My GTA
Re: My GTA
Thanks guys!
Yep, 74U Flame Red Metallic
It really depends on the lighting. In direct sunlight like that, it has that kind of orangy rust color to it. If it's overcast, or at night, it has an almost purplish tint to it. It's a really cool color.
It came with the L98 and T-tops from the factory too.
I took some pics of the interior and engine bay today too: I need some new floor mats, and the engine could probably use a bit of detailing, but here they are anyway:
Re: My GTA
Simple Green, some different sized brushes, a hose, and a good part of an afternoon. It's an easy job, just very tedious. But now I REALLY need to give my engine a good cleaning because my radiator sprung a leak last night and spewed coolant everywhere. Damn plastic end tanks
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Re: My GTA
Looks very nice, I love your clean cross lace GTA wheels :P Mine are plagued with brake dust, damaged clear coat and unshininess :P
Re: My GTA
That car is in excellent condition.
9 of 10!
I want your interior. The engine would be nice too.
9 of 10!
Car: 1988 Camaro RS/1983 camaro z28
Engine: V8 305 L69
Axle/Gears: 2.73 posi
Re: My GTA
that is exactly how i want my t/a to look when im done, its already the same color, just need some gta's (which im working on), and to get rid of the horrible red interior(cant stand it!)
Car: 1989 Pontiac Firebird
Engine: 5.7 350 V8
Transmission: Automatic 700R4
Axle/Gears: Stock
Re: My GTA
Very nice man! Love the color and it looks very clean and original!
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
Re: My GTA
Beautiful car inside and out, great job on it. I assume it is not your daily driver. If it is, you get extra kudos from me.
Car: 1986 trans am
Engine: 305 5.0 tpi
Axle/Gears: 3.23 9 bolt rear end
Re: My GTA
nice ride man
i really like that color
yrs is in better shape then mine is
how much miles is on it
Re: My GTA
Since this thread is over 3 years old now, I figured I'd update with a few current pictures. Besides, I haven't whored it out in a while lol. The car now has 98,000 miles on it and I think it still looks pretty good for the most part. It's since been retired from daily driver status, but I still drive it every chance I get.
Car: 1989 Pontiac Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27:1
Re: My GTA
Beautiful car! I have the same car - same year - same color. Although, I'm hoping to be going gunmetal grey later this summer.
Re: My GTA
http://www.summitracing.com/parts/APR-400EU/
Oh yeah! not many people are a fan of the two on the left setup, but I really like it. And with full-length headers it sounds amazing.
It wasn't too bad. Took me a few weeks, but I would only fool with it an hour or two here and there after school/work. Cramming those headers in there was harder then the trans swap lol.
Can't go wrong with gunmetal man, that's an awesome color on these.
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
Re: My GTA
How'd you go about refinishing the lip? Amazing looking GTA by the way! So clean. How hard were the headers to install? I saw you said difficult, did you lift the motor at all?
Re: My GTA
Thanks! I used 200 grit sandpaper to strip the clear, then proceeded to uses 400, then 1000, then I wet sanded with 2000. Then I polished the hell out of it with Mother's aluminum polish. I didn't re-clearcoat them so they have to be polished about every other time I wash the car. Not too bad of a job though.
As for the headers, I just undid the engine mount on the side I was working on and jacked up the engine. I replaced the mounts at the same time, so it wasn't that big of a deal. If you're doing headers and still have the original mounts, this is a VERY good idea. The worst part of the install was re-routing a lot of wiring and protecting it from the heat of the headers. I thought I had everything tucked away and protected, only to start the car and smell burning plastic within a few seconds. This must have happened about 3 times lol.
Car: 92 T/A Convertible
Engine: 5.7 (L98)
Transmission: WC T-5
Axle/Gears: 3.27 LSD
Re: My GTA
Mike I'm about to do the T5 swap on a L98 on my 92 convertible t/a have you had any problems with it? Btw nice gta!
Car: 89 GTA
Engine: 5.7 TPI L98
Re: My GTA
The wheels really turned out amazing! I was thinking of doing the same to my wheels but two of the rims are extremly pitted, I wonder if sandpaper could fix it. Either way, I suppose it couldn't hurt to try.
The reason I ask about headers is because it's the next step on my GTA. Looking for a good type to go with. What kind are yours and would you reccomend them?
Lmfao @ the burning wiring. That's a quick sign that something is wrong. lol.
I also noticed you deleted the smog pump when you got the headers. Did you completley remove all of the equipment? How did you get to the AIR line bolt that runs to the cat and shares a bolt with the ground on the back of the pass side cylinder head? Also, do you remember the part # of the belt you went with to compensate for the smog delete? Sorry for all the questions, they're all things I want to do to mine and I figured it'd be best to ask someone who's already done it.
Amazing looking car man!
Re: My GTA
Cutting the hole in the firewall for the slave and in the trans tunnel for the shifter also require a lot of patience and precision. Measure twice, cut once certainly applies here! Besides that, no real issues. It's a pretty straightforward swap. Good luck with yours!
Re: My GTA
I'm running 255/50/16 all around. It's lowered a little bit. The pictures at the top from 2008 are before it was lowered and the more recent pics from this year are after. It's not a huge drop and I'd love to go lower, but my collectors are kinda close to the ground as it is.
Engine: 5.7 (L98)
Re: My GTA
Hey Mike I did it now my 92 base model firebird convertible V6 is now a 92 "GTA" L98 w/ a WC T5 convertible I'll post pics soon
Car: '70 LeMans
Engine: 383 Stroker Small Block
Transmission: Turbo 350
Re: My GTA
My 1st car was an '87 GTA. Same color but with flame red interior to match. God that was a beautiful car. I tear up when I see a flame red GTA cause I really miss it.
I vowed to own another GTA someday. Though I ended up getting a formula. Maybe someday I'll get one, lol. Nice ride.
