$DA2 93 Vette LT-1 help needed...
Old Feb 11, 2010 | 01:36 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I have a couple of questions on the above..
First, where can I download the stock .bin for a '93 vette LT-1 / six-speed and what is the 4 letter file name for it?
Will VE master work on this .bin for get a head start on tweaking VE?
I have tunercat and the $DA2 def. file to view the .bin, but I having trouble locating a stock .bin
Will datamaster 8D be compatible to scan the car, beings they are both ODB1?
Any suggestions would be very much appreciated!
THanks!
Old Feb 11, 2010 | 08:51 AM
ULTM8Z's Avatar
Re: $DA2 93 Vette LT-1 help needed...
I have the $DA3 93 LT1 Camaro bin. If the ANHT vs AUJP L98 comparison holds into LT1 land, then my guess is that the Corvette has a more aggressive timing map, but not much else is different.
Old Feb 11, 2010 | 02:35 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I only have the def. file for 92-93 corvette ($DA2), so I'm not sure if the F-body Lt-1 .bin will work?
Still need the .bin name for the vette .bin and where to find it. Anyone?
Old Feb 11, 2010 | 10:07 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
i have a BAFL BIN, which is a 92 vette LT1 with a six speed...
if you PM me your e-mail address, i can send it.
Old Feb 11, 2010 | 11:19 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Is the BAFL .bin the same as the 93 vette .bin? Just wondering if there was a different .bin for 93?
PM sent...
Old Feb 11, 2010 | 11:22 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
if there was a difference in the BIN, the BCC would be different as well. there are exceptions to this, but they are few and far between.
Old Feb 11, 2010 | 11:30 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Is the one you sent bone stock or modded?
Old Feb 11, 2010 | 11:33 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
should be a stocker... if not, i didn't change it.
Old Feb 11, 2010 | 11:38 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Much appreciated!
What's the difference between the 93 F-body $DA3 and 93 Vette $DA2 ?
Will either .bins work with either ECM's?
Old Feb 11, 2010 | 11:40 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
i'm no expert when it comes to the DA masks, but from what i remember:
DA2 is the 92-93 vette LT1 mask
DA3 is the 93 F-body LT1 mask
there are slight differences in them, but they MAY be able to be run on the same ECM, not sure about that.
Old Feb 11, 2010 | 11:50 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Thank you sir!
I will give that a shot...
Old Feb 16, 2010 | 04:42 PM
stinger32's Avatar
Car: Trans am GTA 1990
Engine: 383
Transmission: TH700R4
Axle/Gears: stock
1bad91Z--> Maby this site can be any help for you. http://www.bfranker.badz28.com/LT1Edit/LT1files.htm
Old Feb 16, 2010 | 11:38 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Saar sent me BAFL. It matched the PROM code on the PROM in the factory 93 vette's ECM (LT-1 / six-speed). Will be working on the car this weekend, will let you guys know how it goes. It's a modded 355 LT-1, ported heads, cc306 cam, 30# injectors, headers etc...
Should be fun!
Old Feb 16, 2010 | 11:39 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I'm wondering if VE master will work with the BAFL .bin ???
Anyone try it before?
Old Feb 17, 2010 | 02:01 AM
stinger32's Avatar
Engine: 383
Axle/Gears: stock
Does any1 have an bdlc bin for 93 lt1 camaro/firebird
Old Feb 22, 2010 | 12:17 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Is VEmaster compatible with Datamaster$DA (for 92-93 Y-body) ?????
or is there a different version of VEmaster for $DA2 ?
Old Feb 22, 2010 | 09:19 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Hope this helps someone....
I did find out that VEmaster will work with Datamaster $DA2.
Old Apr 10, 2010 | 10:38 AM
scotth48's Avatar
I am getting ready to do some programing on my '93 Ruby and was looking for a stock for the Lt1 SIX SPEED BAFL memcal. I just got the Moates ADUL1 kit and Tunerpro RT software. I did a search and found your post. Thanks for any of your help. My goal is to boost my mileage, so if you got some info on what changes I should make that would be appreciated too.
Scott Hansen
Charlotte, MI
269-209-2547 work cell
517-213-1242 cell
scott_hansenfamilyfarms@yahoo.com
Thanks,
Scott
Old Apr 12, 2010 | 11:00 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
You could use VEmaster to help out your gas mileage from 0 -3000 rpms. Do a couple of searches on VEmaster, there are some good threads on howto use it.
Old Yesterday | 10:17 PM
Ruby2's Avatar
Hello, I know this post is in the way back machine, but I'm restoring a 1993 Anniversary car and would be most grateful to get the BAFL .bin to load into TunerPro RT.
Thank you.
s2exread@gmail.com
Old Yesterday | 10:54 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
https://gearhead-efi.com/gearhead-efi/bin/BAFL.BIN
FormulasOnly
Jul 23, 2018 08:47 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
BDR
Nov 7, 2015 03:05 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
R13_Braz
Sep 18, 2015 05:00 PM
