Right Turn SIgnal issue (Video Inside)
Old 02-23-2017, 10:57 PM
B_Dubya's Avatar
Engine: 305 5.0 TBI
Transmission: 700-R4
I have read the other forums posts about flasher problems, however mine is something different.
Problem: Right side marker will not stay on. It does blink
Problem: Front right blinker does not blink, but it does stay on.
Problem: Right turn indicator on cluster does not light up.
Left side is fine. Hazards are fine.
1990, RS 305 TBI,
Any ideas? Any words would be greatly appreciated, it is my daily driver.
Old 02-24-2017, 02:33 AM
Twin_Turbo's Avatar
Re: Right Turn SIgnal issue (Video Inside)
Check the bulbs first but most likely a ground issue, clean the sockets for the driving/turn signals real good and use dielectric grease. had this on many thirgens and each and every one with turn signal problems including dash indicators being lit up all the time had the same problem, corroded sockets and or bad grounds on the rad frame
Old 02-24-2017, 08:36 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Are you using LED lights and an old style flasher unit?
