I am Back but...Need a welder/fabricator
Location: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Yep...after an extended absence from these boards I am back. Finally got enough income to put the 92 back together. 88 IROC is still rolling. Any way on my 92 the new floorboard is in. I need some fabrication & welding done by the drivers side firewall (about 6" x 6"), one strut tower and on the inner rear wheel well. It sounds worse than it really is.
So who knows a local welder / fabricator / body shop that does this type of stuff?
Strut tower repair
Wheel well repair
Firewall driver side repair
Strut tower repair
Wheel well repair
Engine: all 225+ RWHP
Transmission: all OD
Re: I am Back but...Need a welder/fabricator
Best advice if you truly want to fix it is that I would not touch anything until I had a donor car or cut donor pieces from a known good car.
Those things can all be fixed but it will be tome consuming and have good pieces to replace it with would be by far the wisest way to go.
We did the drivers side firewall on my Formula and partial strut tower too. Driver floor pan is yet to be done along with some rocker repair as well.
Figure the strut tower repairs and a cut and replace on drivers side firewall, we had over a 40hr week into time wise with 3 people non stop and not counting lunches.
It can all be fixed, just be stout of heart, of wallet and of time
Axle/Gears: Posi
But I need a specific person to do the welding. Who do you know?
I don't know anyone on the side who would have that kind of time.
We can't even get together to do my car......
That at a body shop will get costly quickly
Axle/Gears: Posi
Axle/Gears: Posi
Ok ready to get car welded. Who should I use? Want to get it done before the snow comes.Help me.
Axle/Gears: Posi
Ok still need that welder. I am ready to move on this ASAP...Can anyone point me in the right direction.
shagdonk
Interior Parts Wanted
09-22-2016 04:33 PM
