How would YOU build a 10 Bolt?
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
Hi Kids! New project, I broke the rear in my convertable IROC. It's an '88 with only 70K miles. Took two teeth off the pinion gear due to failed pinion bearing. I had an '89 RS for a parts car and I pulled the rear and stuck it under the Vert. So now I'm lookin' at the busted 10 bolt with the drum brakes and I'm thinking " I could build a rear that would last and have what I want in it"
Hence my question, What would you build? It is a posi (sometimes) and has highway gears (3K at 70 MPH) and drum brakes. I was thinking about 3.42's and a decent center section. Then maybe some disc brakes (PBR/1-LE's?) All new bearings and reuse the stock axels. Good plan?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i wouldn't spend money on a 10 bolt, find a junkyard rear and swap it that way or keep the cash as a 12 bolt/9" fund some day. These people that spend $800 on a gear swap, axle swap, girdle, etc make me wonder sometimes when they're halfway to a 9" that probably will never brake.
Well, I was just gonna go through this rear and make it good. The car is not fast, it's a 305. It's pig heavy and I'm not building a race car. It will most likely get a 350 or 355-LPE 219 cam and ported aluminum heads. I just want something to move the car out a little better and last in a car that's more for cruising than beating on without mercy. I have the white IROC for that!
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I spent $1450.00 on my 10 bolt. And its a piece of crap Gov-lok. I am looking at spending another $300 installing a used Torsen. I did it this way because I didn't know better at the time, and I bought all the parts peice-meal, then after it was all done I added it all up and said "S@#T! I could have had a moser 9 inch for around 500-700 extra!!"
Even if I install the Torsen, and tried to sell it I would be lucky to get 300-400 out of it, and thats with the Torsen and 3:73 gears.
I would seriously think about the Moser 9inch or 12bolt, or the Currie 9inch.
Lets see, i've broken 4 posi units (2 of them auburn pro series) 3 sets of gears, countless spider gears, and i haven't pulled the rear end cover yet to see what i broke friday night (probably the carrier broke in half). Get a twelve bolt. if you break 1 ten bolt, you will break another one soon enough.
Thanks for the replies, You know I've been banging around on here since '99 and I ALWAYS forget the tech articles! Thanks, I printed and read them at work.
To all the guys who are screaming "GET A NINE INCH" -I know, Whenever I'm on here and everybody tells you the same thing it's because they're right. And you are. It's just in this case I'm going for a stock/unmodified look, No heavy mods. I want to keep the car original. In looks anyway. I already have an IROC that I went nuts with and It's a lot of fun but nobody wants to ride in it. It sucks on trips. It's tempermental, rides rough, runs hot-I have over rides for the fans. Manual lock-up on the converter, Line-lock. Nitrous switches on the console that EVERYBODY wants to f&%k with. Now I've got a cage in there. I got the Vert just to ride around in. Seeing and being seen- That is what the Vert is about.
Now that being said, Who here can help me out?
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I myself like the 3:73's I put in mine (had a 2:73 stock). I used Moser axles since I had a 26 spline rear and figured all the time and effort needed to find a used set of 28 spline axles would be time wasted and I would be better off with new alloy pieces that would be by far superior. I also installed an aluminum support cover. I may want to weld up the axle tubes but I have not decided on this one yet.
All the work was completed obviously with a rebuild kit and I used a new GM Gov-Loc differential (like saying I put a rotten cherry on top of my ice cream sundae). I am in the process of installing a Torsen right now and eventually down the road a few years I will hopefully move up to a 9 inch.
I'd just toss a used 9 bolt in if I were you.
Good value, simple bolt in and they are strong.
You can rebuild the posi's get aftermarket 3.70 gears as well now for them.
If you don't like that I'd look in to fabricating a Ford 8.8" unit.
The 9 inches and 12 bolts are pretty pricy, you can get a good axle for much cheaper in there if you a willing/able to fabricate a little.
I have a 9-Bolt in the white one, I am kinda looking forward to building a ten bolt because I have never done one before and I like having a new project. You believe that right? O-K, I have no life. There is the truth of it.
Anyway, Here's were I'm at:
1. Clean, Blast, and inspect housing
2. Weld axle tubes
3. Paint
4. Diff cover w/ girdle
5. Solid bearing spacer
Now for the questions:
1. I have 2.72:1 gears, Do I need to throw everything away and start with a 3-series carrier?
2. The housing will be reused right? that is not series sensitive?
3. It's an '88 so it will have 28 spline axles right? I will go count them tonight. I can use any diff for 28 spline axles then correct?
4. What posi unit is in there now? Is it an Eaton? What's better an Eaton or a Torsen?
Now, Based on what the answers to those questions are here is what I think will happen.-
Pick up were I left off in the first part of the post. Reuse stock axles, Score a Torsen diff. on ebay for a series 3 carrier. Get a 3 series carrier as well. Then some get some gears. Probably 3.42's or something similar. Finish off with a rebuild kit and try my hand at putting this thing together.
After that I will be back here asking questions about what brakes to go with. How's that?
2. Weld axle tubes
3. Paint
Car: projects.......
diff/carrier = same thing. A 3 series zexel is a 3 series carrier. - If you do have 28 spline axles, stick with them for mild to moderate power, go aftermarket for higher hp, if they are 26 spline, go aftermarket 28. Weld the tubes, get an aluminum cover/support, depending on the camshaft/intake, either a 3.42 or a 3.73 gear, a solid pinion spacer for good measure and have fun.
Built up they'll take quite a bit, but it can quickly become a waste of money for any high powered car. I'm running 11's on mine with 17" dr's and a stick. 1.6X 60fts. Will it break? ....probably. It is built, but only because I got a hell of a deal on it as is(stocker was a 9-bolt) - Seems anything past 3.73 gears is quick death because of the small pinion.
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
You guys keep suggesting 9 inch 9 inch 9 inch, and while I agree that this would be the most desireable setup, you guys that have broken your rears countless times (not just in this thread, but from what I've seen all over this board, not trying to single you out here Matt) have to think about what you are using your cars for. You guys are running 12s and lower at the track with slicks, so of course a built 10 bolt wont hold up.
But for what Mike here is using his car for, a built 10 bolt would be, I think, fine for him, especially if he is on a budget. Even with the heads and cam, he's still gonna be making just over 300hp, and this is enough for a STOCK rear to handle in many cases that I have seen, including mine.
I have been researching rears heavily in the past month, as it is time to do something about mine, as I am probably making just shy of 400hp, and somethings going to give eventually.
I'll tell you what I am doing, and you can tell me what you think. First off, my goal was to make something that can handle power, without having to change out worn out clutches (as this is what is wrong with my unit now as well, might as well be an open diff)
-Eaton Truetrac Differential DTL-912A317 - $365.95
-Alloy USA 28-spline Axles ALY-12103 - $209.95
-Richmond Gear Install Kit RMG-831044M - $128.95
-Richmond Gear 3.42 Ring and Pinion RMG-4900451 -$185.88
-Aluminum Rear End Girldew/stud kit(from LPWracing.com) 3017.5G - $190
-Solid bearing spacer (dont know where I'm getting this yet) ~$30
-Welding of axle tubes to pumpkin - Free
Grand total: $1110.73
Now, compared to paying over $2000 dollars for a 9 bolt, and making it fit, this seems pretty reasonable to me, especially since my IROC is my daily driver, and never sees track time. Maybe once a year, and I don't use slicks. Hey, some guys can afford to say "hey, spend 900$ more dollars and get a tank of a rear." But as for me, as a guy paying his way through college taking out $10,000 loans every year, this is about as much as I can manage. I'm in no way, shape, or form trying to sound like an arsehole here, but rather, just trying to make you see it from a different perspecitve.
Hope this helps you out, and good luck on your selection.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I've also built up my rear end, with some of those goodies.
I left the axles and stock gears and posi in, but used the solid pinion spacer, summit girdle, and welded the tubes.
There's also a stud kit for the main caps, TA racing, and another company make these.
If you're looking for more strength, (or more money to throw at it, since i'm not sure this is much help), there's a tube support setup. It braces the tubes, and bolts to the rear cover. Just have to use this companys rear cover setup. I think bracing the tubes is going overboard, but it's an option. (Forget the co. who does this).
Make sure you tighten the solid pinion spacer down good, I used a 5' snipe I think, loctite the nut, and then stake it.
don't overtighten the preload bolts on the girdle. This is a wonderful invention by the way.
If your 2 series posi is still useable, you can use a higher gear ratio and a spacer. Just in case somebody in this thread didn't know this little tidbit.
Some redline "shockproof" fluid is a nice addon. Yea the fluid is pricey, when compared to fluid, but when you think it's only 2 quarts or something, and it's going into the rear for a good long time, you can compare it to bearings or something, and it's pretty cheap when you look at it that way.
Careful welding the cast housing to the steel tubes. Use a weld-all rod, or high nickel rod, if you're using a stick welder. Just don't crank up the heat on your mig as if to weld the 1/2" thick housing (that kind of heat setting), and go to town, good chance you'll warp it. A nice small stitch bead will add mondo strength as far as torsion, without warping anything.
Car: 87 IROC
Why not just buy a used rear end out of an LS1 car? I've seen complete rears for $150-$200 locally, and they have most of all the parts you are looking for already. If you can live with the extra width, why not?
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
I think the 4th gens are 4" wider.
This is how I had mine built recently, but with 3.73s, the $770 in labor and $130 for sandblasting and priming. I didn't want to spend $1100 just to take longer and mess it up. Like the rest of the car, its all a package, I don't plan to put more than 400HP in my car (260HP crate currently) and don't plan to race it often, so I figured its worth saving the $. Besides I knew there wouldn't be any fitment issue or need a weird brake setup. Just my
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
since you're going for that stock, look...
i would snag a 4thgen rear. they're cheap because people swap to other rears all the time.... and:
you can get a econo happy 3.42 or a snappier 3.73 rear.
you would have upgraded disc brakes.
it would have a posi...
and you can bolt on 3rd or 4thgen style rims...
but really.... if its going to have a modded anything-other-then-a-305 engine, i would get a aftermarket rear. do it cheap, if you want.. a used stock ford truck centersection and a moser housing/axle/TQarm mount package...
I can get a good deal on a '94 or '95 Z28 rear but it's been completely rebuilt with Auburn posi, strange 3.73 gears and axles, welded tubes, LPE girdle, disc brakes etc...The dude wants $700 for it. I think it's worth it.
Question is, will it just bolt in my 3rdgen? How much of a gap am I looking at here for the fenders? Will my stock GTA rims bolt up? Need all the details...
a 4th gen rear is just under 2" per side wider. - I'm running custom billet wheels, so it didn't bother me. If I were to do it again, since I may switch to a 9", I would stick with the 3rd gen offsets and keep the wheel lips closer to even.
- If you did use a 4th gen rear, you would have slightly better 28 spline axles factory, and the zexel 3 series carrier. Then you would only need the gear, install kit, pinion spacer and rear cover......
O-K, I got the old one apart. It has 13 teeth on the pinion and 40 on the ring. That works out to a 3.08:1 correct? The axels are 26 spline so I guess they are garbage. I can put any gears I want into this rear end housing right?
So long as they are compatible with whatever series carrier you have (2 or 3). I believe that carrier is a 2 series carrier. When you order the gears, it will specify what series the gears are compatible with.
All Right, I am confused. The carrier. Is that what you bolt the ring gear to or is the carrier what you put everything into when your done? Meaning, The housing is also called the carrier? I thought the carrier was the center section that contains the posi unit. Please clarify this as I was going to grab a used torsen with gears on ebay and plop it in my rear end housing.-Mike
Car: 1982 Trans-Am
You've got it right, the housing is just what everything goes into. The pumpkin, the shell, two tube sticking out make it a rear end.
The carrier is what you bolt the ring gear to, the center section, contains the posi unit.
Cool, That's what I thought. Thanks Sonix, Now I can go and spend money !!!
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
That Idea about buying a forth gen. rear is good. It would give me my centersection, gears and brakes. I can not use the axles because they are too wide correct?
You can use it, but youd have to get custom spacers, or something like that. Search for it, I see this topic come up all the time though.
So the axles are too wide, Spacers are not an option. Could I have the 4rth gen axles chopped and resplined? That would probably cost as much as a set of correct axles right? AAAAAAAHHHHHHHHHHHHH !!!!!!!
nothing is easy....
nothing is easy....
I'm not sure what it is that you need to get, but apparently they sell something that will make 3rd gen wheels fit nicely. Like I said, search, youll find the answer.
Received 1,664 Likes
Seriously, no "they" don't make anything of the kind. That would require what you might call a "negative spacer", such that when you put it in, it TAKES SPACE OUT, instead of PUTTING SPACE IN. Now I haven't been in EVERY place in this universe yet; but I haven't seen anything in my sorely limited travels yet, that looked like it would do that.
And no, you can't cut and re-weld the axles, without also cutting and re-welding the axle tubes. Not economically sensible.
The cure for the wheel problem on one of these cars with a 4th gen rear is either 4th gen or Corvette wheels.
About all you can do to the 10-bolts out of these cars (or the 4th gen ones for that matter, they're the same thing) is a good carrier (preferably NOT an Auburn); better axles, such as Superior, with both carrier and axles in the 28-spline size; new gears and bearings throughout; a solid pinion spacer; better yoke; welding the tubes to the center section all the way around; a girdle type cover; cap studs, instead of bolts; the triangulating braces; and synthetic fluid. You could throw in LCA reloc brackets for good measure, since if you're going to all taht other trouble and expense, you might as well make it as traction-tuneable as possible. And it still won't be all that strong.
Sorry, I thought I remembered there was some sort of conversion kit on the market for the 4th gen wheels, but I guess you are right, the only way to remedy it would be to get the 4th gen wheels.
Hey all! Here's were I'm at: Blasted the housing and welded the axle tubes. Painted, Home Depot has a hammered metal finish in a spray can- 5 Bucks !!! I scored a T/A rear cover on ebay, $90-That's more than I wanted to spend but I got it and it's new-DONE !!! Next up I will look for a 4rth gen rear with a Torsen and good gears AND disk brakes. Axles, Summit is selling their over stock of Superior axles for 28 spline 10 bolts for $109 a set. Screammin' deal but they are for 4rth gens only. I will shop around for a set of aftermarket axles or just source a set of stock 28 spline axles from a buddy. Will order a pinion spacer this weekend. Very close to being done, Am I missing anything?-Mike
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i'm in the same boat as you mike.
I have a pinion spacer (RAT-4111), Eaton 19599, lakewood gear lube, and a rebuild kit. I'm waiting for more cash to come in to buy a set of superior axles, motive 3.42s, and a diff cover.
I will be welding in a set of spohn lca brackets as well as the axle tubes, then i wanna paint it in por15 and hit it with a few coats of color. maybe a cast aluminum or flat black.
I just replaced the brake lines with a set from fine lines. will probably also freshen up the brakes and paint the drums while i'm back there. don't really have a need to upgrade to disks yet...but maybe if i come across a steal i may.
oh, I'd like to finish it off with a 23 or 24mm swaybar with polyurethane endlinks/bushings.
too bad summit wasn't overstocked w/ a set for 3rd gens. just my luck.
let me know if ya come across another diff cover for cheap. i don't care whose name is on it, haha.
brandon
brandon
I think you have the Borg Warner 9-BOLT and the FORD 9-inch mixed up?
You can get a BW 9 bolt for about $200 used that came stock in 3rd gens. ie bolt-in! They are very much stronger than the GM 10 Bolts and are a better built and engineered unit. I still recommend getting one of these to start from and doing exactly what you are doing to your 10 bolt. In the end you will have a much stronger rear. Guys in Australia are running the BW 9 bolts into the 9's regularly (with a spool)....food for thought! I'll even sell you new Motive 3.73's for it..
Problem with the BW 9 bolt is that parts are really hard to find and/or cost an arm and a leg to get. I was going to get a 9 bolt as I know of a couple being sold around my neck of the woods but heard about this 4thgen 10 bolt with all the mods done that I couldn't pass up. To each their own...
I have a 9-Bolt in my white IROC. The rear is great but parts are expensive and hard to find on the cheap. I am determined to build my 10-bolt cheap. Now I am looking for a used 4rth gen. rear-Kind of a one stop shop! I should get everything I need and be done. We will see though, Easier said than done.
Okay, Help me out here. I found a junkyard rear that has everything I need. SHOULD I grab the E-Brake cables? Will they work? The brakes will work right? I can bolt the 4rth gen brake set-up to my 3rdgen housing? AND should I grab the speedo gear out of the trans so my speedometer reads right?
GTA/Iroc wheels look ok with the 4th gen rear. They'll sit square with the wheel lip(look at my sig and you'll see why I know)
The early 4th gen brakes will "bolt-on" with some minor modification to the housing mount brackets. The later(LS1 era) discs will require more work, due to the internal park brake.
If the 4th gen you're getting the diff from has the same type trans then getting the speedo gears would make things easier for you. And yes, grab the e-brake cables. They have slightly different ends, but they will work in our "y".
A cheap donor 4th gen rear would deffinitely be a good idea. They're easy to find with the factory Zexel posi and 3.42 or sometimes 3.73 gears. Plus the later disc brakes are nice since you have drums. You can probably still sell the housing and the axles when you're done(not worth much, but anything beats throwing it away).
All right, Here is were I'm at:
I scored a rear out of a '92 Z-28 that has the discs on it. $250
3.42:1 gears off of Ebay $42
T/A performance girdle on Ebay $75
4rth gen rear, All new with Torsen. Cracked ring gear. No brakes but it has
the bearing spacer. $140
I think I can build a rear out of it and sell the rest to offset the cost so far.. give me a week or two.
Why does the Torsen have teeth around it's outer edge?-Mike
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
anti-lock brakes
That's the "tone ring" that makes a sensor put out pulses, one pulse per tooth, that tells the ABS how fast the rear end is turning.
That makes sense. It still will fit in a third gen. ten bolt housing right?
AFAIK yes.
I had the carrier out of about a 97 SLP rear in my car for a while; it was from before they went to the Zexel, it was an Auburn hi-perf, with the tone ring. That fit the 91 or so rear in my 83 car just fine.
