Firebirds for Sale Post your Firebird for Sale.
[OH] 1988 Trans Am with TONS of aftermarket parts
Old 06-22-2015, 11:20 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
I will not part out at this time...
This listing is for a rolling body with ALL the parts (minus a torque arm) that you need to complete this beast-of-a-build (plus tons of extras)
The car has been covered and stored indoors for the last 13 years. It has been stored inside a relatively nice garage with a car cover on. The parts have been stored indoors as well. The previous owner also stored it indoors, and the owner before him was a professional tennis player and likely also stored it inside.
After 4.5 years of research and buying, I acquired all the parts for a set up that, based on similar combos, should be pushing around 405rwhp which comes out very close to 500bhp. All you need to do is install them, turn the key and go. I have everything you need except the torque arm. While you could find a stock one for around or under $30, I would recommend going with an aftermarket one because of the power that's going to be going through the drive-train. Feel free to ask me any question or for more details or specs of any of the parts.
Aside from the drivetrain and exhaust, the car is complete as it sits right now and is ready to be wheeled onto your trailer. The body, interior, and wiring are complete and intact and ready to accept the parts below that are included in the sale.
The photos are from when I was last driving it back in the summer of 2003 and since it has been stored covered inside of a garage, it for the most part pretty much looks the same. The car is very nice, but don't expect mint show-room condition...There has always been a chip of paint missing on the rear bumper and the front bumper also has some paint missing from when a raccoon ran into it (just paint-only damage).
I forget the exact mileage that the body has, but it's somewhere between 233k-244k, although you'd never know it to look at it. (I think I bought it at around 233k). Almost all of the parts that go with this are either new or have less than 5k miles.
Since these parts are not installed, it gives you great flexibility to either:
1) assemble them and have a extremely nice-looking third gen Trans Am
2) mix in your own combination of parts to go a different direction with the car (maybe you want a different intake or brakes)
3) sell the parts individually and make money
This car has an IMSA fiberglass hood made by Baldwin Motion, which I believe might be the only one still in existence. I have not come across one person who has this hood (on here or otherwise) nor have I ever seen one driving around or at any car show. I have seen 1 or 2 over the last 10 years that have a bolt-on scoop in the style of this hood, but no one with this actual 1-piece fiberglass molded hood.
Will sell the vehicle and everything I have for it for $7,500 - If you tried to do this piece-by-piece you'd be well over $14k before you ever got done buying the parts themselves,...let alone the car or the hood. UPDATE 11/20/17: ACCEPTING BEST OFFERS FOR A LIMITED TIME
Cash only. I will not hold the car without a deposit. I won't sign over the title, or give you the vehicle until it's paid in full. Sorry, No Trades
The title is clean and clear and ready to be signed over to you.
Here is a List of Just Some of the Parts Included:
  • 406 sbc - brand new rebuild - 0 miles
  • extra 350 sbc roller short block for rebuild
  • ported lingenfelter super ram intake - powercoated red and polished
  • port matched super ram lower intake - powercoated black
  • ported and upgraded aluminum 195 afr heads (flow 283)
  • extra set of sbc cast iron heads with nice roller rockers
  • hooker super comp long tubes - jet coated black
  • 3" custom y pipe
  • 4" mufflex exhaust (no cat)
  • 4" single in/out hideaway spintech muffler
  • flywheel balanced to engine (if you want to run a manual)
  • flexplate balanced to engine
  • 3200 vig converter
  • built 700r4
  • custom firebird tall valve covers - brand new powder coated
  • march underdrive pullies
  • slp cold air kit - brand new
  • bbk 58mm throttle body - brand new, power coated red with old-school lingenfelter plate
  • cc 1.6 roller rockers
  • comp cams 853-16 retro fit roller liters
  • hydra rev kit
  • comp cams cc12-450-8 286hr retro fit roller cam 230/230 .560/.560 110
  • brand new timing chain - brand new
  • brand new 2 piece timing cover - brand new
  • cam buttom - brand new
  • wear plate - brand new
  • moroso deep oil pan - brand new
  • moroso oil pump - brand new
  • brand new engine mounts
  • ac delete pulley
  • smog pump delete pulley
  • edelbrock aluminum water pump - brand new
  • aftermarket upgraded alum radiator - brand new
  • msd billet distributor
  • msd 6a
  • msd rev limiter
  • msd super coil
  • msd retard
  • msd super conductor wires
  • holley adjustable fuel pressure regulator
  • brand new aftermarket upgraded fuel pump
  • 3.5" lingenfelter aluminum drive shaft
  • 9 bolt rear end with 1le pbr brakes with slotted and drilled rotors
  • 3.73 gear and install kit for 9 bolt - brand new
  • complete front 1le pbr 12" brake set with slotted rotors - brand new
  • stock sized slotted and cross drilled front rotors
  • brand new brake lines (long chassis lines)
  • several sets of gta rims
  • 4 dunlop sp5000 tires
  • 2 nitto drag radials
  • several sets of ttops (glass and plastic ones)
  • several sets of ttop bags (two styles)
  • several variations of the stock radio
  • a couple setups of the factory performance sound setup
  • several extra sets of gta seats
  • leather seat backs from rear seat of a notchback gta (rare set of seats with rear-headrests)
  • spare dash pad
  • spare complete low mileage digital dash
  • spare ttop bars
  • custom-fit car cover
  • set of gta emblems
  • several sets of spare tail lights
  • ac delete heater box
  • spare gta door panels
  • transgo shift kit
  • hardended push rods
  • 700r4 rebuild kit
  • lots of fluid to get you started
  • lots of brand new arp bolt sets
  • there also should be every brand new gasket set (most felpro) you need
  • several manuals including a the factory repair manual and a huge parts number illustration guide
  • probably lots more that I am forgetting
Last edited by 4mul8r; 11-20-2017 at 05:06 PM. Reason: bolded the price, and changed the price
Old 01-03-2016, 08:55 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Re: 1988 Trans Am with TONS of aftermarket parts
Photos of car and the TONS of parts that go with it.
https://www.flickr.com/gp/138563396@N03/54GFUM
Old 01-06-2016, 05:26 PM
Amillionoh7's Avatar
Car: 92 RS
Engine: Sbc With h/c/i/e holly4150
Transmission: 700r
holy crap. I hope whoever buys this has a big trunk!
Old 01-08-2016, 11:15 PM
TA8487's Avatar
Car: 1987 GTA & 1984 Trans Am
Engine: 383 stroker TPI
Interested in selling any of those parts in the pictures?
Not that far away in Southwest Cleveland suburbs plus I'm in Columbus quit a bit.
Bob
Old 01-10-2016, 07:40 PM
fbody4me's Avatar
Car: 1980T/A,1987GTA,1989 GTA conv
So you are the reason why third gen Trans am parts are so hard to find around here,lol. Beautiful car, someone is going to get a hell of a deal. GLWS
Old 03-10-2016, 11:20 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Weather is getting nicer....TTT
Old 03-10-2016, 12:59 PM
Car: 92 RS
Transmission: 700r
seriously considering taking a loan out and coming to get this beauty
Old 03-11-2016, 12:02 AM
TA8487's Avatar
If you buy it, sell me some GTA wheels and some extra interior parts, lol
Old 05-12-2016, 07:16 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Last chance to build this car yourself before summer arrives...TTT
Old 10-26-2016, 04:24 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
PRICE DROP TO $7,500. - Nice winter project for someone. Might accept partial or full trades for:
  • professional video/photo gear
  • 2003+ full size chevy/GMC cargo van with less than 200k, in good cosmetic shape, and no logos
  • Sprinter van
  • Box truck in good cosmetic shape with no logos,...(lift gate preferred)
  • SMART car or similar in good shape with lower miles
  • car with total length of 14 feet or less that is reliable and in good condition
Old 10-27-2016, 02:43 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Wow! I saw the parts that go with it and the extras are as impressive as the car! Someone should pull the trigger on this deal. Wish I wasn't over-extended at the moment with putting a kid through college and all I would have to strongly consider making that trip! GLWS.
Old 10-27-2016, 11:14 PM
TA8487's Avatar
  • Sprinter van
How storage space would this take to hold it all with out the car? A full 2 car garage? Thanks
Old 10-28-2016, 10:47 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Without the car I could easily store the stuff into an empty one car garage.
Most of the stuff is in bins and boxes, and are packed in a way that maximizes space at the expense of logic or ease of use/finding something. Most of these bins/boxes can be stacked.
I have three metal cabinets that store a large majority of the parts. I would be possibly open to selling them if needed. Or I have some cheapo metal shelves and some older banquet tables that you could have for free if I still had them at the time of your purchase.
To actually work efficiently on the car though, obviously having more space would be beneficial....and I think an open full two car garage would be enough.
To give some additional reference, at one point I had a 2.5 car garage that had tools, household items, all these parts, the trans am, and another car...
Old 09-28-2017, 07:10 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
It's back on the market. TTT
Everything is still the same, except not looking for trades at the moment. This is a good deal for someone with time to build or part out.
Old 09-29-2017, 12:24 AM
t/aws61985's Avatar
Car: 85-6 TA 85IROC 82-6 MSE 15th/83pace
Engine: Slow ones
Transmission: 700R4/T5
Axle/Gears: Weak ones
Where did you get those valve covers? Could you post some more pictures of them?
Old 09-29-2017, 07:58 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Off the top of my head I don't remember where I got them. It was a long time ago. It was a company out of California that sold them and you could get whatever you design you wanted etched into it. I then had them powder coated elsewhere. I'm not sure if you saw the two pics of them on the link, but here they are. If you want more let me know, but it might take some time.
Old 09-30-2017, 07:30 PM
TA8487's Avatar
When I see your car and parts post, I always think about it a bit especially since now we have access to a car trailer. But I would have to unload either my 84 TTA or 87 GTA or both first to generate the space.
Old 10-01-2017, 08:02 AM
Chopski's Avatar
Car: 1989 IROC
Axle/Gears: 3:42
That is a mother load of parts. Someone could make out like a bandit with this deal. Good luck.
Old 10-02-2017, 03:46 PM
FutureKnight's Avatar
Did you sell this red beauty?
Old 10-02-2017, 03:54 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
It is still available for someone out there...
Old 10-02-2017, 04:26 PM
  • Sprinter van
Are you still selling this buddy?
Old 10-02-2017, 04:31 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Yes. I am still selling.
You quoted the trades section from my original post and so on that note, the only trade I would possibly be interested in would be for a cargo or sprinter van...but I'm looking for something very particular in those areas.
Are you interested in the car?
Old 10-02-2017, 07:31 PM
Yes could be.. However you’re asking price is still $7500 right? I’m in the U.K. London England and looking to export over here. Do you have an email address to discuss this further? Cheers Shaz
Old 10-03-2017, 03:39 PM
Hey buddy.. Yes I am very interested and I think I have the access to various options for you, such as a Sprinter, even a Smart Car and depending on what Camera Equipment you want.. Can we PM and discuss it further?
Old 11-20-2017, 05:04 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Last chance...Make Offer: Want a Black Friday / holiday deal on the whole package?
Read my entire description and then PM me your best, serious cash-in-hand offer before I change my mind again.
Someone is going to get a hell of a deal.
Seriousness and number of offers depends on how quickly I accept one. (or guaranteed buy it now for my original $7,500 price)
But come January if it's not gone, I am either going to put it all together or start parting it out (no requests for individual parts at this time). If I'm still in the mood to sell if after Jan, it will never be offered as a package deal again.
Old 11-20-2017, 06:23 PM
misteroman's Avatar
It appears from the flikr page that there are numerous sets of many different items.
is everything included in those pics?
thanks
Old 11-20-2017, 06:26 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Yes. Everything is included.
Old 11-20-2017, 07:51 PM
misteroman's Avatar
K. Trying to process all.
for example, it looks like there are 5-10 sets of ttops. Not that these are extremely valuable, just trying to get a grip on it all. There also seems to be like 5 or 6 overhead counsels amongst other things.
thanks
derek
Old 11-20-2017, 08:22 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
I think there are 10 overhead consoles and 4 sets of ttops. I know there are 2 glass tops and 2 plastic sets of ttops.
Old 11-20-2017, 11:32 PM
COTM Editor
QwkTrip's Avatar
Received 1,855 Likes on 1,270 Posts
Car: '89 Firebird
Engine: 7.0L
Will you please show a picture of the hood with it latched closed? Can't decide if the hood was never closed in your pictures or if the lines are really bad at the front.
Old 11-21-2017, 07:05 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
The very 1st pic (in the driveway w/ 2 firebirds on the street) on this thread is with the hood latched. The hood seems thicker than the stock hood which might or might not be contributing to this. Any of the pics in the flickr link of the car inside are going to be super exaggerated as we took the hood off to remove the original engine and haven't put it back on properly. When the new engine went in the car I was going to see if there was anything that could be done to make the front of hood sit a little lower. It never bothered me too much though.
Old 11-22-2017, 12:51 AM
COTM Editor
QwkTrip's Avatar
Car: '89 Firebird
Engine: 7.0L
Thanks. If you ever sell that hood then I'm your man. Not even going to worry about the price because I know you'll be fair. Doesn't matter if it is this week or 2 years from now, just don't forget about me when it comes time to sell. I'll come pick it up in person. No shipping mess to worry about.
If you need a stock hood then just pick one out from somewhere, send me the link, and I'll have it shipped to your home as partial payment.
Old 11-26-2017, 07:35 PM
85irocZ2819's Avatar
Car: '87 z28
Engine: 383
Transmission: t56
Axle/Gears: 10 bolt 4:10
I’m think I’m interested in your ta can you pm me a number I can reach you at thanks
Old 11-28-2017, 02:57 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
PM sent
Old 11-28-2017, 03:06 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Ok. Here are some answers to requests by people:
This was originally a 5.0 TPI car. When I bought it had been switched over to a jasper 350. I replaced the camshaft and this caused an oil and antifreeze leak, which destroyed that motor. I pulled the motor and began assembling everything here for a new setup. I motor and heads I pulled went to the scrap yard. What is included here is much much better though...
The car has an alarm system which (from what I remember) also allows remote locking and unlocking of the doors.
The hood was purchased in 2000 and the car painted in 2002. Front and rear bumpers have paint chips that will need to be touched up or resprayed. The radiator leak, caused some of the paint on the underside of the hood to flake off as well. (pic in new link below)
The spare 350 that is included wasn't the one that was in the car when I bought it. This one was included in a storage unit I bought a few years ago. I don't know anything about the history of that block. It is randomly missing a rod and piston. It will likely need a rebuild...or at min. freshened up. It's a 638 block, 1 piece rear main seal, and is (I believe) set up for option use of a roller cam based on look of the valley. (pics in new link below)
The underside of the car is in pretty good shape considering it has 233k+ miles....very little rust. Keep in mind that it's not a show car. I took a bunch of photos 2 days ago to give an idea. The photos show how the car currently sits. I didn't wipe anything down or even remove dust or cobwebs. I never wiped off the original areas the oil and radiator leak blew to. Really the worst issue is a small hole in the floorboard on the passenger side. Here is a link to these photos and the ones mentioned above:
https://drive.google.com/open?id=1Za...sccfTmeZnKs0RM
-reminder: the engine shown here is the spare 350...not the main 406
The 406 block was built in 2002 and never run. I bought it around 2004 and also never ran it. Here is some info on it from the person I bought it from:
400 block bored .030"
with TRW forged aluminum pistons TRW-L2489F30
SDPC balancer part
#6272225 also done is
Hot tanked and magnaflux
Bore and hone with deck plate
.010-.010 crank
.035" deck clearance
Resurface deck to flat
cam bearings
checked align bore
Pink rods
Resized rods to bolts
ARP rod bolts
crankshaft oil holes chamfered
complete assembly balanced (externally I assume)
This should handle the setup I have here. If you are going to do anything super more aggressive, I would recommend redoing some of the internals, especially if you are going to super or turbo charge...but doing that would create the need to change out several other parts in this setup anyway.
The super ram, lower intake, and AFR heads were purchased from JohnnyIroc who had them port matched. He had less than 5,000 miles on this setup. I never got the chance to install them myself. He gave me the following info when I purchased:
195 74cc
ss 2.020 + .050
ss 1.600 + .050
upgrade spring 8020 to 8015
steel 10 degree retainers
10 degree valve locks
rubber valve seals
guide plates
rocker stud upgrade 3/8 to 7/16 stud
s.b. bronze guides .502
2.200 intake seats
1.695 exhaust seats
helicoils 7/16 14x1.2
angle mill and correct intake 58cc
Head Flow Data
.1 = 67.9 / 56.0 = %82.47
.2 = 134.3 / 113.9 = %84.81
.3 = 201.1 / 167.9 = %83.49
.4 = 248.2 / 206.1 = %83.04
.5 = 276.6 / 227.0 = %82.07
.55 = 282.2 / 233.0 = %82.57
.6 = 283.6 / 239.3 = %84.38
Here is the information the original owner of the 9 bolt rebuild kit. I have not installed this either.
9 bolt COMPLETE rebuild kit from ratech (all timkin) with severe duty pinion shims and a solid spacer to replace the crush sleeve. With this will come ring gear bolts from arp and 2 bottles of redline lightweight shock gear fluid. These were purchased to beef up the 9 bolt to handle a good amount of power. Of course nothing here is used, all brand new in box.
Not specifically mentioned in the original post, but included and shown in the flickr album is:
Coan torque converter 3,000 stall w/lockup
3.5 aluminum driveshaft for use w/ a ford 9"
These are in addition to the 3.5" aluminum driveshaft for a 9 or 10 bolt and in addition to the Vig. TQ coverter.
The transmission rebuild kit and shift kit are brand new, not installed, and not part of the built transmission referred to in the original post.
I bought the built 700r4 from Johnnyiroc. Here are his original ads for it, as well as the torque converter, headers, exhaust, and muffler which I also bought from him.
Dynotech 700r4 trans, 500miles on it
Posted on Jul 10 at 07:51 PM Ad No. 47386
Posted By: JohnnyIroc
This is a serious trans for big hp cars. It will hold up to 650 hp. Ive used it for
only 500 miles and then my motor spun a bearing, and im going with a much bigger motor
so i need a glide or th 400. This trans cost $1800. Email me with offers
PI Vigilante 3200 stall tq converter
Posted on Jul 10 at 07:48 PM Ad No. 47384
This is a new converter with only 500 miles on it. It is a lockup converter and has a
3200 stall speed. This cost me $850.
Hooker Super Comp headers
Posted on Jul 14 at 08:07 PM Ad No. 47632
These headers are brand new from jet hot and have never been bolted up. They have 1 3/4
inch primary tubes and 3 inch collectors with an o2 bung tapped into the the top of the
drivers side collector. The coating is jet hot 2000 , in a rough black finish. These
cost me $620.
Mufflex 4 in. catback system for any 82-92
Posted on Jul 14 at 08:16 PM Ad No. 47633
This system featurs a 4 in. single inlet, single outlet, spintech muffler, with
hideaway tip. It also includes the complete intermediate pipe. Only used for 5k miles.
Hopefully this helps everyone out! Someone is going to have fun with all of these parts.
Old 12-01-2017, 08:43 PM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
You been trying to sell this for 2 years?
Old 12-02-2017, 07:27 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Extremely passively most of that time...now it's time to get serious about it
Old 12-26-2017, 09:01 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Can you PM me? After thinking about it again, I am very interested in the car and parts
Old 12-27-2017, 07:38 AM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
This would be a good project for you. I know a few Felts' that would think you were really cool with a Trans Am.
Old 12-27-2017, 02:02 PM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Still available guys. Make offer. Someone's going to get a good deal.
If I am still selling after the new year I'm going to start breaking it down into parts/lots as my work schedule permits.
Old 01-13-2018, 02:31 PM
COTM Editor
QwkTrip's Avatar
Car: '89 Firebird
Engine: 7.0L
I'll still make the drive to come get that hood. Just need you to say come get it.
Old 01-13-2018, 07:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
You can buy the hood from fiber concepts in PA, they are still available.
Old 01-17-2018, 08:49 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Can't believe nobody has grabbed this after all this time! I'd buy this tomorrow if I hadn't cleaned out my bank account to buy the pickup I bought a couple weeks ago. Any chance you'd be interested in an 08 duramax crew cab dually that needs a motor(which I have)?
Old 01-19-2018, 09:15 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
QWKTrip: When my schedule allows me to start breaking it up, I will let you know about the hood.
//<86TA>\\ - Re: Fiber Concepts - that's interesting, but several parts of their site seem to be not updated or maintained, so I wonder if it is actually still available, if their price is still accurate, and what their lead time is.
zya5point9 - Not interested in dually, sorry. If you sell it though, check to see if this is still available.
I might be tempted by a straight up trade though of something running (or pro-level film/video production gear),...maybe.
Old 01-19-2018, 10:37 AM
TA8487's Avatar
Are the seat surfaces on the black GTA seats in good condition?
Old 01-19-2018, 10:59 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
Mostly. There is one seat that has some rips...and one that might need some bolster repair. But most of them are in good condition. Pics here (go backwards to see a few more):
-pretty sure those white flecks are just dust, or other material and not holes...but I can check to make sure later
Old 01-19-2018, 01:22 PM
COTM Editor
QwkTrip's Avatar
Car: '89 Firebird
Engine: 7.0L
Thanks. Yes, there are actually two places that make the hood still. Getting one is easy and pricing is not a mystery. But in my experience aftermarket parts tend to fit better when they were made closer to when the cars were new.
But you are right, the rarity is not because you cannot get it, it is because hardly anybody chooses to get it. I'm not sure if I will like it or not on my car but buying used is harmless because you can always sell it for what you got into it.
Old 01-19-2018, 03:58 PM
//<86TA>\\'s Avatar
I was going to get that hood for my 92 a few years back and spoke with fiberconcepts. At the time they said it was available and the lead time was a week or two, however they said they hadn't sold one in years.
Old 01-24-2018, 09:15 AM
4mul8r's Avatar
Car: 88 Trans Am
Engine: 5.7 TPI
re: extra seats - the white flecks are just general dust and debris. There is a cigarette hole on one of the seats. Some of the seats have items that have been stored on top of them (such as seat bottoms, plastic trim pieces, etc...so there are some bottom and side bolsters that might need some time for the foam to return back to normal. Overall though...good shape, especially for 30 year old car seats.
Old 01-25-2018, 11:29 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Where is the price at now? I have a friend with a truck and trailer and between the two of us, we could probably use most of this.
Quick Reply: [OH] 1988 Trans Am with TONS of aftermarket parts
