83 Camaro Base diff is????
Old 03-27-2017, 10:42 AM
thrdgncamaro's Avatar
Car: 1983 Camaro Base
Engine: 4.8 LS POWA and CHINA boi turbo
Transmission: TH350 w/ Shift kit 3200 stall
The code sticker in the glove box is gone, I've searched for a casting number on the diff housing but its unreadable. Im having a hard time finding out what diff this car came with stock without pulling the cover. Im assuming because it was a V6 it probably came with 3:73 but im not sure. Any help is good help. Thanks.
Old 03-27-2017, 10:47 AM
sprojam's Avatar
Car: 86 Z-28
Engine: 355 small block XR276HR roller cam
Transmission: TCI built 700r4 2000 lockup stall
Axle/Gears: moser axels auburn posi 3:73 gears
Re: 83 Camaro Base diff is????
GM 10 bolt
Old 03-27-2017, 10:53 AM
sprojam's Avatar
Car: 86 Z-28
th350 has 1 to 1 final ratio so you will be tacking well above 3000 rpm at 70 mph with 3:73 gears and I don't know of any other way of narrowing it down with out pulling the gear set.
Old 03-27-2017, 10:54 AM
Drew's Avatar
Count the cover bolts. Pop the cover and look for the stamp on the ring gear, or count the teeth on the ring gear and pinion.
Probably not 3.73s. 3.23 or 3.42 would be a lot more likely with the V6.
Edit: If you really want to avoid pulling the cover (do it anyway) you can mark a tire, and the driveshaft. Turn the driveshaft and count how many times the tire turns. It'll give you a rough idea. But go ahead and pull the cover, the gear oil is probably due to be changed anyway and you'll know for sure.
Old 03-27-2017, 10:57 AM
Thanks for the help!
Old 03-27-2017, 11:03 AM
GeneralDisorder's Avatar
Well based on the engine in your profile you definitely need to open that up and swap in some posi. And some 28 spline axles. Before it grenades.
Rick
Old 03-27-2017, 11:10 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Old 03-27-2017, 11:16 AM
Im going with its got 3.23 since I've got a 700r4 laying in the garage that the guy i bought the car from said its the OE trans. GREAT info thanks so much!
Old 03-27-2017, 11:17 AM
Any suggestions on a god replacement unit for my set up? I want to drive it but i dont want it to be a pig either.
Old 03-27-2017, 12:04 PM
sprojam's Avatar
Car: 86 Z-28
moser has a 12 bolt rear end for these cars for 2500 bucks may want to look at verses trying to beef up the 10 bolt witch is only good to about 425 hp and if you like hole shots and a above stock torque convertor don't waist your money on beefing up the 10 bolt. also 700r4 stock sun gear is a disaster waiting to happen worth the effort to replace. these observations are based upon my experience only.
Old 03-27-2017, 01:42 PM
big gear head's Avatar
Sometimes the sticker is on the back of the spare tire cover or jack cover or in the console.
Keep hard street tires on it and the 10 bolt might live. Quick Performance has a nice package with a Yukon Dura Grip, gears and a USA Standard installation kit for a good price. I'd recommend trashing the 26 spline axles and get some 28 spline axles.
Old 03-27-2017, 03:26 PM
Drew's Avatar
83 didn't have a SPID, they didn't start putting them in until 1984.
