help with removing speedometer and replacing dash lights
Old 01-12-2012, 05:15 PM
sassylady's Avatar
Car: 89 Camaro
Hi guys,
I am trying to change the dash lights and add white face gauges in my 89 camaro. I am stuck! (my baby is all torn up and I'm freaking out ova here!!!) I can't remove the speedometer gauge and I am clueless on how to install the new lights. Do I have to remove the white plastic piece that holds the gauges for light installation or it there an easier way? I gonna add a pic of where I'm at in the process so u can better advice me. All advice is appreciated thanks in advance for the help!
Attached Thumbnails help with removing speedometer and replacing dash lights-dash-help.jpg
Old 01-12-2012, 10:14 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: help with removing speedometer and replacing dash lights
You will have to remove the cluster to change the dash lights. Fairly easy to do. Just a matter of removing the faceplate, disconnecting the speedo cable and removing the nuts that bolt the cluster to the dash. Little tricky to get the cluster out with the steering wheel in the way but tilt it down and the cluster will come out. With the cluster out, you will see all the sockets that the bulbs are in. Twist the sockets and they come right out to change the bulbs.
Old 01-12-2012, 11:01 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Hardest part is disconnecting the speedo cable.
Old 01-13-2012, 06:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Removal instructions (as well as a how-to to repair the trip odometer) below:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old 01-24-2012, 01:19 PM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
Transmission: T56 stage II
Axle/Gears: S60 4:10's
JamesC
Follow JamesC's thread. Lots of good info. I've done mine so much lately, I can do it in like 20 minutes start to finish. Long Flat-headed screwdriver and a headlamp works great to detach the clip.
Old 01-16-2017, 04:17 PM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
Here is how to take out the cable
Old 10-19-2017, 02:59 AM
Biggd4355's Avatar
My high beam indicator bulb inside the speedometer is out. Have you ever replaced that bulb?
Old 10-19-2017, 03:00 AM
Biggd4355's Avatar
the bulb for high beam inside my speedometer has gone out. Has anyone ever changed out that bulb?
Old 10-19-2017, 05:00 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
I haven't changed mine because it was good. however it is a type 74 bulb.
Old 10-21-2017, 05:29 PM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Why not just take off the dash pad and reach down behind the cluster
and remove the bulbs and holders from the rear?
Old 09-21-2018, 03:08 PM
88BlackFormula's Avatar
Engine: 305 TBI, Hedman shorties
Axle/Gears: 3.23, non-posi drum
Does that actually work? Seems a hell of a lot easier.
tnrednneck
08-13-2015 08:57 AM
Omega
08-10-2015 12:46 PM
marcusaw
08-10-2015 08:13 AM
3rdgenparts
08-08-2015 07:09 PM
apie2546
08-08-2015 07:12 AM
Quick Reply: help with removing speedometer and replacing dash lights
