[AL] 1990 Pontiac Trans AM GTA
REDUCED FOR QUICK SALE $2000
Selling my sons, now mine, project car.
1990 Pontiac Trans AM GTA, VIN: 1G2FW23F2LL214998, 350, 700r4 Transmission, T-tops. Project started awhile ago and have no time to finish. Rear seats need recovering. Includes original 305 ci engine(on stand) and rebuilt 350 ci engine. 350 is in car and has never been started, only manual rotated.
List of mods and work to new motor listed below. Rebuilt engine 85% completed, have all parts to finish. Two months ago while test threading new stainless steel bolts I dropped one in the base plate and have not been able to get it out. Wheels, hatchback, and front clip are not GTA correct. Previous owner wanted to make it look like KITT from TV show "Knight Rider". Car was last driven November of 2011, has been in my garage since.
350 Motor: ZZ4 Engine Block: bored .30 over, SN: 10243880, 4 bolt main, laser etched 03/31/00 02:01 on bottom rear, crankshaft was balanced and polished, hypereutectic pistons, smog pump delete pulley kit.
Intake and Runners: Edelbrock High Flo TPI Base plate part #: 3860, Edelbrock High Flo runners Part #: 3870. Original Plenum is ported to match High Flo runners and clear coated. Has all new fittings.
Fuel injectors: Bosch 24lb EV1 High Impedance (Gen III)
Cam shaft / Lifters / Rocker Arms / Timing Chain: Comp Hyd Roller Camshaft #: 08-302-8, serial #: VH3200-10, grind#: CS264h-R12, Comp High Energy Hyd Roller Lifters, Part # 850-16, Comp Magnum Roller Tip Rockers, part # 1417-16, Comp Magnum Double Timing chain, Part # 2136, Comp Springs, Part # 983-16, Comp High Energy Pushrods, Part # 7808-16
Thermostat: 160 degree Hyper-tech with a matching fan control sensor (175 deg on /off at 166 deg)
Water Pump: Summit Super Cool, part # SUM-31267S
Oil Pump: Melling Stock replacement Oil Pan: Dorman Stock
Starter: Power Master Powermatic Mini Starter part# 9200
All new belts and hoses, new aluminum water neck, new coolant tank, 2 new headlights, Edelbrock chrome valve covers (not installed), stainless steel bolt kit for base plate and plenum. New Transmission mount, New weld in UMI Performance sub-frame connectors and UMI Performance steering brace(both new in package).
$3665.15 - For parts that I have receipts for. $1400.96 for Speed shops work on new engine.
Vehicle mods since purchase:
27 Nov 2009 - Transmission rebuilt with a mild shift kit installed with new U-joints. $1520
28 Dec 2009 - A- pillar engine gauges installed. $275
14 Jun 2010 - 4 new Firestone Firehawk Indy 500 RWL tires. $390
July 2010 - Front Clip repainted as well as both fenders. New side marker lights installed. Replaced Headlight Bezel, installed new door weather-stripping. $1150
16 Mar 2011 - New Distributer and Spark plug wires. $398
July 2011 - Installed new T-top weather stripping. $218
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Re: 1990 Pontiac Trans AM GTA
would you be interested in selling the Edelbrock base plate and runners?
You know what they say.. Great minds think alike haha
I think you are mistaken, it doesnt appear to be a GTA unless all the things that make it a GTA were replaced with normal trans am parts. Look for the RPO code Y84, if your RPO list doesnt have that then unfortunately its not a true GTA
Car is in Huntsville, AL. I only have the seats that are in the car, not sure if they are originals that have been recovered or not, as I've never researched or seen what original seats look like. No side skirts.
