Stock manifold vs Mid tube vs Long tube results.
Old 03-22-2017, 09:30 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F
Axle/Gears: Zexel Torsen 3.73, 28-spline mosers
Engine Master Header Challenge:
The logs shown cost roughly $369. The Mid tubes roughly $600 and Long Tubes are $1000.
they gain only 9 HP and 12 tq over the mid tubes and 40 HP and 20 tq over the iron manifold.
So based on the results, are the long tubes worth their $1k price tag?
I would have a hard time justifying it.
Engine Masters Header Challenge
Old 03-22-2017, 09:55 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Stock manifold vs Mid tube vs Long tube results.
i think it would have been interesting to see mid-length headers with the same size collector and pipe size. i hate when they're trying to compare apples to oranges.
Old 03-22-2017, 09:59 PM
Ozz1967's Avatar
Car: 1984 Trans Am
The point being Long Tubes don't gain as much over mid tubes as everyone seems to think.
Old 03-22-2017, 10:59 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Look at the 3000-4500 rpm range. LT's picked up substantial power. You will notice that if you want a tight converter or are a manual trans car
Short primary lengths cater to high rpm. Thats where the tuned wave reflection effect starts to work. Long primary lengths are tuned for lower rpms, typically. Thats why you see the big jump in botom end but because of the diameter and collector size, the long tubes still can pass the flow and dont lose power up top to the short/mids length stuff.
Long tubes typically are for overall curve shape. Superior bottom end. If you drag race and had a high stall converter then that low end may not mean much.
They each have their place.
Old 03-23-2017, 06:10 AM
Ozz1967's Avatar
Car: 1984 Trans Am
I looked at it again and I just can't wrap my head around it being with the additional $400-500 for long tubes for that relatively small gain.
Old 03-23-2017, 07:09 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
40+ lb ft change on a 500 hp motor is huge!!!!!
Old 03-23-2017, 09:05 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i think the difference would have been smaller if the mid-length headers had 3" collector and pipe diameter. or if the long tubes had the same small 2 1/2" diameter.
the torque down low is great for a daily driver. worth that much more money? it'd be hard to say without a true comparison.
Old 03-23-2017, 01:20 PM
3rdgenmaro's Avatar
Car: 88 IROC
Transmission: 700 r4
Looks like those cast manifolds flow would flow a lot better then many of the stock manifolds.
Old 03-23-2017, 01:22 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Yeah it's possible. They only have 2.25 exhaust ports though.
Old 03-24-2017, 05:30 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Kind of makes those BRP Hotrods mid-length headers look good with my LQ9 build, also I believe they do have a 3" collector. I bought some of the Racing Innovations headers and what a poor fit.
Old 03-24-2017, 06:05 PM
Ozz1967's Avatar
Car: 1984 Trans Am
As Orr89rocZ says, if you take away the peak, , the usable rpm range is hugely different between the mid and long tube headers. 40HP/tq or so from 2500-4500. That's where you have to judge the long tubes at. Not so much the high end peak number.
Old 03-24-2017, 06:07 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I'm also building an LQ9. What's wrong with the Racing Innovation Headers? Can't beat the price on them for long tubes. I've been eyeing them as a possibility along with the BRP mid tubes.
Old 03-24-2017, 08:33 PM
92BLKL98's Avatar
Terrible fitment at the sub frames, the collector touches on the right side and only about 3/8" clearance on the left side. Several pics I've seen on this site shows the same fitment issues I had so I know it is not a production variance in the car like the guy at RI says. They do look nice and from the top of the engine compartment but when you go underneath they don't work. I've seen some guys wrap them with cloth wrap but that is a cheezy way to approach the problem. I'm now weighing on the Hawks SW headers or maybe the BRP mid lengths. I'm not building a car to compete with a full on race car just fun on the street, so it may be the mid length headers.
Old 03-24-2017, 08:37 PM
Ozz1967's Avatar
Car: 1984 Trans Am
​​​​​Wow, OK. Thanks for that great review! Cross them off my list of headers. That leaves me with the BRP mid length or the Hooker Black Heart long tubes. Good thing I don't have to make a decision just yet.
Old 03-24-2017, 08:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Tell you what, my buddies heads cam ls1 4th gen ta ran mid 11's at 120 mph with mac mid lengths. Ran harder then most other guys setups around here with long tubes
Mids can work, especially with highstall converters. Wont see low end rpm much
Old 03-24-2017, 08:51 PM
92BLKL98's Avatar
So you're saying they aren't that good on the street, I plan on a 3000RPM Vigilante converter.
Old 03-24-2017, 08:53 PM
Ozz1967's Avatar
Car: 1984 Trans Am
As am I.
Old 03-24-2017, 09:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Mids will work fine on the street. Higher hp motor you build the more longtubes seem to help down low because the cams are generally bigger on higher hp builds, which generally hurts low end power. But everything is a system so it all has to work together.
Mids with good collector size will support good power just not quite as much torque in the lower rpm to mid range areas. As seen in the vid. You gotta determine how much torque you want/need. Heavier car may like longtubes better. But if you have a stout build with good heads and good compression, its gonna make torque regardless. And there is such thing as too much torque on the street. Even bolt on ls1's making 320 wtq can be trouble without a good tire
Old 03-25-2017, 11:58 AM
Street Lethal's Avatar
Hopefully you meant a 2.25" collector, as a 2.25" port/primary is huge...
Old 03-25-2017, 12:00 PM
Ozz1967's Avatar
Car: 1984 Trans Am
haha yes I meant collectors.
Old 03-25-2017, 12:06 PM
Ozz, you need to consider the overall build. Nobody should install LTH and expect magical numbers, it comes down to stall speed, cam specs and gearing. This is how you choose the right system. LTH have way more potential overall than the other two choices, but you need to compensate for them in the right areas to reach their full potential. Stock-ish cam, average intake, and low stall speed, then yes, mid tubes all the way.Then again, there is no denying the LTH exhaust note, regardless...
Old 03-25-2017, 12:10 PM
Ozz1967's Avatar
Car: 1984 Trans Am
agreed. When my build went sideways after learning my JY found headers were garbage, I wound up with a set of ported and polished 243's for my LS swap. Of course then I couldn't leave the Cam alone.
so now I'm trying to justify saving the extra $400 on the Mid tubes vs long tubes but seeing the gains in the true usable rpm range and not just peak, I. Starting to consider the extra money is worth it.
Old 03-26-2017, 09:45 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
My chance to learn something guys...So Mid length...not seen many of those. Looks like a shorty with a more traditional style collector on it? Just going by the picture in the video.
Old 03-26-2017, 10:23 AM
Ozz1967's Avatar
Car: 1984 Trans Am
kind of. Longer primaries as well. Stops short of long tube length as they were designed for swaps with ground clearance issues IIRC. Gives you nearly long tube power as you can see in the video.
