TBI POD Gasket
TBI POD Gasket
Does anyone have a part number for just the gasket? I bought a rebuild kit but the pad gasket sucks, it is super thin and I'm having a slight leak @24psi. Any help would be appreciated. Also is any gasket brand thicker than another? My stick was thick compared to the carquest part.
Car: check
Engine: check
Transmission: check
Re: TBI POD Gasket
The only place I've seen pod gaskets is SPR Performance. It was a set of 5 units. Check DCtrumpets ebay store.
RBob.
RBob.
Re: TBI POD Gasket
You could get a pod spacer if you want, instead. The ones I've seen/installed are all basically thick gaskets. You won't need a separate gasket. Plus, the potentially help performance(although I can't swear by that claim).
