Members post your RPO codes!
Car: 85 Z28 Vert
Engine: LG4 ENGINE 5.0 4BBL
Transmission: 700R 4SPD
Axle/Gears: 3:08
I hope this will be ok with the admins but I wanted to find a thread JUST for members RPO codes instead of just several posts scattered on the site.
I know it will make lengthy posts but that should be ok. I am very interested in this and interested in the discussion it will create by doing this.
Again, I hope this is ok.
I will start with mine, then you post your codes. Also post what Year, make and model of third gen, and any other pertinent info about it and if your original owner or not. Post any pics of your car or RPO sticker as well but please try your best to keep the thread on topic. Here goes Mine:
Mine is a 1985 Z28. My family is second owner to the car.
My Codes:
NK3 STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
VAN ASSEMBLY PLANT, VAN NUYS, CA
69L SECONDARY COLOR, EXTERIOR, ROOTBEER MET (92)
B34 COVERING, FRT FLOOR MATS CARPETED INSERT
D88 DECAL, STRIPE, SPORT
N33 STEERING COLUMN, TILT TYPE
VK3 LICENSE PLATE FRT MOUNTING PKG
69U PRIMARY COLOR, EXTERIOR, MED BEECHWOOD MET (91)
B35 COVERING, REAR, FLOOR MATS CARPETED INSERT
E5Z SPEEDOMETER ADAPTER (DELETE)
N90 WHEEL, 15 X 7 ALUMINUM CAST, 4.75 INCH BOLT CIRCLE
V73 ANTENNA, FIXED
7ZX SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
B84 ORNAMENTATION, EXTR MLDG, BODY SIDE
E7Z KEY, SPEEDOMETER (DELETE)
QYH TIRE, ALL, P215/65R 15N WOL R/PE ST TL HWY
YE3 CONVENIENCE PKG, DECOR LEVEL #3, HIGH TRIM
8NL SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
B9K MOULDING DOOR EDGE GUARD
E9Z SPEEDOMETER KEY (DELETE)
TR9 LAMP, GROUP
YR2 SEAT FRT, CUSTOM
9NL COMPUTER SELECTED REAR RIGHTHAND SPRING
B94 FENDER EMBLEM, Z28
GE8 FLEET INCENTIVE RYERSON-TULL (C/G/H/U/W-TRK CK)
T63 ALARM, HEADLAMPS ON WARNING SYSTEM
YS2 REAR SEAT, DELUXE
92P WHEEL COLOR GOLD
B97 ORNAMENTATION, EXTR MLDG, LOWER ACCENT
GE9 FLEET INCENTIVE AMERICAN AXLE & MANUFACTURING (F-TRK CKGMLST)
T93 STOP LAMP, SMOKED
YT1 BUILD UP DR QTR
CD4 WIPER SYSTEM WINSHIELD, PULSE
GU4 AXLE REAR, 3.08 RATIO
UE8 CLOCK, ELECTRIC, DIGITAL
YT9 OPTION PACKAGE, FISHER FURNISHED PARTS
J50 BRAKE SYSTEM, POWER
UM6 RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS
Z28 MERCHANDISED PKG, SPECIAL PERFORMANCE
C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
K34 CRUISE CONTROL, AUTOMATIC, ELECTRONIC
UP8 STEREO RADIO INSTALLMENT PROVISIONS
1AY Stock Orders Processing Option (DEALER ORDERED CAR)
CODES OF MINE THAT WERE HARD TO FIND:
D6J SPEEDO GEAR
My Codes:
V73 ANTENNA, FIXED
TR9 LAMP, GROUP
YT1 BUILD UP DR QTR
D6J SPEEDO GEAR
Car: 85 Z28 Vert
Axle/Gears: 3:08
Re: Members post your RPO codes!
What exactly is 8NL SPRING, COMPUTER SELECTED, REAR, RIGHT HAND,
7ZX SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND, E5Z SPEEDOMETER ADAPTER (DELETE), E9Z SPEEDOMETER KEY (DELETE), YT1 BUILD UP DR QTR ?
I think most of the are self explanatory.
87 IROC:
AC3: ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AG9: ADJUSTER, SEAT, POWER, 6 WAY
AR9: SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3: LOCK CONTROL, SIDE DR, ELEC
A01: WINDOW, TINTED, ALL SHADED, W/S
A31: WINDOW, POWER OPERATED, SIDE
A90: LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
B18: ORNAMENTATION, INTR, DELUX
B2L: PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
B3W: ADVANCE PRICE SHEET
B34: COVERING, FRT FLOOR MATS CARPETED INSERT
B35: COVERING, REAR, FLOOR MATS CARPETED INSERT
B4Z: IROC PACKAGE
B84: ORNAMENTATION, EXTR MLDG, BODY SIDE
B94: FENDER EMBLEM, Z28
B97: ORNAMENTATION, EXTR MLDG, LOWER ACCENT
CD4: WIPER SYSTEM WINDSHIELD, PULSE
C60: HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DD8: MIRROR I/S, R/V, LT SENSITIVE
DG7: MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
DK6: CONSOLE ROOF, INTERIOR
D08: PAINT, HIGH GLOSS FINISH
D34: MIRROR, VISOR VANITY
D42: SHADE, RR COMPT SECURITY
D6M: GEAR, SPEEDO DRIVEN
D80: SPOILER, RR END PNL
D88: DECAL, STRIPE, SPORT
E5Z: SPEEDOMETER ADAPTER (DELETE)
E7Z: KEY, SPEEDOMETER (DELETE)
E9Z: SPEEDOMETER KEY (DELETE)
FE2: SUSPENSION SYSTEM, RIDE HANDLING
GW6: AXLE REAR, 3.27 RATIO
G80: AXLE POSITRACTION, LIMITED SLIP
J65: BRAKE SYSTEM, PWR, FRT & RR DISC
KC4: COOLING SYSTEM, ENG OIL
K34: CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K68: GENERATOR,105 AMP
L98: 5.7 LITER V8 TPI ENGINE
MD8: TRANSMISSION, AUTO 4 SPD, THM 700 R4
MXO: MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5: EMISSION SYSTEM, FEDERAL, TIER O
NOD: ASSEMBLY PLANT, NORWOOD, OHIO
NP5: LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
N33: STEERING COLUMN, TILT TYPE
N65: WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
N96: WHEEL, 16 X 8, CAST ALUMINUM
PB4: LOCK CONTROL, WHEEL
P20: HUBCAPS, WHEEL, STYLED
QDZ: TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
TR9: LAMP, GROUP
TT4: HEADLAMPS, HALOGEN, 4
T93: TAIL & STOP LAMP, SMOKED
T96: LAMP, FOG
UQ1: RADIO PROVISIONS, FOR STEREO
UX1: RADIO, AM/FM STEREO CASSETTE EQUALIZER
U21: CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U25: LAMP, INTR, RR COMPT, COURTESY
U26: LAMP, INTR, ENG COMPT, COURTESY
U29: LAMP, INTR I/P, COURTESY
U79: SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VK3: LICENSE PLATE, FRT MOUNTING PKG
V73: ANTENNA, FIXED
YR1: SEAT,FRT CUSTOM
YS1: SEAT,RR CUST
YT1: BUILD UP DR & QTR
YT9: OPTION PACKAGE, FISHER FURNISHED PARTS
Z28: MERCHANDISED PKG, SPECIAL PERFORMANCE
1AZ: CUSTOMER ORDERED
1HV: COMPONENTS OF IROC-Z PERFORMANCE PKG(CHEV)
1SC: PACKAGE, OPTION 03
15P: WHEEL COLOR SILVER METALLIC (91)
6ZX: SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZX: SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NL: SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
81Q: MOLDING COLOR, BRIGHT RED (91)
81U: PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
82C: TRIM COMBINATION, CLOTH, MED DK GRAY (C) (91)
82I: INTERIOR TRIM, MED DK GRAY (91)
829: SEAT BELT COLOR, MED DK GRAY (91)
86A: STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
9NL: COMPUTER SELECTED REAR RIGHTHAND SPRING
88 IROC:
B6Q: DECAL PACKAGE, 02
C41: HVAC SYSTEM, HEATER OUTSIDE AIR, WITH FAN
C49: DEFOGGER, RR WINDOW, ELECTRIC
C95: LAMP, INTR, ROOF, COURTESY AND DUAL READING
D35: MIRROR, OUTSIDE REAR VIEW
D7J: GEAR, SPEEDO DRIVEN
E7Z: SENSOR VEH SPD (DELETE)
GM3: AXLE REAR, 3.45 RATIO
G92: AXLE REAR RATIO, PERFORMANCE
LB9: ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MK6: TRANSMISSION, MAN 5 SPD, B0RG WARNER, 2.95 1ST, O/D
MM5: MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
TR9: LAMP, GROUP
T96: LAMP, FOG
UM6: RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
VAN: ASSEMBLY PLANT, VAN NUYS, CA
V73: ANTENNA, FIXED
WW1: APPEARANCE PACKAGE(WHITE), AERO #l
W62: ORNAMENTATION, AERO PACKAGE
X06: CANADIAN GROUP
Z31: ADVANCE PRICE SHEET
Z49: EXPORT, CANADIAN MODIF MANDATORY BASE EOUIP
40U: PRIMARY COLOR, EXTERIOR, WHITE
6DB: SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7DB: SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
82B: TRIM COMBINATION, CLOTH, MED DK GRAY
90A: STRIPE COLOR, ACCENT, TWO TONE, SILVER/YELLOW
B4Z: IROC PACKAGE
TR9: LAMP, GROUP
T96: LAMP, FOG
V73: ANTENNA, FIXED
YS1: SEAT,RR CUST
88 IROC:
TR9: LAMP, GROUP
T96: LAMP, FOG
V73: ANTENNA, FIXED
X06: CANADIAN GROUP
'87 GTA, to my knowledge I'm the third owner. No good pics yet, it's currently at the body shop in primer.
AAA, AH3, AK1, AM9, AQ9, AU3, A01, A31, A90, BV3, BY4, B2L, B20,
B34, B35, B84, B87, B94, B97, CD4, C49, C60, DD8, DG7, DK6, D3Y,
D34, D81, D9B, E5Z, E9Z, FE2, GW6, G80, J65, KC4, K34, K68, L98,
MD8, MXO, NA5, NP5, N33, N64, PB4, PW7, QDZ, TR9, T93, T96, UF6,
UQ1, UT1, UT4, U21, U25, U29, U66, U75, VAN, V73, WS4, WS6, WW6,
W62, W63, YS1, YT1, Y19, Y84, 1HV, 52P, 6ZX, 7ZX, 72D, 72I, 729,
74Q, 74U, 8NL, 9NL
For some reason Y19 and 1HV don't show up on the decoder.
74Q, 74U, 8NL, 9NL
Car: 1986 Trans Am
Engine: LG4 305 carb
Transmission: auto 700R4
Axle/Gears: 2.73 open
1HV is the Iroc RPO. My trans am has the speedo delete RPOs also (E5Z E9Z).
~Matt
~Matt
Car: 85 Z28 Vert
Axle/Gears: 3:08
im a dumb butt
Car: 85 Z28 Vert
Axle/Gears: 3:08
Neet to see the different ratios between the two years.
My 85 shows the GU4 AXLE REAR, 3.08 RATIO and its a Z, but not IROC Z..
Who is the rear end expert around here? What was factory standard Option for BOTH IROC Z and Z 28 for rear end gears? I did not find a whole lot of info about in my white book and Yes I at least looked. LOL!
Anyone?
Twin Turbo, do you know if you ordered both of these ratios for your cars or where they that way when you got the car?
Anyone?
Anyone?
Car: 85 Z28 Vert
Axle/Gears: 3:08
Bought the cars used, not new. Don't know what was ordered. My cars have 9 bolt rears, not 10 bolts. J65s too, both of them. The 88 lists G92: AXLE REAR RATIO, PERFORMANCE but I think the 87 has that too but it simply didn't appear in the RPO codes in 87. 87 is a weird year when it comes to certain RPOs
But I stand to be corrected.
Car: 85 Z28 Vert
Axle/Gears: 3:08
Im trying to get someone to answer that too.
Are these E5Z: SPEEDOMETER ADAPTER (DELETE)
standard Options too? Are we talking only Z28's or Camaros and firebirds' too?
Ill gander at the white board and do some searching on this site as well. I willing to bet it has been brought up before now.
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Anyone?
Anyone?
https://www.thirdgen.org/1985-chevy-camaro
Car: 85 Z28 Vert
Axle/Gears: 3:08
Did you look in the Thirdgen Camaro Tech Data section under "1985 Chevrolet Camaro Drivetrain List"?
Axle/Gears: 3.08
No problem.
Regarding RPO codes E5Z, E7Z & E9Z . . . my '89 IrocZ has them all as well.
PS . . . some other sites list those as . . .
E5Z Speedometer Gears Less Adapter
E9Y Vehicle Speed Sensor
E9Z Speedo Gears Less Keys
Still not a great help.
PS;PS . . . over at "Oldpower.com" a post describes it as such . . . E5Z- LESS SPEEDO ADAPTOR. Exactly that. You needed no speedo correction adapter box to make the speedo work properly. Most have no speed sensor either, which is E7Z.
Car: 1986 Trans Am
Sorry, I'll be more specific. 1HV is the components of the IROC-Z package.
My Trans Am has only E5Z and E9Z so I assume I have a speed sensor because I don't have E7Z.
~Matt
~Matt
Car: 85 Z28 Vert
Axle/Gears: 3:08
No problem.
Car: 85 Z28 Vert
Axle/Gears: 3:08
Somethings not right. I meant to ask this before now but I missed it somehow.
(Notice my dumb butt thread I edited) I still stand to be a dumb but! LOL!
Car: 85 Z28 Vert
Axle/Gears: 3:08
For 87 GTA 1HV is ALSO : COMPONENTS OF WS4 TRANS AM OPTION.
I am still looking for Y19 for 80schild 87 GTA...
Car: 85 Z28 Vert
Axle/Gears: 3:08
Im gonna go out on a limb here and see how close I can get..
80schild, not knowing anything about your 87 GTA, is it by chance either factory silver or have/had silver ground effects/Mouldings?
Car: 1986 Trans Am
All GTAs had body colored moldings.
1HV must be an equipment code for the items that IROCs and WS4 Trans Ams have in common.
~Matt
~Matt
Car: 85 Z28 Vert
Axle/Gears: 3:08
Y19 for 66-72 olds is Molding, Body Side Lower
for 76-81 Firebird it is MOLDING,BODY SI LWR.
So, I doubt it has actually changed that much since it probably pertains to some type of molding. I misread the interpretation of SILWR to be silver, so thats why I asked about color. Anyone find anything else on Y19 for his GTA?
Axle/Gears: 3.08
As for my '89 IrocZ, it has neither RPO 1HV (or possibly IHV should it have been misread). Maybe it applies to older IrocZ's when RPO B4Z was needed due to the seperate Z28.
Car: 85 Z28 Vert
Axle/Gears: 3:08
Car: 1987 IROC
Engine: 5.7 TPI
http://www.nastyz28.com/gm-rpo-codes/
According to this site, RPO 1HV is either:
Components of IROC-Z Performance Package
Components of WS4 Trans-Am Option
Here's my RPOs
AC3 AG9 AM9 AR9 AU3 A01 A31 A90 B18 B2L B34 B35 B4Z B48
B84 B94 B97 CC1 CD4 C49 C60 DD8 DG7 DK6 D08 D27 D34 D6M
D80 D88 E5Z E7Z E9Z FE2 GW6 G80 J65 KC4 K34 K68 L98 MD8
MX0 NA5 NOD NP5 N33 N64 N96 PB4 P20 QDZ TR9 TT4 T93 T96
UQ1 UQ4 UU8 U21 U25 U26 U29 U75 VK3 V73 YR1 YS1 YT1 YT9
Z28 1AZ 1HV 1SC 11Q 15P 40U 6ZX 7ZX 8NL 821 822 829 86A
9NL
There are a couple mystery codes in here. At least to me, anyway. For some reason there is U75 power antenna and V73 fixed antenna. Another is 86A stripe color red/gunmetal. The car is white with med. dark gray interior and gray leather seats, so I don't know where the red comes into play.
Here's my RPOs
9NL
Car: 1986 Trans Am
My 86 Trans Am doesn't have 1HV, however it is also not a WS6. The 1HV may include something like the WS6 sway bars or shocks and struts. I have U75 and V73 as well. My RPOs:
AAA AK1 AM9 AR9 AU3 A01 A31 A90 BS1 BV3 B20 B34 B35 B48 B67 B84 B87 CC1 CD4 C49 C60 DE1 DK6 D14 D27 D3W D35 D80 D88 D9A E5Z E9Z GU2 J50 K22 K34 LG4 MD8 MX0 NA5 NK3 NOD N24 N33 PB4 QYH TR9 T93 T96 UF6 UP8 UT1 UX1 U21 U25 U29 U66 U75 VK3 V73 WS1 WS4 WW5 W62 YR1 YS1 YT1 YT9 19Q 6ZW 60P 62C 62I 629
WA - U8757
~Matt
WA - U8757
~Matt
Car: 2003 BMW E46 M3 Vert
Engine: 3.2 I6 M power 333 h.p.
Transmission: SMG 6 speed
Axle/Gears: 3.62 posi
Here is my 85 IROC with out 1HV.
Car: 85 Z28 Vert
Axle/Gears: 3:08
I think it is odd we have not seen the 1HV actually listed on anyone's IROC-Z
and only on 1 Trans Am.....and what the heck does it actually physically pertain to anyway? No one has said.. My guess its a sway bar or something similar on suspension.
Lest I missed something.....
Car: 85 Z28 Vert
Axle/Gears: 3:08
Look up posts that have my buildsheet on it. It shows 1HV and then says B4Z for the description. Whatever that is supposed to mean!!
Here are mine - 1991 Z28 convertible.
It's not perfectly clear so i may have errors.
AC3 AJ3 AR9 AU3 A31 B34 B35 B84 C60 DG7 D34 D5V DM8 E5Z E92 F41 GU4 G80 IPB J41 K34 K68 LB9 MM5 M19 NA5 NP5 N96 QMT R6V T96 UB3 UN6 UQ1 UX6 VAN V73 Z28 1AA 1AZ 15D 17P 190 41U 6XT 66B 66I 669 7XT 8NT 9NL
I can't open the RPO code page to find out what these mean.
Twin_Turbo, your 1988 Iroc doesn't have B84 or B9K? So you don't have the body side protective moldings on the front fender,door, and back quarter panels? This is really unusual for a 1988 Iroc. I haven't seen any without these on 1988 Irocs. I have on earlier years.
Car: 85 Z28 Vert
Axle/Gears: 3:08
T-FATTY:
AC3 ADJUSTER, FRT ST, POWER, 6 WAY, BKT DRIVER
AJ3 RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AR9 SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 LOCK CONTROL, SIDE DR, ELEC
A31 WINDOW, POWER OPERATED, SIDE
DG7 MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
D34 MIRROR, VISOR VANITY
D5V GEAR, SPEEDO DRIVEN
DM8 *CANT FIND*
E5Z SPEEDOMETER GEARS LESS ADAPTOR
E92 *CANT FIND*
F41 SUSPENSION SYSTEM, FRT, RR, FIRM RIDE, HANDLING
G80 AXLE POSITRACTION, LIMITED SLIP
IPB *CANT FIND*
J41 BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON
K34 CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K68 GENERATOR, 105 AMP
LB9 ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MM5 MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
M19 *CANT FIND*
NA5 EMISSION SYSTEM, FEDERAL, TIER O
NP5 LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
N96 WHEEL, 16 X 8, CAST ALUMINUM
QMT TIRE ALL, P235/55R16/N BL R/PE ST TL AL2
R6V CONTROL , SALES ITEM NO. 21R8T
T96 LAMP, FOG
UB3 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH, TRIP ODOM
UN6 RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
UQ1 RADIO PROVISIONS, FOR STEREO
UX6 SPEAKER SYSTEM, FRT DUAL
V73 ANTENNA, FIXED
1AA SALES INCENTIVE RETAIL AMENITIES DELETE
1AZ CUSTOMER ORDERED
15D TRIM COMBINATION, CLOTH, MED SLATE GRAY (D) (91)
17P WHEEL COLOR, SILVER (91)
190 *CANT FIND*
41U PRIMARY COLOR, EXTERIOR, BLACK
6XT SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
66B TRIM COMBINATION, CLOTH, MED BEECHWOOD (B)
66I INTERIOR TRIM, MED BEECHWOOD (91)
669 SEAT BELT COLOR, MED BEECHWOOD (9) (91)
7XT SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NT *CANT FIND*
9NL COMPUTER SELECTED, REAR RIGHTHAND SPRING
NEED TO FIND THE FOLLOWING CODES:
DM8
E92
IPB
M19
190
8NT
It's an unusual car altogether, look at the RPO list, it has a lot of deletes and all of the performance options yet it's not a 1LE. It only has power windows, no power mirrors, no power locks, no power seats, no AC..it's bare bones. Has 5 speed, LB9 high output (5500 redline), 9 bolt axle w/ perf ratio, J65 discs.
Look at the redline and metric gauges, even the oil pressure is in Kilo Pacals. odo is km not miles.
This is a weird car and it's in pristine condition with onl 50K on the odo. It's completely original and unmolested. The only issue is the exhaust is shot so I'm replacing it with the stainless edelbrock system that came off the 87 and keeping the stock tip sections.
Car: 1986 Trans Am
Twin Turbo:
You have the metric gauges because the RPOs show X06 and Z49. It was a Canadian car.
~Matt
~Matt
Car: 1986 Trans Am
Oh ok sorry. Didn't all 1988 LB9s have the 5500rpm redline though?
1985 IROC LB9,MXO,GU6,G80 J65
Car: 88 GTA
Engine: 5.7L 350
88 Trans AM GTA:
Was veru excited when I found the sticker in the bottom of the hatch area....pluggin in the codes was kinda like going back in time.
Thirdgen.org -- RPO Decoder
8NL: SPRING, COMPUTER SELECTED, REAR, RIGHT HAND 7ZX: SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
669: SEAT BELT COLOR, MED BEECHWOOD (9) (91)
66I: INTERIOR TRIM, MED BEECHWOOD (91)
66D: TRIM COMBINATION, CLOTH, MED BEECHWOOD (D)
52P: WHEEL COLOR, GOLD MET (91)
Y84: MERCHANDISED PKG, GTA, TRANS AM
YS1: SEAT,RR CUST W62: ORNAMENTATION, AERO PACKAGE
WW8: APPEARANCE PACKAGE(BRIGHT RED), AERO #8
WS6: PERFORMANCE PACKAGE, SPECIAL
WS4: MODEL CONVERSION, TRANS AM
V73: ANTENNA, FIXED
U75: ANTENNA, POWER, RADIO
U66: SPEAKER SYSTEM, 4, DUAL FRT DASH MTD, DUAL EXTD RGE
U52: CLUSTER INST, ELECTRONIC
UW1: DIAGNOSTIC SYSTEM
UT4: RADIO, AM/FM-ST CASS, AUTO NR, TOUCH CONTROL, STEERING WHL CONTROL
UT1: TONE GENERATOR, WARNING
UK3: ELECTRONIC SYSTEM, ACCESSORY CONT
UF6: LAMP, INTR, CONSOLE, COURTESY
UA6: THEFT DETERENT SYS
T96: LAMP, FOG
TR9: LAMP, GROUP QDZ: TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4 PW7: WHEEL, 16 X 8, ALUMINUM, DIAMOND SPOKE
N64: WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
NK4: STEERING WHEEL, SPORT LEATHER W/ RADIO CONTROLS
JG1: SHAFT, PROP, ALUMINUM
D98: STRIPE, ACCENT
D81: SPOILER, RR, AERO WING
D3Y: GEAR, SPEEDO DRIVEN
C67: HVAC SYSTEM, AIR CONDITIONER FRT ELECTRONIC CONTROLS
CD2: INDICATOR, WSWA JAR FLUID B
84: ORNAMENTATION, EXTR MLDG, B0DY SIDE
B67: CONTAINER, RADI0 CASSETTE TAPES
B20: ORNAMENTATION, INTR, LUXURY
BY4: ORNAMENTATION, INTR, INST PANEL, NAME PLATE
BV3: ORNAMENTATION, INTR, I/P, BLACK
BC8: ORNAMENTATION, INTR, DR MAP POCKETS
AQ9: SEAT, FRT PASS A DRIV, RECL
AM9: SEAT, RR, SPLIT, BACK, FLDG
AK1: DELUXE BELT AND SHOULDER HARNESS
AAA: 4-WAY MANUAL SEAT ADJUSTER
V73: ANTENNA, FIXED
T96: LAMP, FOG
D98: STRIPE, ACCENT
Car: 89 camaro RS
where is it located under the hatch, because mine are not up front anymore
i would definatly like to look mine up
Car: 88 GTA
Engine: 5.7L 350
