Split ratio 1.6/1.5 Comp Pro-Magnum
Car: 1966 El Camino Custom
Transmission: 200R4
Excellent set of Comp Pro-Magnum full roller rockers. Non-self aligning. Split ratio 1.5/1.6 ratio. $175 or trade for self aligning rockers.
Car: 1991 Trans Am GTA
Axle/Gears: 4th gen 10 bolt 3.42 posi
Re: Split ratio 1.6/1.5 Comp Pro-Magnum
Interested. Have to wait to hear about some heads I'm looking at first though. These will work on center bolts, correct?
Transmission: 200R4
Yes..and I'm pretty sure I have the guide plates which I'll throw in.
Engine: 4++,350 & 305 CIs
They will work but the valve covers will need some mods.
Transmission: 200R4
Yes. Some minor clearancing. Removing some internal bracing on steel covers. Some easy grinding needed on aluminum covers.
Would some slightly taller than stock covers solve it, or will it be same issue?
71formula455
Exterior Parts for Sale
Dec 29, 2015 11:15 PM
blue86iroc
Dec 7, 2015 07:30 AM
