How many miles is too many miles?
So this 89 I am looking at has 252,000 instead of 152,000. That's a lot more miles but at some point, its all just a lot of miles. The car looks great inside and out, runs, great, no rust etc.
Now I don't think it can be the original motor and transmission but if it runs fine, I don't care.
Are there any serious problems with too many miles on these convertibles?
UPDATE: Looking more closely at the CarFax, I am teasing out that the speedo must have been changed out twice. An average of 150 miles per day is too many over 13 months.
Here's what info I have:
10/07/13 6,969 Passed Emissions - This is accurate mileage I believe (106,969).
10/09/13 New Owner
01/06/15 79,302 Passed Emissions - 179,302 - 106,969 = 72,333 in 15 months (456 days) = 159 miles per day. This is too many. SPEEDO CHANGE LIKELY
03/26/15 New Owner
02/11/17 15,295 Reported from owner - 115,295 - 79,302 = 35,993 in 13 months (395 days) = 91 miles per day. This is too many. SPEEDO CHANGE LIKELY
10/09/13 New Owner
03/26/15 New Owner
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: How many miles is too many miles?
That may be one possibility. Another is that the sending unit at the transmission got swapped and there is a different gear on it. Of course driving it would answer all your questions because the speed would be completely off. It is unlikely, but the other component that the speed signal goes through is the buffer box. Being an '89, it should be an electronic speedometer; if not, forget everything I just wrote.
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Miles don't matter after 50k or so ($$ value). If the body is well maintained then; all other parts are interchangeable; other parts are probably well maintained, too.
Purchased 8/12/89. Stored car for winter 1/2/90 = 135 days. Mileage = 33,000 = 244/day. Too Many? NO! Out to Cali, up and down PCH, and back to Mpls on 1/1/90.
4 months old, and I drove my car into a tree Had to pull way over so my bro could get out the pass side to take the pic:
225,000 miles later and my car is better than new with an LS2:
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Thanks all. So I think I figured it out. It's a 5-digit speedo with a 10th dial. 79,200 was really 7,920. I am pretty sure the smog shop entered too many digits when they made that entry. at 107,920 that makes sense. Car has 115,200 miles. Now its looking good.
You're probably right. Either way, as long as everything operates as it should and car is in overall good condition, mileage isn't that big of an issue. The more miles you have on it, the more good times you've likely spent in it! What burns me up is people selling cars with 5-digit speedos as though the odometer has never turned over. "20K original miles" but looking at picks, it's clearly at least 120K miles. Either way, good to know the history some and what the mileage is so you can have an idea of what might need replacing. In the meantime, enjoy and keep logging the miles on!
Just a number people care too much about. Means nothing if the car is in good shape.
