89 350 TPI Code 43 Troubleshooting
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Currently getting a code 43 on WOT when it fails the Forced Knock test (makes your engine knock, tries to hear it, if it doesn't, error 43.) This is the type that has the ESC mounted on the drivers side firewall.
Currently getting super low voltage (.02v) @ the Knock Sensor connector. Should be 5v DC disconnected, 2.5v DC connected. (Edit: the voltage should NOT be 5v/2.5v as I state here - read down the thread further).
- Knock Sensor tests good (100k resistance)
- ESC wire to Knock Sensor good, but very low voltage (.02v) with ignition on
- ESC ground wire test good
- ESC 12v wire and voltage tests good
- ESC to ECM B7 wire tests good
I'm conflicted if the issue is the ECM or ESC module. Research and the manual are not clear if the 5v is sourced from the ECM or ESC module. Either part is $80-100 so I'd hate to throw money at the problem
Any input is appreciated!
Edit: Currently leaning towards ESC at this time, but any first hand experience would be nice.
Car: check
Engine: check
Transmission: check
Re: 89 350 TPI Code 43 Troubleshooting
RBob.
With the engine running and held at about 1000 RPM, does tapping on the block next to the sensor cause knock to be reported? If so then there isn't an issue with the ESC system. The forced knock test can fail due to incorrect distributor timing or too high of an octane fuel.
The tapping test produces no knocks counts @ the ECM.
Runs great aside from when the ECM performs the forced knock test. When it attempts to do the forced knock test, it is successful in making the car ping (golf ***** in a tin can come to mind,) but datalogging shows a big fat zero on detected knocks.
Good to know. Out of the 100 threads I read yesterday it wasn't quite clear. Assuming then it's the AC type, where it generates a small amount of AC current upon knock? Was hoping to test the KS individually before throwing another one in there and getting a coolant bath.
Edit: Going to get the test lamp back out and simply follow the book procedure to a T. I'll post the resolve either way.
Car: check
Engine: check
Transmission: check
Both the early and later knock sensors produce an AC voltage. It is basically a microphone that sends the current engine sounds to the filter.
One thing to double check is which connector/wire is going to the knock sensor. Some have posted here that the fan switch connector/wire can be attached to the knock sensor. Which of course doesn't work.
Looks like the test in box 7 will do the trick.
RBob.
RBob.
Heading out to run through the flow chart and will advise further, at least to maybe help someone out who runs across this thread in the future.
Got an old-school test light (none of this new fangled DVM business I've been using,) and ran through the tests again.
#7 -> Yes
Faulty Knock Sensor (or) KS Wiring. Verified wiring to-from the KS has no shorts to ground/etc, so Knock Sensor it is.
Oreilly carries BWD brand knock sensors. I'll grab one of those, bench test for 100k ohms, and plop it in. If it gives me problems I'll order an AC Delco OE, as I'd prefer one of those anyways.
#7 -> Yes
The BWD sensors seem ok...just remember 350's use a different sensor than 305's...different ESC modules, too...and careful not to over tighten the sensor.
Also, make sure that the knock sensor wire hasn't been accidentally swapped with the temperature sensor in the passenger side head..they have identical type connectors. IIRC, knock sensor is a white wire, that goes to terminal E on the ESC module.
Knock sensor wire is definitely correct as verified in test #7 above (as I tested from the connector itself.) I verified continuity separately. It also has worked in the past, and I haven't rewired the engine since. Good to know regardless as I'm sure lots of people searching may have done that on accident.
Installed replacement knock sensor @ 15ft/lb. After the wonderful coolant bath, it is now testing properly when tapping on the block.
I'll give it a drive-ability test after I get all this coolant off of me.
Test drive & data-logging confirms the new knock sensor fixed the issue. Hooray!
I also noticed the engine builder used thread-locker on the knock sensor threads, but everything I read says you shouldn't. Either way I did not use thread locker, and no leaks so far.
