LS1 Swap/ Now I can't figure out the windshield wiper motor wiring
Old 11-21-2013, 03:51 PM
admathi's Avatar
I was wondering if anyone knew of a definitive solution to wiring up the stock windshield wiper motor after an LS1 swap. I have an 1986 IROC. I did an LS1/4l60e, dash, fuel tank, wiring harness, interior swap from a 99 TA. I did a search on here and saw someone suggested switching the windshield wiper motor switch (the part in the steering column that the multi-function lever connects to) to one from an IROC. I never saw for sure if this would work. I was wondering if anyone had experience or suggestions for wiring up the stock 86 wiper motor to the newer wiring harness. Thanks.
Old 11-21-2013, 05:06 PM
Pocket's Avatar
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Re: LS1 Swap/ Now I can't figure out the windshield wiper motor wiring
If you've got all the 4th gen wiring, why not switch to a later 3rd gen wiper and use that directly?
Old 11-21-2013, 05:09 PM
UR50SLO's Avatar
Car: 86 Turbo Camaro
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
I used a 89 Nissan Maxima Windshield wiper motor... Wired it in just to run on the low setting but it takes up NO room and is a direct bolt in .... except for one bolt hole you need to drill and put bolt/nut on.
~Scott
Old 11-21-2013, 05:41 PM
Pocket's Avatar
Car: 92 Firebird
O-rly
Would have LOVED to know that before I rebuilt my engine mounts moving my whole powertain forward to clear my wiper
Old 11-22-2013, 05:32 AM
UR50SLO's Avatar
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
I'm not sure if you can see it very well in this video but I can also take some pictures of it at home this weekend if you need me to...
It bolts right in pretty much and is 1/4 of the size of that monster GM put in there...
My V6 would not fit in there!!! I doubt this LS would have fit with stock wiper motor.
Why did they make it so huge? Have to wipe away 12lb snow? Lol
Old 11-22-2013, 08:40 AM
admathi's Avatar
Thanks, guys. Sounds like both those ideas are easy enough. I truly appreciate your responses.
-Adam
Old 11-22-2013, 08:48 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
~Scott
Interesting... Why did you wire it only on low? Is it possible to install with original thirdgen wiring and have intermittent along with lo/hi settings?
I used a 4th gen washer bottle, so I was able to remove the pump, which bought a decent amount of room back there. I ran power wires for the 4th gen pump up into the original pump cavity, and I planned to shave the housing cover and finish it off that way. But this nissan idea has me curious.
J.
Old 11-22-2013, 10:04 AM
92purplehaze's Avatar
Car: 90 IROC-Z
Transmission: M6
Axle/Gears: 9" spooled 3.70
I have A 4th gen column and a functioning 3rd gen wiper motor. The stick in the column needs to be changed to a 3rd gen.
Old 11-22-2013, 05:13 PM
Pocket's Avatar
Car: 92 Firebird
What a difference
Nissan Maxima
Late model 3rd gen
Looks like it would have cleared my fuel rail too. Gahhhhh
Think Ill swap it anyways so I can leave the wiper attached when swapping clutches. Ill look into the wiring. Thanks Scott
Old 01-22-2014, 06:30 PM
fonzie85's Avatar
Car: 89 IROCZ
Engine: Forged 347 LS1
Transmission: Built 4L60E with 4k stall
Axle/Gears: 4th gen w/ 3.42 gears
Do any of you guys have a wiring diagram of how you wired in the maxima wiper motor?
Old 01-22-2014, 07:07 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
This is awesome......the massive OEM wiper motor was driving me nuts!!
Old 01-23-2014, 05:38 PM
UR50SLO's Avatar
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Honestly It was a freak accident... Lol...
I had a 89 Maxima that was my daily driver... I put a stock GN turbo on it for fun.. then chaned it to a TA49 which is one above that... stock GN IC with in/outlet changed... Drove it from 181,000mi when I turbod it to 245,000 it went 13.40@108mph on 11psi with a 2.4 60'... Got 24mpg in town and 31mpg highway. Was a fun 1000.00 car.
ANYWAY... had a parts car here and looked at the wiper motor and said.. humm...
so Put it on fire wall and lined it up. Soooooo Close!
For wires... Well.. I turned my key on ... found the power wire on the camaro harness and put it to one of the wires on the Maxima motor till it moved... then made it perminate... I didn't go bonkers... I'm confident if you spent some actual time at the wires from the 3'd gen to the max you can make it all work like stock... I just wanted it to work on low for when it rains.
Sorry it wasn't very technical on that part hahaha...
~Scott
Old 02-25-2014, 07:04 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
saving...
Old 02-25-2014, 05:22 PM
UR50SLO's Avatar
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Sorry.. did get the car back a couple weeks ago...
Here's the pictures... Looks like I cut the stock nissan arm and welded it to my 3d gen arm... motor pretty much just bolts in stock location.
Old 10-31-2015, 01:09 PM
Mr Pain's Avatar
Car: 91 camaro rs
Engine: 355 sbc
Transmission: muncie m22
Axle/Gears: 10 bolt limited slip 373's
Would the Nissan wiper motor work with a 4th gen column? I've already tried to wire the 3rd gen motor with the 4th gen harness and I'm getting what everyone else did, the motor only works on high and the wipers only move a few inches. I'm want to know if the same will happen with the Nissan motor.
Old 02-26-2017, 05:13 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
Hi all, sorry to revive this post, but I am now in the same position as the OP. I've got a 1991 Camaro RS with a 4th Gen T/A Steering column. so I'm going to have to fish my third gen wiper switch out of the old column and disassemble my new column (again) to fix this?
Old 05-31-2017, 04:23 PM
rgauder's Avatar
Car: 1987 Trans Am
Found this diagram for maxima wiper wiring. Maybe it will help someone. I'm working on it now.
File Type: pdf
Old 05-25-2018, 12:10 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Anyone know the weight savings with going to the maxima wiper motor?
Old 06-07-2018, 11:46 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Checked in to the weight savings, about 2lbs
Old 10-31-2018, 10:52 AM
rgauder's Avatar
Car: 1987 Trans Am
Anybody have some good directions for wiring this up?
Old 03-31-2019, 08:20 AM
Firebat's Avatar
Anyone have updated photos of the Maxima wiper motor installed? A lot of the photos on this thread are no longer showing. Also, does it also have a wiper fluid pump on it?
Old 03-31-2019, 10:12 AM
MikeP_82's Avatar
Car: 1982 Camaro Sport Coupe
Engine: 2.8
Transmission: Saginaw 4-spd
This might be helpful:
Old 01-14-2020, 06:09 AM
rgauder's Avatar
Car: 1987 Trans Am
Has anyone got the park feature to work the way described in the video?
Frozer!!!
01-19-2024 04:55 PM
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
TheExaminer
08-26-2015 04:59 PM
slade5612
08-11-2015 07:19 PM
Quick Reply: LS1 Swap/ Now I can't figure out the windshield wiper motor wiring
