TAN Interior people!! Paint Match?
Car: 84 z28, 86 irocz
Engine: LS6, 305 TPI
Transmission: TH350, T56
Axle/Gears: 3.73, 4.10
Ok I have just a 86 iroc, it has Tan interior, My rear fender well plastic pieces are all faded, and nasty, So I got some other ones, but there gray, I need TAN! and I CANT find the matching paint, I ordered some from YearOne, And it was the wrong color, So They send my the only other color they say it could be, and its Way wrong. So Then I went to the local paint supplies, that sells SEM paint (the brand yearone sent me) and Bought the only other closest can, and its WRONG. has anyone repainted there tan plastics? i want Like 100% Correct, But I cant find anything.
help Please
help Please
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Re: TAN Interior people!! Paint Match?
I have the same problem. I'm going to paint all my interior plastics at the same time so they match. Probably not the answer you'd like to hear.
If anybody else has any ideas please chime in.
Well I have the 86 brochure and its called saddle. But I CANT find saddle paint.
Car: 1988 Camaro RS
Hey,
My interior is tan and the back panels are doing the same thing. I couldn't find any information on the color name but chances are you will have to paint all the plastic...which kind of sucks. However, all the colors will match and it will make the car look that much cleaner.
My question is how much would it cost to get paint for all the panels and whats the prep work for it.
Hey,
Well I got a color I wouldnt mind but it doesnt look good with the door panles, And just wash them good, and i bought this prep clear coat primer for plastics and it works good.
Car: 1988 Camaro RS
It seems the tan color name is hard to find. I'm wondering if talking to someone at a Chevy dealer would make it easier on you to find the exact color.
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
My 89 iroc has tan interior. Mine is called medium beechwood. They might of called it a different name in 86 and maybe the shade is different too. If you're trying to match the other panels with the paint they say is correct, you have to remember that most likely the rest of your panels and interior are probably faded and the paint is not going to match. Might have to paint all the panels.
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
The shades of tan changed depending on the year. Have you tried SEM# 15753? It's called light oak and matches some tan panels I have from the mid 80's.
Car: 2002 TT Corvette
Engine: 5.7L
wetsand them smooth and buff them out. they will have a smooth look to them then. I've done that before to restore color loss on plastics.
well I know for a fact, the piece that goes under the hatch isn't faded, nor is the kick panels and nothing matches.
mine are actually so faded and dyed up by the sun there like chalky.
Engine: 5.7L
yeah i know.. sand them down and get past the "chalky" layer... sand with like 320... then 400... 600... 800... 1000... 1500... and buff them out they will look awesome. you can make them look smooth too by sanding away all the rough textured finish.
But wont thay then be smooth? and not have the original grain look?
Engine: 5.7L
Hey guys. I have an 86 iroc and the interior is called "Light Saddle Tan". I know this because I purchased that color headliner from Hawks and it was color matching. I actually am looking for this paint too. Haven't really looked anywhere except on the net and couldnt find it...
Hawks may call it, that. I have the 86 catalog and the only tan is "saddle" some places even call it Light buckskin/saddle, because im looking for a headliner, But Iv actualy bought Light buckskin and its to light.
Car: 85 SC and 87 IROC Both T-Tops
Engine: 305 V8 H Code and TPI F Code
Transmission: 700R AT/OD and 5 Spd.
Axle/Gears: 7.625
For what its worth, decode your RPO Codes, and that will tell you what to look for and GM should have info for you.
AHHH great thought tan would be the cats a@# didn't know they had 4 different colors of tan.I tried the RPO code thing last night but all I got was a bunch of alien code crap so I didn't do something right
Axle/Gears: 7.625
The bottom line seems to be, copy your VIN and REPO codes to GM dealers and ask them to tell you what to get, and where if they are no longer able to supply.
Axle/Gears: 7.625
Here are my RPO codes for my 1987 IROC Z28 5spd, with A/C
AR9 AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
B34 B34 : COVERING, FRONT, FLOOR MATS, CARPETED INSERT
B35 B35 : COVERING, REAR, FLOOR MATS, CARPETED INSERT
62B 62B : TRIM COMBINATION, CLOTH, LT SADDLE (B)
The plastic color is a light tan, or light camel, again, go to your part, record the part number information, etc., contact your GM dealer.
Richard.
Richard.
Car: 89 Iroc Convertible
Im also looking for the 85-87 Light Saddle color paint.I have the sem paint chip chart and none of them seem to match up.
Car: 83 z/28
Engine: 305 4 barrel
i used this prouduct from ppg i had it color match to one of the parts that was not faded. it was a perfect match. Elastomeric Color System
Car: 83 z/28
try this https://buyat.ppg.com/refinishProduc...a-7899a59d93bc under basecoats
Found this on ebay.....What do you think?
http://cgi.ebay.com/ebaymotors/Chevy...Q5fAccessories
Awhile back I pulled a rear area carpet from an 86 camaro sport coupe and on the underside it has a paper tag attached that reads GM F Body LT Saddle.I believe it also has a part# but its packed away in the basement so I cant get at it right now to check
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
Has anyone attempted to do the heat gun method on our plastics? I saw on YouTube, there was a fella restoring interior and exterior plastic panels to original colors using a heat gun. Basically, the heat would melt the plastic just enough to get rid of the fade.
I never found anything like the 85-87 saddle color. I ended up using something else. And wasn't happy. And I still have the car.
Transmission: World Class T-5
Axle/Gears: BW 3.45
I need some too. I've bought a few different cans, and can't find an exact match for my '85. I was going to have some mixed up, but never got around to it.
Engine: 3.1 V6
Axle/Gears: No idea
i believe most people use PPG Dye to redo their plastics. you can take your interior color code and have them mix you up the color. i think you can get them at your local paint supply store. https://www.ppgpaints.com/home
Car: 84 Z28
Axle/Gears: 3.73 Torsen
I went through this a few years ago trying to match code 62 interior paint on my 87. There are multiple shades of code 62 in the paint books - dark, medium, light, which correspond to paint codes 62C or 62CN, 62B/62BN, and 62A/62AN. Code 62, sometimes called saddle, sometimes called camel, was used on Pontiacs, Chevy, Olds and Caddy from 85-87 and in 88 on Buick, Olds and Caddy only.
Further confusing matters, 62B as your interior code doesn't mean 62B or 62BN is the matching interior paint color. On a Camaro in 1985, 62B was the code for the standard cloth interior in saddle. 62C was the custom cloth interior, etc. There was also 62D, 62E, 62N, and 62R interior codes, but they are all the same color.
62A or 62AN should be the PAINT color code that matches the trim panels on a code 62x interior.
As a side note, it has long been a source of frustration for me trying find interior trim/restoration parts for the 87 GTA, because it seems like nobody realizes that the 87 GTA code 62 interior isn't the same as the 88-up code 66 Beechwood interiors. But I digress...
I ordered my paint in a spray can from these guys www.themotorcompany.com They don't have it on their web site, you have to call. And it isn't cheap - over $20 a can plus shipping. But you should be able to order it from any local automotive paint store as well. The original PPG number was 25230, but they'll likely have to cross reference that to something newer.
colton_carlson
03-08-2019 12:21 PM
hectre13
09-08-2015 03:38 PM
