[NY] Small Block TPI setup w/ Accel DFI Gen 7
Old 11-30-2015, 10:09 AM
cj68's Avatar
I am selling the tuned port injection setup off my Jeep. System was in good working order when I removed it this October. The system was purchased from Lingenfelter Performance and installed new on my 383 stroker since 2010. Since then I have maybe 8,000 miles and a dozen trail rides on my Jeep.
I am looking for $1,800 shipped and firm on price. Priced at the lower end for a quick, no-nonsense sale. I will part the system out if it does not sell whole after some time. Located in 11971.
This is a complete Air, Fuel, Spark engine management system. Total retail value of all components that I am including is over $4,000. Accel Gen VII DFI is a very power engine management system capable of forced induction and even has a built in multi-stage Nitrous controller. The ECM can also control torque converter lock-up on an auto trans as well as cooling fan controls. The Gen VII system REQUIRES A SKILLED TUNER to setup and dial in to perfection. But once dialed in, you can have OEM quality engine management and refined driveability. Personally I netted 17MPG highway with my 400hp 383 on 37's when I had a manual transmission.
List of included components (I am probably forgetting some odds and ends):
  • OEM Upper Plenum, port matched to throttle body
  • OEM Fuel Rail setup with -6AN fittings
  • OEM TPI water neck and 180* t-stat installed
  • Edelbrock 3861 High Flow Base Plate (EGR block off plates installed) (Pretty sure this will work with later model heads, check with Edelbrock to be sure)
  • Accel 74195 High Flow Runners
  • Mr. Gasket 146 TPI Runner Gasket Set (New, never opened package)
  • Accel 74190 1000CFM throttle body (coolant cross-over tube modified to clear high flow runners)
  • Accel 150132 32lb/hr fuel injectors
  • Accel 74750 Adjustable TPI fuel pressure regulator
  • Accel 77022 Gev VII DFI Fuel/Spark Management system (ECM Updated to latest firmware V6.1 by Accel) (ECM, Harness, Sensors)
  • Accel 77681 GM Injector Harness
  • Accel 77190T Tall Deck (adjustable deck height) Dual Sync Distributor (Tall Deck needed to clear Edelbrock base plate)
  • Accel 77101 Dual Sync Distributor Adapter Harness
  • Accel 77174 SBC Closed Loop Spark Knock Control Kit
  • MSD 6201 Digital 6A CD Ignition Box (Custom made wiring harness w/ weather pack connectors)
  • MSD 8222 High Vibration Blaster Coil
  • Accel Calmap software (Latest version, User manual, and windows drivers on USB thumb drive)
  • Accel 77994S USB tuning cable w/ integrated sportsman key
  • Accel 77062 Single Channel Wide-band O2 sensor/ Signal conditioner ($400 value!)
  • Accel 74701 & 74720 200lb/hr @ 45psi fuel pump and high pressure fuel filter
  • Lokar TPI throttle Cable parts (Will need new inner cable/outer sleeve if what is provided is not long enough for your application)
  • Trick Flow Specialties 315B800 Intake elbow (Modified to Mount IAT sensor in Elbow)
Old 12-08-2015, 01:29 PM
cj68's Avatar
Re: Small Block TPI setup w/ Accel DFI Gen 7
Price Drop. $1,800 shipped
Old 12-24-2015, 08:39 AM
cj68's Avatar
Price Drop. $1,500
Old 02-28-2017, 12:49 AM
Want a title? Post!
redbowtiez28's Avatar
still available?
Old 02-28-2017, 03:28 AM
cj68's Avatar
Long gone
MinnGreenGT
26
08-26-2014 09:44 PM
lakeffect2
04-17-2010 09:24 AM
skifur555im666
03-07-2010 10:06 AM
S!MON
10-30-2009 11:41 AM
Kurt04
02-24-2008 01:49 PM
Quick Reply: [NY] Small Block TPI setup w/ Accel DFI Gen 7
