Third Gen Dual Exhaust Picture Collection
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Dual exhaust picture collection ***HELP RE-READ***
UPDATED 5-19-2006
http://fbody.beater.org/
After a long time of the original picture collection being down I've finally put it up again. I'll be adding more pictures and redoing it all pretty soon ...I'm kinda lazy though.
HP52TA (10-11-2021)
A picture is worth a thousand words, and both those sites have alot of pictures
*****, how much did it cost to get that system done? Do you think it was worth it for the performance and sound?
Thanks for the info guys
Matt
Matt
Car: 1987 Z28 Convertible
Transmission: 5-speed
Matt,
Before I had my exhaust done, no one I knew of had accomplished a true dual setup using the stock routing. Also, no one I knew of used a pair of chambered mufflers. All the pics of other systems I saw were crude, at best -- most had so little ground clearance that I would not be able to drive into my driveway. Most had mufflers hanging so low they were tacky looking. I like doing things slightly differently and decided that I was going to make it happen. I like to think I accomplished this. Because mine uses stock routing, ground clearance is not an issue and all the pipes look like they belong where they are.
The sound is awesome. Here's a sound clip:
http://www.iroc-zpostforum.com/MemberWillie.htm
It turns heads wherever I go. As for performance, I do not have before and after runs with only the exhaust being the difference. Therefore, I cannot quantify the improvement, if any.
The complete system was not cheap, but I did NOT cut any corners. I used very expensive mufflers and bought six 180 degree mandrel bends (to be cut to desired length by the installer). I also used a pair of Flowmaster "Ys" to act as an "X" pipe. The shop I had the work done charged $60 per hour, which included the straight sections of pipe. It took them five hours.
To minimize the cost, have the shop supply and bend all the pipe and do not use an "X" pipe. Also, use a much cheaper pair of mufflers and the cost would probably be half of what my total was.
Willie
Matt,
Willie
Car: '85 Z28
Transmission: WC T5, 3.23 posi
We should make this a sticky. 88IROC350TPI, that is an excellent site with all the pics of dual exhaust from TGO, very nice, it's going in my bookmarks...
Car: 1988 IROC-Z Convertible
Engine: 408 Stroker Turbo, TPIS Mini Ram
Transmission: Magnum t-56
Axle/Gears: Ford 9" 3.55
mine is the second one on the first page
you forgot to say its true dual 3"
sweet! I was just trying to decide on a way to run a true dual exhaust and I wanted to do it along the stock exhaust location...what I was wanting to do is already pictured so it will make it that much easier to do! Thanks for those great pics!
Car: 1989 rs camaro, 1990 jeep wrangler, 1995 eagle talon tsi awd
Engine: nothing right now
Transmission: j.w. performance th350 3500 10" stall... soon to be t56
great site, i think it would answer at least a third of the questions in this forum, lol
camaro picture u have..
Hey man whats up i was just wondering, do you have any more information on the red camaro that is first shown on that exuast page of yours that has dual 3" into X-pipe and out to 3.5" dynomax bullets. Is he a body or have a web page that has info on that car. I was just wondering bc i want to find out what size of rims and tires he has out in the rear. and just want some more pictures of his car, bc it looks good. I have a red z28 91 and it looks just like it minus the rims and hood. hope u can help, cya
Car: '89 IROC-Z
The guys name on here is "The Man" heres his post where I got the pics from: https://www.thirdgen.org/techbb2/sho...hreadid=182537
tra309 (06-19-2021)
Car: '89 IROC-Z
heh ...well, looks like the site might be goin down soon unless, of course, someone wants to host it on a real server
Dear EarthLink Member,
Your free member Web site http://home.earthlink.net/~chris255 has been popular this month -- maybe a little too popular. According to our records, your Web site has exceeded 75% of your traffic allotment this month.
If your free Web site traffic exceeds 1024 MB, the site will become unavailable until the beginning of the next month. During that time, no one will be able to access your site and you will have only limited abilities to publish to or modify the site's contents.
here ya go man...
from the side
[IMG]
http://images.cardomain.com/member_i...51_37_full.jpg[/IMG]
heddman longtubes, xtensions, moroso spiral muffs, turndowns. going to get an h-pipe soon though.
from the side
[IMG]
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I'll post pics of mine tommorow. I had a custom mandrel bent 3inch X pipe system with the traditional muscle car routing, and they had to install the mufflers in the rear location where the factory crossflow was installed. With hooker long tube headers, 3inch piping, x pipe and 3inch stainless magnaflows, it sounds badass. My car is lowered too, and it doesn't have any clearance issues except over steep dips or big speed bumps, which I can manuever over. I was really amazed at how the shop (eastside performance exhaust) tucked up the dual 3inch pipes so well on a thirdgen of all cars.
Car: 91 RS Camaro
Hey you guys what kind of muffler is that, that is used on either side of the gas tank? Looks small and discreet. That isn't made by Borla is it?
you know, i thought that they would be louder than they are. inside i can still have a conversation with someone, they are really mellow for being a race muffler. i am not saying they are not quite by any means, but they are not obnoxiously loud. and they have a really cool bark when you step on it. i wish i knew how to post videos.
Car: '85 Z28
I have duals with 3" center in/out aerochambers and it's kind of loud. You can see right through the mufflers... Got a pic of it around here, I'll try and scan it in sometime. Anyways, I've been thinking hedman longtubes and the morosos. From everything I've heard they're more bassy than actually loud (unlike the bullets which barely muffle). I honestly don't think they're louder (or not by much) than my hookers. To have a converstaion in my car you have to raise your voice quite a bit. My dad doesn't even like riding in my car cause he says it's too loud, lol and he's a car guy! So what's your opinion 66nova? Oh, sound clips would be cool too...
Originally posted by iroczrockz
Are they going to be too loud for a street car?
A. what you think is loud
B. what your cops in your area think is loud...
probably too loud for most peoples street cars, but i will drive mine everyday anyways...
Car: 87' Iroc-Z
here's my old one from last year (last spring 2002) my new exhaust (end of spring) consists of those same Muffs as Willie which are the Stainless Specielties Chambered Tube.. but this is the old setup....all 2-1/2" piping, 2 Dynomax Cats 2-1/2, 2 40 Series Flowmasters, out of side exits, 2 Borla Intercooled slash tips., surprisingly there was a fair amount of room under the car except that the mufflers were a lil too low, so that's why i got the chambered and there's alot more room now (no scapping or having to worry about it all the time)
Car: Camaro
Engine: Gas
Transmission: Automatic
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
heres my true dual pics CLICK ME I did the best i could ill put up some more in the next few days its really hard when the car is only a foot off the ground though. Ill also get some pics soon of where it goes over the rear axel soon. If anyone has any questions about the routing of pipes or anything feel free to ask and ill answer/get more pics to show ya. Also remember this is all through stock pipeing and i dont have knowledge about pricing or anything because the previous owner had it done.
*UPDATE* the moroso spiral mufflers are mean sounding, but after driving for the last 4 days, i have found them to be annoyingly loud on the roads, cool for the race track, too much for the road. i will be upgrading(or downgrading) to a set of dynomax superturbo mufflers. i will let you know how they sound and i will post some pics after i get them installed...
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
too loud for the street???
man i bought them since they were quiter than the bullets....don't know til i fire the motor up i guess for what i consider too loud.
Here's a pic of mine. I borrowed *****'s idea for the duals down the stock routing, but mine are slightly different.
You can see a description of how we did it, and a bunch more pics at my website in my sig.
I'm working on getting some pics of it mounted up on my car, but I made a design error on the front part so it hangs down about 3" lower than it should. As soon as I trim up the pipe I'll take some pics of it.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Dunno if side exhaust counts here, but I found pics of it on my computer (dunno who's it is though)
One of these, either side:
Car: '85 Z28
I think the guy's name that owns it is Andrew, but I can't remember his username.... I'll look it up later, I have it somewhere.
Car: 85z28 // 97 Hawk
Engine: wore out 360 // LT1
Transmission: 700R4 // 4L60E
Axle/Gears: 3.73 // 3.23
these are not the best pics but
on the right side this is where the header meets the pipe.
this is on the left side in order going from the header to the glasspack. from the glasspack it used to turn out and come out under the gfx but i cut it off right behind the glass pack
I wish I had better pics. that and better exhaust like ******* but maybe someday.
edit- i forgot to mention that is on the 85z
Car: Still a 3rd Gen
Engine: 450HP 355
Axle/Gears: 9" with 4.11's
damn, i've only personally seen a true dual setup a few times on a 3rd gen, one was with some vette sidepipes and the other was my old setup with 2.5" side pipes off my shortie headers.
I'm just running a 2" crossover off the shorties Y'ed into 3" through the stock channel split into dual 2.5" at the back. No muffs
*loud and proud*
no tickets yet............
*loud and proud*
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
is that with a shorties and a standard trans?
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
Originally posted by juggernaut_69
gta w/duals
gta w/duals
