TPI dual fan setup with custom cover
Old Sep 10, 2016 | 11:57 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have a complete TPI dual fan setup. Factory upper and lower mount and both fans with newer fan motors. I also have the upper fan mount/radiator cover that I made a few years ago that can be sold separate or together. Made of 1/8" aluminum that was spool gun welded. On the back side I cut out the Chevy Bowtie emblem. The mount bolts down exactly as a normal mount does. The fans bolt to the shroud with a 1" spacer.
$200 for the setup with mount that I made
$120 for the setup with only the stock mounts.
PayPal, I'm in Northern Arizona.
Old Sep 10, 2016 | 01:28 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: TPI dual fan setup with custom cover
need paypal info
cash is king..
Old Sep 12, 2016 | 08:53 PM
still need a paypal address
Old Sep 13, 2016 | 10:33 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Tried to take better pictures of the weld so people know not to expect a machine welded piece.
Old Sep 14, 2016 | 08:19 PM
funds sent 5 min ago..$225
that's fine..i can run a ball end mill. down it to clean it up and redo it...its a start.so I don't have to take more time to make one from scratch...then who knows..
Z28Johnny
Sep 16, 2016 05:26 PM
jtmiller92
Sep 11, 2016 09:22 PM
Cody Willey
Sep 10, 2016 05:38 PM
86FyrBrd
Sep 7, 2016 08:22 PM
hotrodjames
Southern California Area
Sep 5, 2016 12:46 PM
