Over heating on stock engine with AC on?
Car: 86 Trans Am
Engine: 305 LB9
Hey all, been reading a lot on here. My car will over heat on highway or high speeds with AC on. It's been over 100 out so that Ac struggles regardless. The motor got up past half to about 230. Not sure what is too hot for these cars. Never went past that. Pulled over and coolant was bubbling. My fan is wired always on with ignition on. Single fan. Engine also has a trans cooler. As soon as I turn AC off the car cools back down.
Stock radiator
air damn in place
car will cool when I come to a stop or in town speeds when the fan can do it's job
i added water wetter and it helped significantly but still a little past half
recently replaced wp radiator and hoses
ive also cleaned the radiator and condensor to remove dirt.
Any idea? Love my Ac but don't want to cook the engine on the highway
Stock radiator
air damn in place
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Re: Over heating on stock engine with AC on?
Does your car have the plastic air dam under the radiator?
Car: 86 Trans Am
Engine: 305 LB9
Im having this same exact issue with my ls swap setup and a/c. Im even running ls1 fans and a 160 stat. Car runs perfectly normal temp with no a/c or in trafffic with a/c. Once on the highway it creeps up to 230 and stays there. Turn off the a/c, or hit traffic and it drops. I even picked up a whole factory airdam setup, and it helped. Before the airdam the temp would continue to rise above 230.
My next step will be a larger radiator, then maybe some aftermarket fans 😕
Car: 86 Trans Am
Engine: 305 LB9
Car: check
Engine: check
Transmission: check
Check that the fan is blowing into the engine compartment. Reverse the wiring and the fan will blow air out of the front of the car. That works at low speed, but not on the highway.
RBob.
RBob.
Car: 86 Trans Am
Engine: 305 LB9
Car: 86 Trans Am
Engine: 305 LB9
Today's weather was 75-80 and cool. Car didn't run hot at all. Didn't even get to half and Ac worked perfectly. Going to just assume it won't be a good summer highway car until I switch to a better radiator
