Will This Posi Carrier Fit My 85 Z28
Axle/Gears: 4:10
The attached link is for a posi-diff and gears out of a S-10. I was wondering if it will fit my 1985 Z28. Thank you in advance for your input.
Respectful Regards,
http://m.ebay.com/itm/GM-7-5-7-6-Eaton-Gov-Lock-10-Bolt-Posi-373-3-73-Gears-28-Spline-Chevy-S10-locker-/191913314940?nav=SEARCH
Respectful Regards,
Re: Will This Posi Carrier Fit My 85 Z28
I agree, you do not want a Gov Lock. Look up Quick Performance on ebay and get their package with the Yukon Dura Grip, gears and USA Standard installation kit.
Axle/Gears: 4:10
Thanks I will check it out in a couple of days. In addition to the differential cover, I will be looking over the axle tube for a gear code.
I have only owner the Z28 for a month and have already done a heads and cam (25 hour thrash!!!). Exhaust is next and then a 3:73 gear. Still has greasy hand prints from the weekend.
Assuming you have the 7.5 10 bolt, you need to pull the axles out before you order any parts. If the axles are worn where the bearings run on them then you need to replace them too. No point in putting 26 spline axles and differential in it when 28 spline parts cost the same and are quite a bit stronger. Now is the time to upgrade.
Except that Auburn just told me last week that the weak link in these rears is not the axles -
it's the small diff side gears and the small ring & pinion.
The pinion gear gets really small if you have 4.10s.
Ring & pinion usually goes first in the 7.5, but no point in putting 26 spline parts in if you have to replace them anyway. 28 spline stuff is the same price and stronger. I'd rather be sure that the gears are going to break before the axle. When the ring & pinion break it doesn't tear the quarter panel off and cause you to crash.
Yeah the 2 pinion side gear design is much weaker. But if you get a Torsen carrier there's no side gears anymore.
GM used the same diff on the 99 to 02 WS6 with LS power, T56, and zexel torsen carrier. They can hold decent power. It's no drag race diff.
The 9 bolt can be upgraded to the same or a little higher power. They have 28 spline axles already, larger ring gear, and a more rigid case design. The Torsen carrier for them is about $500 shipped from Australia. You can get 370 gears easily. Other ratios from Australia also. They get used on 500 wheel HP commodores over there routinely and are pretty well respected.
TA makes a girdle cover for them.... etc.
People talk a lot of trash on the 10 bolt, not as much, but still on the 9 bolt - realistically what power level are you going to be at?
Rick
Rick
That is why I did mine, my old axles were worn on the bearing surface after 32 years of use. No reason to not upgrade
The axles on the 9 don't don't wear like that either. They are Timken tapered roller bearings pressed onto the axles making the axle not a wear item. Also they are retained by a heavily interference fit sleeve and a bolted retainer plate making them "clipless" and they will not fly out of the axle tube if they should break. Basically they are stock with C clip eliminators.
Rick
Rick
