Tpi, 350 performance oil pump options.
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
The title says it all..
Looking for a good performance oil pump and water pump for vortec 350 tpi build.
Received 1,662 Likes
Re: Tpi, 350 performance oil pump options.
Yes.
TPI will prevent the oil pump from ever making any significant difference.
Just go to AZ, order what the computer shows, you'll be fine.
Engine: 4++,350 & 305 CIs
The stock melling oilpump will be just fine.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The oil pump in my BBC is Melling pump. Nothing special. It's not even a high volume pump. I don't need to fill the top of the engine with oil at 7000+ rpm.
The nice thing about an aftermarket pump is it may come with an option higher pressure spring.
The best thing you can do to improve the oil pump is to use an aftermarket shaft that doesn't use the plastic/nylon connector.
stock pump, pull the spring out and stretch it out, and radius the outlet inside the pump. SBC's have the best stock oil system ever made. be careful when buying a Meling oil pump, not sure if they have corrected this weak casting or not.
https://www.thirdgen.org/forums/tech...-m55-pump.html
Car: 1983 G20 Chevy
The last 3 smallblocks I have built, I used high pressure standard volume big block pumps in. They seem to work well.
LOL on a small block chevy if the cam bearing are not wasted no need for a high pressure pump, just add extra oil slinging around and robs a little hp.
MeenZ28
Southern California Area
10-12-2016 09:29 AM
mynameisfrank89
09-19-2016 10:49 AM
91dime
09-17-2016 12:07 AM
