Footwell heat normal?
Old 03-18-2017, 09:43 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
My car gets warm down there. I blocked off the heater and it still got warm. Is this normal and if so, has anyone tried to cool it off?
Old 03-18-2017, 09:48 PM
NoEmissions84TA's Avatar
Re: Footwell heat normal?
Your cat converter is under there if you still are using it.
Old 03-19-2017, 09:50 AM
Engine: 350 TPI L98
Transmission: WC T5
Yeah, but isn't that on the passenger side?
Old 03-19-2017, 08:23 PM
How did you block off the heater?
Did you block the hot air, or cut off the coolant to the heater core?
Old 03-20-2017, 09:37 AM
Engine: 350 TPI L98
Transmission: WC T5
Coolant hose. The one that runs into the firewall over the passenger side valve cover.
Old 03-20-2017, 08:19 PM
Then if there is no heat coming from the heater core, it must either be hot air from the engine compartment, or heat radiated through the floor from the exhaust.
Old 03-21-2017, 05:29 PM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Easiest way to cut off the heat drift and hot water flow to the heater core
is to buy a manual water valve. Used on many older a/c equipped GM
cars.
Install in heater core supply line and minutes and switch off the water
flow.
Only $10 bucks: http://www.partdeal.com/red-dot-heat...&zmap=77157165
Old 03-21-2017, 08:44 PM
That's a pretty good idea. And inexpensive too.
Old 03-21-2017, 09:26 PM
Engine: 350 TPI L98
Transmission: WC T5
Yeah, what's funny is I cut it off in the engine bay and it still got plenty warm down there.
Old 03-22-2017, 04:29 AM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
You gotta make sure that the valve is installed on the flow entrance side
or else the heater core will always be hot.
Also mentioned above the cat converter is under the pass. side.
Old 03-22-2017, 05:41 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Did you remove the air dam?
That made a big difference for me, much cooler with it on...
I have a fiberglass KR nose with openings up front for headlights, I thought that would be enough air to cool, but it wasn't... Put the air dam back on, much cooler foot wells / trans tunnel, etc...
Rafael
Old 03-22-2017, 08:35 AM
Engine: 350 TPI L98
Transmission: WC T5
Rafael
Interesting. My other thread is about my car overheating and another member said the airdam (ducting) ahead of the radiator is crucial. I haven't had a chance to look but I will soon.
Old 03-23-2017, 09:32 AM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
The airdam is a important part of keeping the engine/coolant/etc.
at proper operating temps. and prevent overheating.
Old 03-23-2017, 09:44 AM
Engine: 350 TPI L98
Transmission: WC T5
Here's what I've got. Looks like it's all there:
Old 03-23-2017, 10:03 AM
naf
naf's Avatar
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
nope. air dam is missing. it's not shown in your break-away diagrams.
https://www.thirdgen.org/forums/exte...d-air-dam.html
Old 03-23-2017, 12:29 PM
Engine: 350 TPI L98
Transmission: WC T5
Is this it?
http://www.hawksmotorsports.com/cama...iator-air-dam/
Old 03-23-2017, 07:16 PM
A piece of heavy-duty belting, at least 4-6" in width, fastened across here
will help deflect the air up through the radiator's core. See attached.
Old 03-23-2017, 07:20 PM
Engine: 350 TPI L98
Transmission: WC T5
Awesome. I found a guy nearby that has the dam and the rectangular pieces to the side also.
