TBI pinouts. I'm 99% sure this will work, with only a few mods maybe to be done. (splice a ground or two)
This assumes you have allready:
1) Replaced the in-tank fuel pump with a TPI pump
2) Replaced the TBI intake with a TPI intake
3) Connected the fuel lines, and are ready for wiring.
-- Joe
-- Joe
Re: Re: Repinning TBI to Speed Density TPI
Originally posted by 91blackgta
Do you mean 1228746 instead of 1227746?
-- Joe
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
I am really **** about having cut wires, but couldn't really cough up $150 for a harness right now. I repinned my TBI harness today while my motor was out, but I went a step further. I had a really hacked up 85 TPI harness lying around that was next to useless, and I removed the wiring for the injectors, iac, and tps (surprisingly, these were uncut). I carefully separated them from the harness, traced them through to the ecm, and unpinned them from there. I did the same to my TBI harness, traced the injector, iac, and tps wires all the way to the ecm, and unpinned them. Then I replaced them with the TPI wires (iac and tps are now the correct length). This way, I didn't have to cut any wires, all looks stock. While I was at it, I also removed the air divert and egr wiring, as I will not be needing those. Repinning the harness as anesthes outlined above was pretty straightforward. It took me about an hour and a half, but only because I purposely went slow and triple checked everything I did. I don't want to end up tracing electrical problems. Doing what I did to avoid cutting any wires took me all day, as I worked slowly and methodically. Its not difficult at all, just annoying work. I'm gonna try leaving the fan control as it is now. If I run into cooling problems, I'll look into dual fans.
By the way, if you decide to take a look into a Chilton's manual, don't take their diagrams for granted. The one I was looking at had a mistake or two. I believe the 746 to 730 chart in this post has an error as well. Take a look at the line with BD12 and A8. A8 was already used in the chart privously ( BA8 and A8 ), which is supposed to be ALDL Serial Diag.... Looking at the unreliable Chilton's diagram, A8 on both the 746 and 730 ecms show as an orange cable, without specifying what its for. BD12 is labeled on previously as A/C Pressure Switch, but I can't tell from the diagram I have in front of me what it should correspond with from the TBI diagram. I'm kinda tired though, so that may be my problem, I'll look at it again tomorrow.
Clarifications on the Wiring of 746 to 730
There is one error in the repinning table, and it's important for those of us who want to keep the EGR Enabled.
730 terminal GE9 should be pinned with the wire originally on 746's A4. AGain, for those running a stock EPROM or Super AUJP with EGR enabled need to have this pin correctly installed to avoid an SES.
I am also not a fan of using a single +5ref for both the MAP and TPS, especially if there is a provision availible on the 730.
My solution was taking a pin from my old CCC wire harness that went to a MAP sensor and running it through the harness creating a seperate +5 ref like the factory intended.
Also I've found that Quad 4 motors had a seperate injector harness. I simply disconnected it, cut the plastic wetharpak connector off, spliced the two drive wires together and presto, had me an injector harness that makes a much cleaner install than the 3+1 look of the v6 cars.
Many Mild 350 TPI applications need a 24lb injector... stock on 1990-1994 3800 series I tuned port engines is a Bosch 24lb injector. These motors are finding their way into the yards more and more. I got 6 of my 8 injectors form a 48,000 mile motor. the other 2 a 64,000 mile motor. They are currently being sent to be fow matched and cleaned. I got all six form the second car, in case any were bad. I think the harnesses and the injectors ran me about $40 at the U-pull-it yard near my place.
Re: Clarifications on the Wiring of 746 to 730
-- Joe
Former Sponsor
Car: 1992 Camaro RS
I removed EGR and installed a block off plate, and I also disabled it in my PROM. As a result, I didn't pay any attention to that pin.
I think there is still a bug in the table though:
A8 was repinned to BA8 for the diagnostic link.
Later, you have BD12 listed with A8.
-- Joe
Car: `91 rs
Engine: 352 TPI
tool for pin removal
What type of tool would you use to remove the pins out of the harness? Also where would you get one?
Here's a thread on the Fiero board of the exact same question I asked with some good answers. I'm personally using the eyeglass repair screw driver.
http://www.fiero.nl/forum/Forum2/HTML/054649.html
EDIY: I've decided to do some web searching for extractor tools and this was first on the list in google:
http://www.berkut13.com/extractor.htm
Former Sponsor
Car: 1992 Camaro RS
I picked up a weatherpack terminal tool kit from summit. $10 for three different picks. Quite handy.
you can use the components from the 87 TPI engine, minus the ecm and maf sensor. This works for a speed density system (MAP Sensor) 90-92 model year
Car: 2001 SS Camaro
Axle/Gears: I should know this
The wiring confuses me completly.
If i have my 91 tbi harness. And i want to switch to tpi, which diagrams am i compairing?
Is 1227746 the tbi and 1227730 the tpi?
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
