Crossmember "rubber mount"
Old 05-21-2017, 06:17 AM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Hey all,
Im rebuilding my trans and when taking down the crossmember, the "rubber mount" had separated. What is the proper name for this, and does anyone know where to get one?
Thanx!
Ken
Old 05-21-2017, 07:43 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Crossmember "rubber mount"
Transmission mount.
Can be had at the local parts store or various aftermarket companies.
Old 05-21-2017, 09:35 AM
Jacobaxeman's Avatar
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
You should look into getting any mount other than the rubber, I broke a few within a year; I drove it hard though.
91rs 305/700r
Old 05-21-2017, 10:34 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
Many don't like the poly mounts because it transmits so much more vibration to the car. If you're not running high power levels, a stock replacement rubber one will work just fine for you.
Old 05-21-2017, 04:27 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
I agree, go with the rubber one.
Old 05-22-2017, 06:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/tran...ison-pics.html
JamesC
Old 05-29-2017, 07:54 AM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Thanks guys!
Ken
Old 05-29-2017, 06:07 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
If you keep tearing the rubber mount I would try this first.
I tried two different ES Poly Mounts before this one.
This is my #94 post in the thread JamesC offered above.
= https://www.thirdgen.org/forums/tran...ml#post5790123
The easiest way to know the rubber mount is torn is when you put the car in drive or reverse and you get a bang between the front seats.
And the only way to see the tear is to place a piece of wood on the transmission pan so the jack does not damage it and lift it a little.
You will see the tear then.
