WTB stock exhaust manifolds for 88 TA
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
Looking for stock exhaust manifolds for an 88 TA V-8 with A.I.R. emission.
Car: '91 Camaro Z28
Engine: L31 5.7
Axle/Gears: 10 bolt, 3.73
Re: WTB stock exhaust manifolds for 88 TA
Are you specifically looking for '88 TA manifolds? I have a set of '91 Z28 manifolds with AIR that will probably fit. If you want to check into fitment I'm not asking much. Also, I'm in Lafayette if you want to pick them up (could meet in Boulder too).
Car: 88 Trans Am
Engine: 355 c.i.
Axle/Gears: 3:42s
let me check and make sure they will fit. I'm not sure myself I'll get back to you soon. Thanx for the reply .
Car: 88 Trans Am
Engine: 355 c.i.
Axle/Gears: 3:42s
It looks like headers for them are the same so I would think the manifolds are the same. How do I get ahold of you?
Car: 1987 Trans Am GTA
Engine: Warmed over 350 TPI
Transmission: 700r4 soon to be t56
I have a set of manifolds from an '87 GTA, but they should be the same for an '88. They needs new studs. They still have the air tubes.
