Roll up cargo shade repair
Old 02-22-2017, 01:38 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
I was excited to find a vinyl cargo shade in the junkyard from another IROC, and immediately installed it in it's rightful place in the mounts in my IROC.
However, it worked great for exactly two days. The passenger side plastic cap looks to have broken where it attaches on the inside of my otherwise very nice shade.
Is there a way to repair the plastic cap, or is this something I could find somewhere? The shade is in extremely good shape, and I'm thinking it might be more likely to repair this one, than find an affordable other shade.
Additionally, I seem to have been having trouble keeping the two pins engaged into the trim piece on the hatch...is there a "trick" to latching this to the hatch, or am I more than likely looking at a trim piece that the slots are too worn to hold the shade?
Old 02-22-2017, 02:22 PM
t/aws61985's Avatar
Car: 85-6 TA 85IROC 82-6 MSE 15th/83pace
Engine: Slow ones
Transmission: 700R4/T5
Axle/Gears: Weak ones
Re: Roll up cargo shade repair
I would just hold onto it and find a 2nd shade. you can get them usually cheap when they pop up. The end caps are riveted on so it makes repair hard. Mine is Iffy too. has a bipolar attitude. All the shades used the same caps on the end.
Old 02-22-2017, 02:27 PM
t/aws61985's Avatar
Engine: Slow ones
https://www.thirdgen.org/forums/inte...acy-cargo.html
Only Restoration Thread I have ever seen on the topic.
Old 02-22-2017, 02:35 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
it's ashame you dont live closer. i've got one in very nice condition that i can't use because of roll cage, etc. i'd just give it to ya. if you want it and can figure out shipping, shoot me a PM.
Old 02-22-2017, 02:46 PM
Car: 1988 IROC-Z
I appreciate the thoughtfulness!
I'll see what I can figure out about shipping...FedEx has triangular tubes that are used for shipping things like blueprints...maybe they have something long enough to be shipped.
Old 02-22-2017, 02:54 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
that's what we do,...help each other.
Old 02-22-2017, 03:11 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Does you trim piece on the hatch have the metal backing behind those slots?
Old 02-22-2017, 04:09 PM
Car: 1988 IROC-Z
Yes. According to my RPO codes, my car originally came with the shade. The mounts were already in place when I bought the car, and I'd already verified the metal brackets were still there underneath, but the shade was long gone.
Old 02-24-2017, 08:55 AM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
You can slip two of those boxes together to make it long enough. USPS has them also, may be less expensive.
Old 02-25-2017, 03:36 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Before installing a privacy shade you must "wind" it up.
That puts a lode on the spring in the shade and allows it to retract properly.
Otherwise there just sloppy.
You push in on one of the ends with it rolled up and turn it until there is a lot of tension, then install it.
Old 03-13-2017, 07:13 PM
Car: 1988 IROC-Z
Yeah...the plastic on the passenger side totally disintegrated. Definitely going to have to replace it.
Old 03-28-2017, 06:10 PM
zero13's Avatar
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
How does one get the fabric out of the roller..if the end caps dont come off?..I bought a 2nd one to fix..I need to iron it,and dye it back to black..It rolls ok,but according to this thread,the fabric can be removed..Has anyone else confirmed this?
Old 03-30-2017, 02:27 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
You can drill the rivet/s out, but the piece behind it is a little fragile.With the cap off it's alot easier, but you can slip it out with the caps inplace.For that you have to pull the shade all the way out.It fits into a slot & will slide out if pulled.
The shade should not retract unless the ends are pushed in.As when installed on the vehicle.This releases the ratchet, so the shade rolls back up.
Old 03-30-2017, 06:51 PM
zero13's Avatar
Car: 91 Z28
I opened it fully,and locked it into the un rolled position..I hung it up on either end,taped all plastic parts and sprayed with a water bottle. Soaked it a bit and saw some filthy looking water drops off of it..I will take my steam cleaner to it this weekend, then I will spray with the black upholstery dye I purchased. I will post back results here. .....I didnt try to hard to pull fabric out of the channel for fear of ruining it.....
Old 04-03-2017, 04:00 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
I restored my vinyl cover using parts from my cloth one a while back. You can find info about it in my thread. I also found out how to get more power into the roll-back mechanism.
If your shade doesn't latch into the mounts properly, you may have to replace the smaller spring inside it.
Here's the according post:
https://www.thirdgen.org/forums/memb...ml#post5882485
Old 04-03-2017, 07:09 AM
Car: 1988 IROC-Z
Very useful stuff! I ultimately found a shade in excellent condition on Ebay for not an outrageous amount, but may try repairing the old one--thanks!
Old 04-21-2017, 08:05 PM
CamaroDoc's Avatar
Car: 84 Z28
Engine: tweaked '71 model 307 sbc
Axle/Gears: not sure yet
I ran across this thread a couple of weeks ago and I'm glad I did. Being new to the 3rd gens, I had no idea what the two mounts were on my interior panels when I removed them. Yesterday, I went to a swap meet and spotted a roll up shade on a vendors $5 table. Thanks to this thread and the restoration thread link, I knew what I was looking at. The guy told me it came out of some import. I didn't argue with him but the shade came home with me. It's a light tan so a re-color is in order for it along with all the other interior plastics in the car. I have been getting a lot out of these tech threads. Thanks to everyone who posts in them...
Old 05-13-2020, 09:50 AM
MacRocZ's Avatar
Car: 1989 IROCz T-top & 1988 Convertible
Engine: 350 TPI x2
Axle/Gears: 3.73/4.11
You still have that cargo hatch shade ?
Old 05-13-2020, 12:13 PM
zero13's Avatar
Car: 91 Z28
you talkn to me?...if so, i do have the cloth one i dyed...if ya want me to open n take pix,i will....ron
