Double Din Radio Bezel
Old 01-19-2017, 01:02 PM
brettr81's Avatar
Car: 91 Firebird
So, I decided to try and put in a double radio. However, I don't feel like paying $99 for a bezel that's plain. Thought about modding my own, but then I remembered that a member here veaceonee, designed one for 3d printing.
DO NOT USE THIS ONE DIMENSIONS ARE OFF!!!! I edited this post with links for the ones that were made and tested by other members and found to work.
http://www.thingiverse.com/thing:1353274/#collections
Well, that's awesome, but I don't have a 3d printer. So, I had to find an online service where I can have someone print it, and ship it to me.
THESE WORK
For Camaros 7thdarkangel made:
http://www.thingiverse.com/thing:2194376
http://www.thingiverse.com/thing:2281726
First one is standard fitment, the one beneath is for HVAC controls on the bottom.
For Firebirds:
http://www.thingiverse.com/thing:2238132 Smooth
http://www.thingiverse.com/thing:2249678 Checkered
http://www.thingiverse.com/thing:2241658 Digital HVAC controls
This is from Cehbra on his thread https://www.thirdgen.org/forums/car-...vement-3d.html
So, then I went to:
https://www.3dhubs.com/service/87790
Found that guy, under $20 for him to print and ship to me, and made in ABS plastic.
Great service, and it was completed next day, sent pics right away, but I haven't received it yet. If it turns out well, I'll have a double din bezel for under $20. It does appear that the gap between the thermostat controls and the radio is a little thin, but if it doesn't work I can revise it and do it again.
So far, I like the look of the texture, not stock but also not looking like someone just took a plain sheet of plastic and threw it on there. Once I receive it, I'll let everyone know fitment. So far, this guy Matt has been pretty good to deal with, updated me constantly.
Last edited by brettr81; 05-18-2017 at 03:14 PM. Reason: New information, and good work by other members of forum
Old 01-19-2017, 08:11 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Double Din Radio Bezel
That looks pretty nice. Can't wait to see it installed. Thanks for sharing the links.
Old 01-19-2017, 08:20 PM
brettr81's Avatar
Car: 91 Firebird
No problem, I figured for $20(compared to $99 or hacking up my current piece and having to replace it later) it would be worth trying. Within 36 hours the guy had it printed and shipped. I know a lot of people here have been wanting a more affordable bezel too.
Old 01-20-2017, 06:11 PM
Citation X's Avatar
Car: 92 RS
Awesome hope it works out. Looking to possibly put one in mine. Oh guess it's firebird only heh. Maybe I'll get lucky and someone with do one for a camaro.
Old 01-21-2017, 02:02 AM
stan07sf's Avatar
Car: 1991 RS Convertible
Engine: 305 TBI Stock
Looks like an OEM piece. Are you going to drill your own holes?
Old 01-21-2017, 02:43 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
How so? There are inconsistencies in the material as well as the texture is not close to the OE grid pattern.
While a nice piece, it looks far from OEM. Will still be a suitable bezel for double din use.
Old 01-21-2017, 09:40 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Nice, whos got a 3D file for a camaro bezel? I want one.
Old 01-21-2017, 05:17 PM
brettr81's Avatar
Car: 91 Firebird
So I received it today and installed, and it is a quality made piece. The bezel is 5/8" too long. Otherwise it is a good piece. I ended up just trimming that off. I placed the order on the 18th and received it on the 21st, so I can't complain about that. I'll post pictures later. The printer did his job and did it pretty quickly and impressed with the service I received.
If anyone has 3d editing software, you just need to move the lip 5/8" higher up and then it should be a perfect fit. You can sort of tell by looking at the pictures in the first post.
Old 01-21-2017, 05:24 PM
brettr81's Avatar
Car: 91 Firebird
I should have stated, it's a 91 bird, so it has tabs and pops in.
Old 02-27-2017, 09:36 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:42
I would be in for one at that price..maybe even 2 to play with a few tablets I got around. I know alot of guys have a gripe about the oem texture/grid is hard to replicate but I would prefer a blank canvas to work with. I have an idea to semi get look of oem but it would require time..and even worse more patience and having an original bezel to measure out the oem grid.
Old 03-01-2017, 05:30 PM
FAST LiFE's Avatar
I want one too!
Old 03-02-2017, 07:43 AM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
ill post one in about a week or so.
Tanderson0318 (01-17-2020)
Old 03-02-2017, 10:09 AM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Here's a thread for trying to duplicate the oem firebird texture.
https://www.thirdgen.org/forums/inte...reo-bezel.html
Old 03-05-2017, 12:57 AM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
I hate the tron grid pattern. I have a 91 bird with a double din. I had my shift plate, double din bezel, and switch pod sanded, texturized, and painted black. It looks stock and IMO better than original. On the switch pod, leave the left and right sides the factory grey color. The paint flakes off minimally. It was a worthwhile upgrade.
Did you have the 3D printer make mounting brackets for the head unit as well?
Old 03-10-2017, 06:34 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
As promised. If time allows it, I will print and test fit this week end.
The following 2 users liked this post by 7thdarkangel:
IROCullan (08-14-2020), TWON_3rdGEN (11-23-2019)
Old 03-10-2017, 02:33 PM
FAST LiFE's Avatar
That is awesome!
Old 03-10-2017, 03:33 PM
DynoDave43's Avatar
Looking forward to your report.
Old 03-10-2017, 05:59 PM
Citation X's Avatar
Car: 92 RS
Awesome can't wait to see how it turns out for you.
Old 03-10-2017, 06:59 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Quadruple that.
Old 03-16-2017, 02:04 PM
brettr81's Avatar
Car: 91 Firebird
Very nice!!!!
Old 03-16-2017, 04:59 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Please let us know when you do, I'd love one as well.
Old 03-17-2017, 06:39 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Did a test fit and completely forgot they are tapered. Also need more of a chamfer on the bottom where it meets the shift plate. I'm changing the 3d file today and will print another test piece later tonight hopefully. once this fits, I'll print the rest of it out and fit the hvac controls in as well. I might try a plate with the radio and hvac controls flipped too. Mainly because of my own wants.
Attached Thumbnails Double Din Radio Bezel-img_1712.jpg   Double Din Radio Bezel-img_1713.jpg   Double Din Radio Bezel-img_1714.jpg
Old 03-17-2017, 11:05 AM
J. Chris Davis's Avatar
I'm certainly interested in the one for the Camaro you are currently working on. The plan for mine is to have the climate and radio flipped so the radio is on top and the climate controls on bottom.
Old 03-17-2017, 03:02 PM
Car: '91 LS6/T56/9"
Engine: LS6
I wouldn't expect it to be perfect on the first rev. I'd like the radio on top too!
Old 03-19-2017, 11:17 PM
RWerksman's Avatar
Subscribed. This is fantastic.
Old 03-20-2017, 06:12 AM
chad pickens's Avatar
thats what i want hvac on bottom and 2din on top
Old 03-20-2017, 08:42 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Well, it fits exactly like the oe plate I have. Just need to adjust the upper radius a bit. I may try to adjust it a little more to fit better than oe, not sure yet. Should be able to print the second part out tonight and fit it with the hvac controls in place. Unfortunately I don't have a double din unit at this time but ill work around that for now. Once this one is good to go, ill post the files and start on the reversed plate.
Attached Thumbnails Double Din Radio Bezel-img_1716.jpg   Double Din Radio Bezel-img_1717.jpg
Old 03-20-2017, 09:42 AM
Looking good. Do you need a height and width measurement for the double din or are you just referring to test fitting? Mine is pretty much loose in the car and I could measure it at lunch time.
Old 03-20-2017, 10:59 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
More for a test fit. I used standard for double din size.
Also I apologize for the thread hijack.
Old 03-20-2017, 11:22 AM
I kind of figured, but just incase I thought I would ask, lol.
Old 03-21-2017, 06:26 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Printed and assembled. If I don't go home to a cranky kid again the hvac should be fitted to night.
Attached Thumbnails Double Din Radio Bezel-img_1721.jpg   Double Din Radio Bezel-img_1720.jpg
Old 03-21-2017, 08:05 AM
Car: '91 LS6/T56/9"
Engine: LS6
Looks great.
Old 03-21-2017, 08:20 AM
I second that. That does look great. Can't wait to see the double DIN on top and HVAC on bottom version.
Old 03-21-2017, 09:34 PM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
fits well but will need to modify hvac bracket to adjust the controls up a tad and then chop the bottom off to clear the radio.
I will add the link to the file to this post when its uploaded.
Old 03-22-2017, 08:26 AM
Car: '91 LS6/T56/9"
Engine: LS6
Excellent, and thank you!
Old 03-22-2017, 02:32 PM
FAST LiFE's Avatar
That is awesome!
Old 03-23-2017, 06:24 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Here's the link. Enjoy!
Speedfreak391 (01-06-2022), TWON_3rdGEN (11-23-2019)
Old 03-23-2017, 09:29 AM
That does look great. I found pictures of other double din radio bezels and it looks like the openings on these are not as wide as your plate design. The heights on these and yours look the same, but the opening looks wider than what a double din would require. What was the test radio you used for the opening size. I have a Pioneer AVH-4100NEX and it looks more like the radio in third picture.
Old 03-23-2017, 10:23 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
still looking for a test radio. I can easily add another file variant for a plate with a true double din hole. I left the hole width the same as factory for aesthetics. ill add a second file to the link later today.
Old 03-23-2017, 10:27 AM
Ah Ok, I understand. Makes sense, LOL.
Old 03-23-2017, 11:08 AM
I don't know if it will help. I measured my Pioneer faceplate for my double din and it measures height: 3 3/4" and width: 6 5/8".
Old 03-23-2017, 05:31 PM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
added another plate file with the standard 180mm x 100mm opening.
Old 03-24-2017, 01:34 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Subbed, if you start to produce these, I want one.
oneowner73 (10-12-2019)
Old 03-24-2017, 01:38 PM
RWerksman's Avatar
It's my understanding that they do not need to be mass produced. The plans (on Thingverse) can be sent to any 3D printing service or done at home with the correct printer. A service would provide better quality such as smoothing, different materials and color options.
What I'm waiting for is a plan flipped - with the stereo on top and HVAC controls on bottom. My guess is that it's significantly more difficult due to how the radio itself is mounted.
Old 03-24-2017, 06:30 PM
Thats what I want HVAC controls on the bottom makes it look more modern
Old 03-24-2017, 10:49 PM
Gets the shifter out of the way as well
Old 03-25-2017, 07:38 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
There is a guy on here that did flip the heat control to the bottom. Just do a search.
Old 04-13-2017, 08:06 AM
any news on the flipped version ?
Old 04-13-2017, 11:04 PM
86gn's Avatar
Car: 92 Vert
https://www.thirdgen.org/forums/car-...tall-pics.html
Here is the flipped unit I made, it wasent fun at all lol , I would like to buy a printed one as a backup too if anyone makes a file...
wildmon69 (04-15-2020)
Old 04-14-2017, 06:17 AM
Car: 1983 Camaro
Engine: Missing
Axle/Gears: 9" Ford
Here's what i have so far. I have everything flipped around. The hvac controls will have the same angle as the factory location. Spacers will be included in the print files to achieve this. So far it looks like slight modification to the hvac bracket (holes that mount the bracket to the center council will need to be elongated). I should be starting to print and test fit everything this weekend (hopefully).
Cheers
Quick Reply: Double Din Radio Bezel
