400 SBC TBI tweak
Old 03-14-2017, 03:57 PM
Mark Uptergrove's Avatar
400 SBC TBI tweak
I am running a 400 SBC using a 1227747 ECM. The engine has full headers, a high rise intake, and a TBI from a 350. I originally had the ecm programmed thinking I was going to use a 454 TBI on it (knock sensor is disabled due to false readings on 400sbc), but I was unable to find a 454 TBI..long story. It's running pretty smooth but lean with no CEL, but I was wondering what adjustments I may make for the 350 TBI (ie. IAC "Maximum IAC set to 'D7' currently)? Transmission is a 3 speed 350btw. I have attached a link to the bin file I read from my chip if this helps. I think there are some parameters that could be improved on (basically is a tweaked 5.7) Thanks! Eventually I will find a 454 TBI that doesn't cost an arm and a leg and will update accordingly.
File Type: bin
Old 03-16-2017, 02:29 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 400 SBC TBI tweak
Adjust your ve to compensate for your lean condition. A datalog would be helpful for ve correction. Injector flow setting may have been altered for the 454 tb injectors.
Old 03-16-2017, 02:35 PM
Engine: Lb9
Transmission: M20
You can identify your bin here and then do a file compare.
http://www.gearhead-efi.com/Fuel-Inj...Information-42
http://www.gearhead-efi.com/bithoist/query.php
Old 03-16-2017, 09:43 PM
Thanks, it is an AMUR0055 based chip with some tweaking (as you can see reading the bin) I did see where the BPW was set to default 135 for a 5.7, so I increased that to 156 in line with the 6.6L displacement. What 've' parameter were you referring to? My ALDL cable will be here next week
Here are the differences, my current bin is on the left column, value for stock amur0055 on the right
Old 03-17-2017, 12:31 AM
Engine: Lb9
Transmission: M20
Looking at both .bin I would start over with the AMUR. The spark table is more not so advanced like the 34-36 areas on your first .bin.
Work on your fueling first 0x37F main ve table.
once you datalog look at our blm and int divide 128 into the values then make the correction adding or subtracting the value.
once you have mastered this a few times I like to smooth the 3d graph.
Then move to timing add timing in a few kps/rpm areas at a time . If your knock retard was caused by a gear drive or noisy valve train I see why it was eliminated but I think you may have been experiencing knock retard. You can use the histograms to view the stated int/blm and knock counts.Making a spread sheet helps with tuning I have made ones that will average out missing values woks great for me. after timing changes go back and check fueling. Bogging during acceleration work on AE.Time consuming but worth the effort. Don't be surprised if it takes even 10 tries to get it dialed in. Hope all this helps
Old 03-17-2017, 08:48 PM
Hey, Bonus question for ya lol- I installed the 24 to 28 pin adapter so I can use the programmed 512 chips. I read the bin from the 24 pin chip that I am running now (backup400.bin i posted) I then wrote it to the 512 chip and verified it wrote. I put the 512 chip in, the truck fires right up and runs, but the service engine soon light is blinking really fast. If it were a programming issue the thing wouldn't even run correct? Could this be a start/end chip address issue or perhaps a pin isnt making good contact?
Old 03-17-2017, 09:35 PM
Engine: Lb9
Transmission: M20
Double check your 4k offset
http://www.moates.net/documentation....entation_id=75
Old 03-17-2017, 09:39 PM
Thanks, I have a few changes to make anyway. I plan to enable my knock sensor in addition to a couple of the mentioned changes. Hopefully my aldl cable shows up tomorrow!
Old 03-19-2017, 12:08 AM
Well, no cable today...I did install a heated o2 sensor (3 wire) I get an o2 service engine soon after reaching cruising speed, but it goes away and doesn't seem to do it idling. Are there any parameters that need to be adjusted for this change? Thx again. That cable better be here Monday lol
Old 03-19-2017, 11:28 AM
Engine: Lb9
Transmission: M20
What code 13,44,45 ?
Old 03-19-2017, 11:37 AM
Old 03-19-2017, 12:05 PM
Engine: Lb9
Transmission: M20
Oxygen sensor voltage stays between 0.35 and 0.55 volts for 60 seconds. I'm wondering if your lean condition is causing this.
Diagnostic mode is connecting a to b at the aldl and running the engine. Closed loop is fast flashing of the check engine light.
Old 03-19-2017, 12:08 PM
Good point. Definitely running lean.
Old 03-19-2017, 09:02 PM
I have verified the settings, and it says failed after I hit verify? Other steps seem to be successful.
Old 03-19-2017, 09:31 PM
Engine: Lb9
Transmission: M20
Not sure why it didn't verify, you might try erasing again and then reburning.
Old 03-19-2017, 09:37 PM
Dumb question..but if i erase the chip and it says succeeded, should it say chip is blank if I do a
blank check?
Old 03-19-2017, 09:41 PM
Engine: Lb9
Transmission: M20
Sounds like the sst27sf512 might be bad.
Unless the erase needs the chip start set to all zeros.
I haven't had this issues ever arise.
Old 03-19-2017, 09:44 PM
I just took it out of the static package new....perrrfect. maybe I need to by 30 of them LOL. I have another one I am going to try
Old 03-19-2017, 09:50 PM
Engine: Lb9
Transmission: M20
There usually good but I have seen a few fail when new.
Old 03-19-2017, 10:08 PM
I just tried the second chip, same results..odd. I can read stock chips just fine using the same programmer. Surely I don't have 2 bad chips?
Old 03-19-2017, 10:28 PM
Engine: Lb9
Transmission: M20
Odd maybe see if the sst verify the buffer as a 2732a.
Old 03-19-2017, 10:32 PM
It did !
Old 03-20-2017, 11:36 AM
Engine: Lb9
Transmission: M20
Originally Posted by Mark Uptergrove
It did !
Looks like the 400backup file was not loaded into the buffer.
This check was a compare of the chips data to the buffer not to the desired .bin .
Old 03-20-2017, 12:05 PM
Very correct, rookie mistake :/ I have tried several different bins, one being the stock amur0055.bin with the same results. I ordered a few more chips just to ease my mind but it seems I just cant get an erase/verify but can read all day long.
Old 03-20-2017, 12:15 PM
Woo hoo
Old 03-20-2017, 12:24 PM
Engine: Lb9
Transmission: M20
I can't remember but I think the 747 needs to be started in the 10k jumper mode to initiate data flow.
http://www.aldlcable.com/instruction...structions.pdf
Old 03-20-2017, 12:27 PM
Engine: Lb9
Transmission: M20
Moates support is great shoot them a email.
Old 03-20-2017, 05:45 PM
I'm about to fire up this bad monkey. What options should I select, and what coditio s do I need to run to collect the correct data? (Idle, 1200 rpm hold, down the highway, etc)
Old 03-20-2017, 07:53 PM
Engine: Lb9
Transmission: M20
Use tunerpro rt to datalog. I look at closed loop operation idle to freeway speeds steady accelerations. Win aldl data is hard to read.
Old 03-20-2017, 08:23 PM
Engine: Lb9
Transmission: M20
You can convert the ads to a adx with the acquisition .
Or the $42 adx is available at gearhead efi.
http://www.tunerpro.net/downloadBinDefs.htm
Old 03-20-2017, 08:58 PM
Ok, first attempt at logging!
File Type: zip
Old 03-20-2017, 09:17 PM
Engine: Lb9
Transmission: M20
was that with the 400backup.bin ?
Old 03-20-2017, 09:26 PM
yessir. I havent installed the knock sensor, I am still fighting these two new chips I can't erase/write. I offered to send one back to moates for my own sanity but havent heard back lol.
Old 03-20-2017, 09:35 PM
Engine: Lb9
Transmission: M20
I think your engine isn't warm enough to stay in closed loop.
Old 03-20-2017, 09:42 PM
I may have a 180 thermostat, I'll run it longer in a few minutes. I have a 195 I could put in if that is the case.
Old 03-20-2017, 09:48 PM
Engine: Lb9
Transmission: M20
I think the temp needs to be at 185f or higher , in the log its running about 178for so.
Old 03-20-2017, 10:15 PM
Ok, I definitely have a 180 Thermostat in it, I ran the dog out of it and 184 was the highest I saw before it dropped back down to 178-180. I'll get the 195 installed in there. I thought I swapped it out when i converted from carb but I guess not. Thanks again for the help.
Old 03-21-2017, 01:31 PM
Engine: Lb9
Transmission: M20
I didn't see in the .bin a set cl temp, some tunes are as low as 105f-150f. I'm really not sure why it goes into cl for a few seconds at a time. Some export tunes don't even use cl.
Old 03-21-2017, 02:04 PM
Interesting. Since I am unable to write chips, should I try the stock amur0055 chip or even the superchip with logging?
Old 03-21-2017, 02:51 PM
Eureka! I am able to write/erase chips now. Can you think of any parameters I can modify at the moment to try? I am adjusting the BPW to 156.
Old 03-21-2017, 03:13 PM
Engine: Lb9
Transmission: M20
I hope someone else will chime in on cl I don't know if o2 swings has something to do with it as well. Btw do you have a vss ?
Old 03-21-2017, 03:16 PM
Vss is disabled (3 speed no cruise) I am installing g the knock sensor so at least it will be physically hooked up in case I need to enable or disable.
Old 03-21-2017, 03:24 PM
Engine: Lb9
Transmission: M20
You might want a vss
http://paceperformance.com/i-1900680...sor-60115.html
http://www.jagsthatrun.com/V8-chapte...ed-Sensors.pdf
Old 03-21-2017, 03:29 PM
I'm going to look for that little green box lol...not sure if I saw vss disabled in that 400backup bin
Old 03-21-2017, 03:33 PM
Engine: Lb9
Transmission: M20
050d post #2, this will really help with iac control especially on deceleration.
pin a10 of your ecm.
Old 03-21-2017, 04:34 PM
Engine: Lb9
Transmission: M20
35c, COOL Min for CLS LP Enable
Not at home to review the datalog but it must be o2 signal related.
Old 03-21-2017, 04:57 PM
Vss?
Old 03-21-2017, 05:03 PM
Vss?
Old 03-21-2017, 05:11 PM
Double post, sorry. Wow so some guy may have reversed the ground and sending wire on the 3 wire o2....
Old 03-21-2017, 07:02 PM
Engine: Lb9
Transmission: M20
Not sure what we're looking at lol
