Wheel Help
Old 05-25-2017, 10:17 PM
windsock's Avatar
Car: 86 Trans Am
Engine: Lt1
Transmission: t-56
Wheel Help
I have a 85 Trans am with 15s on it I want to change 17x9 with 245 45 front and 265 or 275 45 rear what offset and or spacer will I need for this to work? Also the car has 2" lowering spring front and rear if that makes a difference !
Old 05-26-2017, 09:15 AM
rgauder's Avatar
Car: 1987 Trans Am
Re: Wheel Help
17X9.5 with 5.5" backspace will fit 275/40/17 all the way around.
Old 05-26-2017, 08:14 PM
windsock's Avatar
Car: 86 Trans Am
Engine: Lt1
Transmission: t-56
Re: Wheel Help
Thanks thats what ineedef to know !
Old 05-27-2017, 06:39 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Re: Wheel Help
With stock front brakes, you may need a 1/4" or so spacer up front to clear. Safer to go 5.25" BS with that sized wheel.
Old 05-27-2017, 08:44 AM
rgauder's Avatar
Car: 1987 Trans Am
Re: Wheel Help
Listen to Paul. He knows best. I was just trying to pull the dimensions from memory. Memory is not what it used to be.
Old 05-27-2017, 01:26 PM
fullsize fun's Avatar
Car: 1986 pontiac bonneville
Engine: LB9 305
Transmission: MK6 T5
Re: Wheel Help
17x9.5 +6 offset
275/40/17s all around .
Old 05-27-2017, 08:05 PM
paul_huryk's Avatar
Re: Wheel Help
Enough with the tease, give us some side shots!
Originally Posted by fullsize fun
17x9.5 +6 offset
Old 05-28-2017, 12:39 AM
Engine: LB9 305
Re: Wheel Help
