carb identify
Car: 1986 Pontiac Trans Am
Engine: 5.0
carb identify
hello im kinda new to carbs (my last carb car was a 77 Mustang II like 7 yrs ago) i just picked up this 1987 Trans Am that had the carb replaced. anyone have any info on this carb? what is it? is this a stock unit? does anything look out of place?
reason i ask is the transmission shifts harsh. its not late or anything just hard even harsh shifting into D. i though maybe a TV cable adjustment but the cable looks ok
Re: carb identify
That is a stock replacement for the factory carb. If in doubt just readjust the TV cable it is easy enough to do
Engine: 5.0
Re: carb identify
Re: carb identify
Here it is
https://www.thirdgen.org/detent/
Also it looks like you have a vacuum port or two open. If those are sucking in air then you should put a plug on them
Engine: 5.0
Re: carb identify
does this carb have an electric choke? meaning im not supposed to depress the accelerator to engage? she will not start on her own i usually have to give her some gas. maybe choke is not working right?
Re: carb identify
Harsh shifting is a classic symptom of a failed or disconnected vacuum modulator. The modulator "lives" on the transmission, and has a vacuum hose coming up to the engine. I'm betting since you have open vacuum ports, it's probably not even connected. Get under the car, find the modulator, then follow the vacuum line, and confirm it's connected.
Engine: 5.0
Re: carb identify
where is it located on the transmission?
update: so doing more research i see that since my car has the TV cable i do not have the vacuum modulator valve, am i correct in the statement? anybody have a diagram of there these to open ports on carb connect to?
Re: carb identify
The procedure I was taught to start a cold engine, you should turn on the key, wait couple seconds, depress the accelerator pedal to the floor once and let off. This will set the choke flap and put the proper amount of fuel in. Then turn the car over. If car does not start right away (less than 10 seconds) on colder days, I will repeat and try again. The only time I had to do it more than twice was trying to start it at 10 below without it being plugged in.
In the 75 owners manual I looked at last night, it said on extremely cold days to depress the pedal two or three times at the start. When I mentioned that in my drivers ed class waaaay back, the instructor said no you would flood the car. I just learned this week, you only need to depress 1/3 of the way unless it is cold out.
Regardless, you need to depress pedal to set the choke flap even with an electric choke.
Engine: 5.0
Re: carb identify
i just got back from doing the TV cable adjustment, i dont have the vehicle legal yet as i just got her 2 days ago but i did start her let her run for couple seconds and shifted to reverse. it was a smooth shift to reverse and didnt have to floor the brake to keep the car stopped. i shifted to drive and got same results so hopefully that solved the problem. once i get my insurance ill take her for a test drive and see how the gears shift. keeping fingers crossed lol
thanks for the info ill keep doing what im doing then
It does have electric choke.
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: carb identify
The one open port that is high on the carb is for the air cleaner vacuum tube. The open port on the bottom is for the CCV which is missing. It looks like the tube that would normally go to the valve has been replaced with one going directly to the charcoal canister. Just a note here for the OP, 1987 was the last year for carbureted engines in F-body cars. And your engine should be a roller rocker type if it is the original 305. You are correct about the vacuum modulator; there isn't one. If your TV cable is adjust properly, then it should shift into overdrive around 35mph. The overdrive function does not work until the engine has warmed to operating temperature. The same is true of the newer vehicles with the 4L60E transmission (found in 90s trucks). This temp signal comes from the temp sensor in the driver side cylinder head, so make sure that works.
Another thing I noticed was that the temp switch for the EFE valve is broken off in the thermostat housing. If you live in a warm climate, then that isn't really an issue. But if you do live somewhere that gets cold in the winter, the EFE system comes in handy. The valve is located at the end of the passenger side exhaust manifold. If it is still there, it may have been locked in the open position. If you have headers, then it is gone, as it will only mount to stock manifolds.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Re: carb identify
And the TV cable is not a "detent" cable. Don't call it that, because that's not what it is (even if the linked tech article calls it that). This explains it all very well: http://www.tvmadeez.com/article/index.php
The open vacuum nipple on the front of the carb with the "T" goes to the air cleaner. If you don't have a factory air cleaner, cap off that open nipple.
The vacuum nipple on the front of the carb under the large vapor hose goes to the vapor control valve, which appears to be missing on your car. I'd suggest capping it off as well.
There is also supposed to be a nipple just in front of the accelerator pump rod, which appears to have some sort of goober over it. Hopefully it is sealing well.
This is a computer controlled carb (factory called it "computer command carburetor"). It needs a signal from the O2 sensor to operate correctly. That wire was routed by the factory in front of the carb. With all the clipped wires in there, I hope that isn't one they cut.
The EGR vacuum hook-up isn't correct, either. It's supposed to go to a solenoid, which doesn't appear to be there. The vacuum hose for that is supposed to go to the EGR solenoid appears to go down to the EFE valve on the exhaust manifold, and the EGR valve is tee'd to the PCV valve.
All in all, it looks pretty messed up.
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: carb identify
That "goober" that five7kid is referring to is covering a screw on the carburetor cover. I just looked at mine and there is no port in that area.
The O2 sensor input is important and hopefully you still have that. Otherwise the carb will stay in "open loop" and your engine will run rich all the time. In other words, bad gas mileage.
I would take a guess that the previous owner of your car removed all the emissions equipment. And it would appear it wasn't done in a methodical or intelligent manner. We are here to help you get it back to a reliable and safe condition. Ask questions and we will provide guidance and photos to help.
Engine: 5.0
Re: carb identify
yes the PO had all the emissions removed. he told me that when i asked him about the check engine light thats illuminated on the dash. he said the light was for o2 sensors but all the wiring was removed so i may be screwed on that one, ill have to check to make sure. there is no emissions testing here in MI so thats probably why its all gone. what should i do? i want the light off in the dash and i want the car to get into of closed loop and get good mileage.
shes a summer car for me and will only be taken on cruises and car shows (im a member of USMA) so cold temps dont matter to me
Engine: LS1/LQ4
Re: carb identify
Engine: LS1/LQ4
Re: carb identify
Different years had different vacuum ports. '87 should have it, but no guarantee this carb is an '87 (I can't read the carb # from the pics posted). Regardless, the carb will work when all the inputs are there (I bought an all-stock '82 from California in which they had replaced the carb with an '87 model - I was able to get all of the vacuum stuff working, and when all adjustments were to factory specs, it ran great and passed emissions with flying colors).
Re: carb identify
Harsh engagement into reverse or OD/drive is kind of normal for this vintage 700R4. The TV cable and its adjustment will have no effect on this.
IIRC, GM addressed this sometime in early 1987.
It could also be that the engine might be running at fast idle (when cold) when you put it in gear and this will also make engagement feel harsh (which is also normal).
Engine: 5.0
Re: carb identify
It's been awhile, but I believe the light blue wire that is clipped off on the passenger side harness is the O2 sensor. Whichever it is, you should be able to get a repair pigtail to get the O2 sensor back working. Can't see what your exhaust is from your pics, but from the factory it's in the driver side exhaust manifold.
I believe you are right about that being on a screw.
the engine runs at about 900 rpm even when cold so i doubt the choke is even working if it is it just starts the car, doesn't raise prm to keep running
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: carb identify
The O2 sensor wire should be in that taped up bundle sitting right in front of the carb. It is a dark blue wire I believe. It would be running across the driver side valve cover to the oxygen sensor located in the driver exhaust manifold. Normally there is a harness plug for the sensor to connect to. In the photo I've attached you can see the harness connector and the wire going down to the sensor.
The transmission going into gear with a "thunk", I found to be caused by a loose cross member trans mount bolt. So every time I'm under the car for an oil change, I simply tighten it up. But this is a common thing with the thirdgen F-body.
Your carb identification number is stamped in the body near that sticker. If you look at the flat portion directly in front of the sticker, you should see a number beginning with "1708". The entire number can be deciphered to tell what year the carb was made and if it is for a manual trans or automatic.
Engine: 5.0
Re: carb identify
do you have a diagram of the o2 wiring i wanna see where it goes since the PO told me they pulled all the wiring.
http://www.ebay.com/itm/Oxygen-O2-Se...1RsTES&vxp=mtr could i just use this as replacement wire?
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: carb identify
This diagram from the FSM shows the harness routing which should help you. It also calls out the wire color as purple (PPL), but if so, it is a dark purple. The item listed as "B" is the O2 sensor.
That sensor that you show has a "weatherpak" connector. That came along in '86 or '87 and you would need the female part of the plug to make it work. Our cars use single wire sensors, so it isn't critical to use a factory connector. When I replaced my sensor, I just bought a generic single wire. There are a few different manufacturers.
Engine: 5.0
Re: carb identify
So I just pulled the codes (should have done that earlier instead of listening to previous owner and wasting all your and mines time) I got a code 15 and code 23
The o2 sensor is present as is the wiring. I saw the EGR piping has been chopped going to the back of the head
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: carb identify
Code 23 is M/C solenoid voltage low to ECM.
The mixture control solenoid is that blue plastic item on top of the carb. Check wiring, if that is good, check the ECM fuse as it may be blown. When you turn the ignition key to the ON position, the M/C solenoid should be heard making a clicking sound.
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
Re: carb identify
Hey gearhead141.....you wouldn't happen to have a pic of that cross member trans bolt that keeps loosening up on you?
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: carb identify
This is a photo I captured off the internet. You can see the crossmember directly behind the trans pan. I don't recall now if it is a nut or a bolt, but you can clearly see it.
Car: 1986 Trans-Am
Engine: 305 4 bbl
Axle/Gears: posi
Re: carb identify
Engine: 5.0
Re: carb identify
instead of making a new thread i though i would post here
would this be ok to use in my carburetor? E4ME
Re: carb identify
It should not cause any harm seafoam is my weapon of choice for carburetors
Re: carb identify
I read 17087130. This carburetor came Factory on 87-88 Camaro, Monte Carlo LS, Caprice & Caprice Classic. Although this carburetor will also fit other makes/models listed on the fitment chart based on the Tomco carb replacement chart.
Engine: 5.0
Re: carb identify
so to bring this thread back up, i just ordered a CCV and purge valve to get everything back to normal again
i just finished re installing the AC in my car and i must say the engine bay looks very respectful. now im working on the vacuum lines and im gonna remove the TVS and put a brass plug in its place to help clean up the engine bay some more since this car will be going to car shows.
not really what i had in mind for this car, every time i finish something i find more that has to be done, but the car has to be right in order to give me a few years of service and enjoyment. ohh well its a labor of love
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: carb identify
Once you get it all sorted out, take a few pics so we can all see your hard work. You must have found a donor car at the salvage yard. That could be the only explanation for such a cruddy CCV. A lot of people on here are always asking about removing the emissions equipment. There aren't as many that ask about putting it back on.
Engine: 5.0
Re: carb identify
Engine: 5.0
Re: carb identify
quick question the vacuum switch mounted in the intake manifold seen in this pic.
is it used for the evaporative emissions control?
Re: carb identify
Yes, it is the canister purge TVS.
Engine: 5.0
Re: carb identify
so doing more research i dont think i need the valve in pic 1 since i thought that was the purge valve seen in this diagram but its the TVS switch mounted on the intake. the one thats by the charcoal canister i believe is still present on my car. so looks like i just need to hook up the CCV and connect the purge TVS from second pic. should clean up engine bay a little and make use of the open vacuum ports
Engine: 5.0
Re: carb identify
So I have had a change of heart and decided to go in a different direction. In instead of putting it all back I decided to scale it down and cap off the rest. I only have the canister and the EGR connected. For the canister I just have the fuel bowl vent and I replaced the lines. Everything has been capped off.
Further more I removed both TVS switches and got 1/2 and 3/8 brass plugs. The last hurdle I have to go through is the stupid EFE heat riser valve still on the exhaust. And a small diameter tube that looks ugly as hell cause it's chopped off going into the engine. I believe it was for the EFE system or smog pump. It was the metal line that went to 4 ports on exhaust manifolds either way I want it gone along with HRV
Right now I'm gonna take the air cleaner and AC dryer home clean them up and paint black to help clean it up
Re: carb identify
For the exhaust manifold heat control valve, take it out, remove the plate and tap the hole where the shaft was for a 1/8" pipe plug.
You need to have your gas tank vented. If you don't, it will either build up pressure, or a vacuum will be created as the fuel gets used, making your pump unable to do its job. You can prove this by removing the gas cap after driving around - there will be a whoosh sound. That is air entering the tank from a vacuum situation, or gas fumes will blow out from escaping. You should keep the charcoal canister and CCV canister control valve, at least. The green top TVS is the control for this system. See these posts:
https://www.thirdgen.org/forums/carb...e-routing.html
https://www.thirdgen.org/forums/tech...grams-i-5.html
see post #221
see post #221
Engine: 5.0
Re: carb identify
i still have the canister in the car and its attached to the carburetor by means of the fuel bowl vent. the tank pressure control valve is also still attached and going to a vacuum source on the carburetor i just dont have the CCV, the purge TVS, or the EFE system. i have the pressure valve hooked to "H" on the YCX hose routing pic seen in post 36
i have all the stuff but after i discovered the purge TVS was broken i decided against installing all it. the tank can still vent this way right? if its a problem ill hook the CCV up but the purge TVS is broken and i am having a hard time finding a replacement
Re: carb identify
The tank will vent without the purge TVS, just full time. That valve is supposed to open at 170*F. By your hookup description, you should be fine.
Engine: 5.0
Re: carb identify
see post #221
see post #221
Re: carb identify
You have to at least partially drop the y-pipe to get the heat control valve out. Get new gaskets. Depending upon how much rust and corrosion you have, that will determine how hard this job will be. Use RED loctite on the 1/8 pipe plug. Spray the bolts and studs for a couple of days with your favorite penetrant before you tackle the job.
Engine: 5.0
Re: carb identify
figured i would get some pics of my progress. im still waiting on the high pressure line for the AC and gotta deal with the heat valve
Re: carb identify
So much cleaner without all that crap in the way.
Did you find the correct plugs for blocking off the ports in the exhaust manifolds from the air injection?
Engine: 5.0
Re: carb identify
no they have bolts in there that protrude out (from PO) i was just gonna get the same plugs i used for the TVS switches. do they make actual plugs for those ports?
side note, i still have the tank pressure control valve on the canister. do i need that valve? will the system still vent without it? or is fuel gonna be getting into the canister? i also read im supposed to put a fuel filter in the fuel bowl vent line to keep charcoal bits from entering the engine is this true?
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: carb identify
5/16" inverted flare. You'll see the the mating surface for the flare when you remove the existing.
your tank has an over pressure relief valve but will still try to vent through the line that runs to the canister unless an alternate vent method is installed.
Engine: 5.0
Re: carb identify
this is the setup i have. im asking if i can remove the tank pressure valve and just connect the lines together or do i need the valve to vent the tank properly? just trying to remove some more vacuum lines and clean things up a little more
ill get some of those inverted flare nuts thanks for the info
Re: carb identify
you'll need to keep the over pressure valve at the tank. it will allow the tank/system to develop some pressure to force fumes towards the charcoal canister, but vent higher pressures that may otherwise damage that system or the tank.
the valve is also two-way, allowing air into the tank to prevent negative pressures, which can also be bad.
while you're thinking about it, a bit of maintenance/checks on this valve may be in order. there's a thread somewhere on dismantling it and repairing. you can check that it releases pressure by running compressed air into the system at either the feed or return fuel lines. should hear it phart off the excess pressure.
Engine: 5.0
Re: carb identify
wait, is the over pressure valve the same as the tank pressure control valve? meaning the vacuum operated valve located at the charcoal canister thats connected to the fuel tank?
Re: carb identify
The tank will vent without the TPCV, but since you are keeping the charcoal canister, then why not keep it? It is just 1 extra vacuum line. With it, the fuel vapors will be sucked into the carb to be burnt.
The fuel filter in the fuel bowl vent line to keep charcoal bits from entering the engine is my idea because I read about this happening to someone else. I figure that it's a cheap and easy way to prevent this from happening. You could even use a plastic, see-thru filter.
You don't really need it because you already removed the TVS valves and CCV.
