[PA] World Product S/R Torquer 58cc heads
Old 02-09-2017, 04:18 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
I'm looking for a pair of the cast World Product S/R Torquer 58cc heads that they made for the 305's. Apparently they stopped producing the S/R Torquers in 58cc a couple years ago.
Old 02-21-2017, 12:52 AM
NoEmissions84TA's Avatar
Re: World Product S/R Torquer 58cc heads
I just joined to send you this info:
https://www.competitionproducts.com/...uctinfo/4265B/
https://www.competitionproducts.com/...uctinfo/4265K/
https://www.competitionproducts.com/...ctinfo/4265KA/
Old 02-21-2017, 06:15 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Those are just the regular S/R heads. I'm looking for the S/R Torquer ones that they no longer make in the 58cc size.
Old 02-23-2017, 10:46 PM
What is the difference between the regulars and the torquers?
I thought I bought the S/R Torquers 20 years ago when I rebuilt my 305.
It was not until only a few years ago that I found that what I received from
RHS were actually circle track heads with 2.02/1.6 valves in them and some
improperly oversized valve seals that the retainers smacked into at full valve lift.
But at the time I figured that RHS knows more than me and bolted them on.
Cam lobes got destroyed as a result and all that shrapnel went through the engine,
destroying pretty much everything. I was able to resurrect it, and hope to get the
car back on the road this year.
As far as I know, there were no differences to the head castings themselves.
The differences were in the way the valve train was set up.
Old 02-24-2017, 06:11 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
The S/R heads are just an improvement in casting over the stock heads. S/R =Stock Replacement with not much difference in flow over stock. The Torquers are designed to flow a bit better than the regular S/R heads or stock heads.
Old 02-25-2017, 07:51 AM
Want a title? Post!
irocboy1985's Avatar
Car: 1985 IROC-Z
Axle/Gears: 7.5/ 3.42 gears
they still run the 1.94/1.50 valve sizes correct? pretty sure I have a set in the garage
Old 02-25-2017, 08:11 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Yes. They should have the smaller valves and the casting should read "305 I-058".
Old 02-25-2017, 08:20 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
If you have them, I'm a buyer. Let me know.
Old 02-25-2017, 09:46 AM
Want a title? Post!
Car: 1985 IROC-Z
ill check when I get off work and let you know. if youre in pitt youre only an hour or so away from me
Old 02-25-2017, 10:06 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
much appreciated.
Old 02-26-2017, 12:05 AM
According to this World Products sheet, the 305 heads did not come in a Torquer version.
http://www.theengineshop.com/product...f_file-212.pdf
http://www.billmitchellproducts.com/...EADIDGUIDE.pdf
Mine are #4265.
More info:
https://www.thirdgen.org/forums/tech...ucts-s-rs.html
https://www.thirdgen.org/forums/tech...305-heads.html
Jegs (e b a y) store has some currently listed. Search for "042650".
305 circle track racers MUST use this head. Good luck.
Old 02-26-2017, 07:01 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Mine are #4265.
More info:
I'm guessing that first sheet is the current heads. If you look at that second sheet/link they mention the 305 S/R Torquers. Like I said before, they have been discontinued, but they most certainly did them in the past.
Old 02-26-2017, 07:04 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
the chamber would look like this
Old 05-11-2017, 05:59 PM
86Z
86Z's Avatar
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
they did make a s/r torquer 305 head. i have them on my car... debating on if i should part it out or not.
Old 05-11-2017, 06:01 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
keep me in mind if you decide to part with them.
