How can i find out if my TA is WS6?
Car: 05 Grand Prix / 85 Trans Am
Engine: 305 TPI Bored .030/Cam
Transmission: 700R4 Megashifter
hey guys i tried searching and i must be search-tarded but i'm kinda still new to trans ams. I have an 85 Trans AM, and was just wondering where to look to see if this car was originally a WS6.
Thank you so much.
Thank you so much.
thank you i know it is an option dealing with suspension, etc... however i am trying to figure out WHERE to look... i know the code, but where do i look? where are all of the places i can look?
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
does it have 4 wheel disk im pretty sure all ws6 had four wheel disk, im not positive though
Car: 1987 Black IROC-Z (SOLD)
Under the center console lid/inside the rear hatch compartment. Otherwise the previous owner ripped it out.
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Car: 1987 Pontiac Trans Am
Engine: 305 LB9 Tuned Port Injection
Transmission: 700-R4 Automatic
Axle/Gears: Saginaw 10 bolt 2.73 posi
The WS6 package in 1985 included 16 inch wheels, so if your center console RPO sticker is missing, look on the driver side door for the sticker with the tire information. That sticker will say something like 245/50R16 if its a WS6 car- it will also have your build month and year. Also there should be a small "performance suspension" emblem on the passenger side of the dashboard, below the map pocket. If its missing the emblem and had 15 inch wheels, the car was not a WS6.
I hope you don't mind me butting in i just posted "WHAT IS THIS????????????????????? HELP "
Talon
asking info about my 1991 firebird formula,, I am curious, what does "WS6" mean, stand for, is it an option most everyone wants,??????
Talon
Car: 85 T/A
yea so my babay just matched all that so she must be . But I think i have 15 in tires. i no i have the performance emblem uder the map pocket!
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
1985 was an interesting year for the Trans Am- the 1984 WS6 package specs were made standard on all 85 TAs but the new for 85 WS6 package included 16 inch wheels with the new Goodyear Eagle GT "Gatorback" tires, as well as slightly larger diameter sway bars. WS6 was retuned (in regards to the shock stiffness) to take advantage of the leap forward that the Gatorbacks offered over other tires- these tires were state of the art in 1985. The ride was a bit less harsh and crisp as compared to an 84.
Car: Recaro Option T/A
Engine: 305 Tuned Port Injection
Transmission: Automatic
Axle/Gears: 3:27 Borg Warner
....... Also there should be a small "performance suspension" emblem on the passenger side of the dashboard, below the map pocket. If its missing the emblem .........the car was not a WS6.
The badge mentioned is not a WS6 exclusive, these are found on many non WS6 cars
Car: 89 trans am ws6
Engine: lb9 5.0
Transmission: 5spd
Axle/Gears: 3:09
p.s. I have rear drums.
Car: 88 Formula 350
Engine: Hopes and Dreams
Transmission: Slush Box
Axle/Gears: 9 Bolt, 3.27
Originally Posted by j dezzy
My 84 doesn't have the WS6 package, but it does have rear disc and 16" rims originaly.
Car: 1984 Trans Am
In regards to the 1984 T/A, only the 10th Anniversary Edition cars came with 16" rims. They were the first f-body to be offered with 16s
I don't know how much help this is, but on my 88T/A I have the "performance suspension" under the map pocket but I don't have a WS6 on the RPO sheet. I have a WS3(Unknown) and WS4(T/A designation) listed, but no WS6.
I'm kinda lost, haha.If anyone can help explain why it's there, that would be cool.
Engine: lb9 5.0
Transmission: 5spd
Axle/Gears: 3:09
Originally Posted by AmorgetRS
Read post 15... the Perfomance Suspension badge is not WS6 specific.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Wow, this is facinating...
OK #1 the 36mm front sway bars did NOT appear until 1986...
WS6 & WS7
1982 - 1984: 32 mm Front 18mm OR 21 mm rear (depending on your engine)
In 1985 the F41 HD suspension was upgraded to be like the WS6 suspension from 82-84
NOTE: the 1984 Special T/A's with the 16" rims got the 24mm rear stabalizer
1985: 34mm front and 24mm rear
1986 - 1992 36mm Front and 24mm rear, there was few 1LE cars that got a 23mm rear sway bar for racing in the later years, apparently the cars were too "tight" to correct this they used 23mm sway bars.
ALL WS6 cars from 1985 - 1992 I thought used the 16x8 rims... BUt 85 may be an exception BUT I doubt it. the 16" rims ARE NOT an indicator of the WS6 package, from 1988-1992 a Trans Am without WS6 could be had with 16" rims.
1984 was the LAST year for WS7 which was the same suspension as WS6 BUT with drum brakes, starting in 1985 the WS6 suspension was specific to the suspension and did not determine rear disc brakes.
John
WS6 & WS7
John
Originally Posted by gon8go
what is level 3 suspension(read in 89 brochure)?
Level 2 = Y99
Originally Posted by 1985WS6transam
My 1985 Trans am was definalty a WS6, had the rpo sheet and all, but had 15 inch wheels. It also had the performance suspension emblem. The 15" wheels were verified by the door sticker so maybe not all 85TAs had the 16" wheels. Maybe something to look into.
A pic of your RPO sticker would help, one of those deals where you have to see it yourself to totaly comprehend it.
Engine: lb9 5.0
Transmission: 5spd
Axle/Gears: 3:09
I re read the brochure and it said that a standard trans am came with level 2 suapension which was 34mm front+23mm rear swaybars and 15" turbo wheels
level 3 was the gta package (ta option) with 16" spoke wheels 36mm+24mm bars. but it mentions it like it is separate from ws6 even though it sounds the same.
........, starting in 1985 the WS6 suspension was specific to the suspension and did not determine rear disc brakes.
John
John
If it helps WS6 was standard on GTA and Formulas
Engine: lb9 5.0
Transmission: 5spd
Axle/Gears: 3:09
This is a 89 Brochure right? The option packages varied from year to year so it gets confusing.
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
my 88 formula had the WS6 package (bigger front sway bars than an IROC, 16 inch wheels that said WS6 in the centers, a 3.23 pos rear but with drum brakes, the little performance suspension tag on the dash, etc. It was a 305 TPI with 700r4.
Engine: lb9 5.0
Transmission: 5spd
Axle/Gears: 3:09
just checked my rpos and its there. I guess they only badged it on the formula and gta. I noticed it designated on the wheel center cap, mine just has birds.
I guess I would have to see an 85 WS6 w/o rear disks, because it was SUPPOSED to be included in 85, thats the way it was sold and advertised at least.
John
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The standard T/A did have the Y99 suspension which had the same swaybars as the Iroc's but the WS6 upgraded to the 36/24 starting in '85 if I remember correctly. The 9 bolt I pulled out of an '85 L69 car has the big 24mm rear bar, and has the 36mm front bar (which reminds me I need to go pull it) and it had the Performance Suspension badge on the trim on the passenger side.
i cut up a red 85 trans am ws6 with disc posi 3.08 10 bolt and 15" wheels
my 82 tran am is a WS7
good thread here
good thread here
Car: 02 WS6, 83 WS6, and 78 Project
Engine: LS1, LG4, and 400
Transmission: 4L60E, T5, and TH400
Axle/Gears: 3.73, 3.73, and 2.73
Re: How can i find out if my TA is WS6?
I have an '87 Trans Am (Which appears to be a debadged GTA) and an '88 Formula.. both have WS6 in the RPOs.. both have 16" wheels.. both have Rear Drums.. and both have the "Performance Suspension" badge inside. So I'm guessing that rear discs were a sepparate option from the WS6.. atleast during those years...
Car: 1971 Camaro
I have a 85 TA with the ws6 suspension that I'm getting parts off of before I call someone to come get it. Is there anything desirable or beneficiary about this option that would warrant me pulling off before I let the car go?
If I end up buying a 3rd gen Camaro Z28, would it have a similar suspension or would I benefit from swapping over parts?
I guess what I'm asking is does the 88-92 Z28 have rear disc brakes?
Car: 1971 Camaro
Thanks!
I'm trying to find a car more complete and drivable, I was talking to the guy that owns the salvage yard down the road that has a 91 Camaro Z28 TPI that's pretty clean. He said he wanted $1500 for the car but when I got there the engine was out of it. Why I don't know, he babbled something about the PO putting in the wrong computer.
Other than that it would be a good car, it's pretty clean. Red w/white rally stripes and a red interior. Has some enkei wheels on it.
Having said that, my brother bought this Trans Am I currently have from this same guy 3 years ago. My brother never did anything with the car so I traded a older big screen TV for it. I had to jump through hoops to get the title work done. It wasn't as easy as I though it would be.
Anyway, this guy asked me what I was going to do with the Trans Am and said they guy that sold it to him wanted it back. I explained it was just a shell and I would take $300 for it.
I think I'm going to keep it and pull the tranny, suspension, harness, and a few other things out of it to keep for myself. The transmission was rebuilt and hopped up shortly before the engine blew up and it ended at that guys yard.
I hate to part it out, but unless I find a clean firebird as a donor it's would be pretty expensive to fix up. I don't have that kind of money.
Bad thing is it's never been wrecked and rust free It was just badly neglected and sat for a long time so all the rubber is shot and deteriorated.
You might be able to fix it up cheaply by buying a complete parts car. I recently bought a '82 T/A with a hacked and blown up drivetrain and picked up a complete and running rust bucket '84 T/A from a local junkyard. All together I have less than $1000 into both cars and I still haven't parted out the '84 T/A for the parts I won't be needing.
Car: 1984 Pontiac Trans-Am Recaro
Engine: 305,elebrock650,weiand,tumprcam
Axle/Gears: 373 posi, wS6 suspension
No, not all od them, my car has the 4 wheel disk brakes, but is not a ws6
I just got an 85 and it has the Performance Suspension badge. As you can see I have the 15-inch wheels on it although it has another set of wheels I'm thinking it's the 16's. I don't know yet I haven't seen them. As you can see the motor and trans are out of it but it came with the tuned Port injected motor and the 700R4 trans which I have. No RPO in the console and nothing on the door about the tires. I have rear drums as well. Need to pop hatch & look. Where's Glove box? I see 3 map holders.
It'd be in the center console if it's still there. They were just peel/stick labels, that often peeled off, especially in Firebirds since it's stuck to the side of the glove box in the console. Anything in the glove box tends to rub against them, so they get beat up in short order.
The difference in 85/86 was pretty minor, mostly the difference between the level II and level III suspensions. At this point, 75% of those components are due to be replaced anyway as preventive maintenance and general upkeep. It's hardly worth worrying about, with all documentation missing its a moot point.
I believe the WS7 started in 1979. In 79 they rolled out the 4 wheel disk rear to come as part of the 2nd year WS6 package.
They were projected to run out of rears because the soaring popularity of the option being ordered and came up with the WS7
(std rear drums like 78) so they could keep on making the cars with rest of the package.
I didn't realize that was still going on in the 3rd gens too. No clue if it was for the same reason, or if some people just didn't want the rear disks. Makes sense to keep the option, in case the supply would run out. I am guessing that happened to a lot of options back then & maybe even today.
Back in early 1978 WS6 included a higher output engine as well as suspension & was amazing what a change that made to the car. First time I drove one I couldn't believe how it felt compared to a std 78 T/A.
Pretty sure my 1982 Recaro had WS6 but I never verified it. It had that std 15" wheels like was mentioned above. I didn't realize at the time the optioned continued into the 3rd gens. No internet back then. Just dealers flapping their lips & others repeating it.
82-84 WS6/WS7 got the 15" rims, except for 84 15th anniv ed
85+ WS6 got 16" Rims... The F41 Suspension was the Base Trans Am suspension and and they too got the "Performance Suspension" emblem.
The WS6, WS7, WY5, WY6 were all gone by 1985, 1984 was the last year for any of those.
I should have said WS7, WY5 & WY6 ended in 1984... sorry
WS6 was an evolution, WS6 in 1984 is not the same as WS6 in 87
I am trying to remember the specifics, so I might be wrong, I do not have my information on me right now, so this is by memory
WS6 = Rear Disc + Posi , and larger sway bars, wheels
WS7 = Rear Drum + Posi & Larger sway bars, Wheels
WY5 = Rear Disc (W/O Posi) & larger sway bars, wheels
WY6 = Rear Drum (W/O Posi) & Larger Sway bars, wheels
I think 1985 (87+ for sure) WS6 became specifically a handling package, (16" Wheels, larger sway bars, specific shocks and struts etc)
Axle/Gears: 10 Bolt 2.73 Open
Just a good sanity check for me!
Your description of the 87+ WS6 content matches what my '88 included.
Breazlan
09-25-2015 11:20 AM
MikkoV
09-09-2015 04:25 PM
