Issue starting up
Old 06-27-2017, 06:49 PM
LGS_18's Avatar
Car: 1992 Firebird
Engine: 3.1 6 cylinder
Transmission: 700R4 automatic 4 speed
Issue starting up
Hey! I have a 6 cyl 92 bird. The car has been running great for the last 3 years iv had it but recently it has trouble starting up. It only has trouble starting when its a cold start, but if the car has been running for a while and i start it back up, its fine. I replaced the distributor but that didnt help. Anyone have any suggestions what might be causing this? Thanks!!
Old 06-27-2017, 10:41 PM
brettr81's Avatar
Car: 91 Firebird
Re: Issue starting up
What exactly is it doing, not doing when attempting to start? Is there a click, no click, tries to turn over but won't start?
Old 06-28-2017, 04:35 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
sounds like its a long cranking time. i have the same issue. first time starting up takes some tries. even priming it. can shutit off and start it up back fine. ill check my manual but i am sure it has to do with some sensors.
Old 06-28-2017, 06:00 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Could be the fuel system not holding pressure, has to build back up every time it sits for a while. Get a fuel pressure gauge and put it on the valve on the fuel rail. Run it, shut it off and see how much the pressure drops over a half hour, hour, 2 hours, etc. Shouldn't really drop much. If it does, you may have leaking injectors.
Old 06-28-2017, 07:09 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
Here's the page.
Old 06-28-2017, 07:13 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
Other ones.
Attached Thumbnails Issue starting up-imag0188.jpg   Issue starting up-imag0189.jpg   Issue starting up-imag0190.jpg   Issue starting up-imag0191.jpg
Old 06-28-2017, 10:34 AM
LGS_18's Avatar
Car: 1992 Firebird
Yeah it just cranks for a while and then surges hard like its got a big cam in it. I think i may need to go through my sensors and then the fuel system
Old 06-28-2017, 10:36 AM
LGS_18's Avatar
Car: 1992 Firebird
By the way. Fuel pump pressure is 38
Old 06-30-2017, 05:53 AM
drdave88's Avatar
Engine: 6.0L
When does it read 38 psi? Running, after running, after sitting for a while? Not sure what sensor is going to make the engine crank for a while when cold. Maybe a coolant temp sensor if it's always reading high, so you're not getting the cold start injector when you need it. Do you have access to a scan tool to read coolant temp?
Old 06-30-2017, 06:06 AM
LGS_18's Avatar
Car: 1992 Firebird
A shop did the test for me. But im working on the car next week and will check the scan tool and do more testing. I will keep posted on my findings.
Old 07-04-2017, 02:45 AM
maroe624's Avatar
Car: 92 Z28
Engine: Ramjet 350
Axle/Gears: 3.23 Torsen
I had a similar problem. Sounds like its your fuel pressure regulator. Hard starts when cold and sounds like it has a cam is due to fuel leaking into the cylinders. When hot it will start back up no problem because there is no fuel in cylinders. To check if its your fpr. Pull the vaccumm hose coming off the fpr and if that leaks gas then yes its your fpr. I'm willing to bet its that.
Old 07-15-2017, 12:50 PM
H8TRAFIC's Avatar
So Im having the same problem as OP. At idle my fuel pressure is 42psi. As soon as I shut the car off the pressure drops to 15- fast. The pressure when the key is turned to "run" is 15. My fuel pressure regulator is not leaking and my fuel pump primes as it should when I turn the key on. Leaky injectors?
Old 07-15-2017, 01:00 PM
H8TRAFIC's Avatar
I did forget to mention the fuel filter is new. After relieving the pressure I ended up with the SES light on. Code 54 which is fuel pump related. I dont know what to make of this.
Old 07-15-2017, 03:50 PM
maroe624's Avatar
Car: 92 Z28
Engine: Ramjet 350
If its throwing you a fp code, I would switch out the pump. Not exactly sure what makes u throw a fp code but Maybe the pump is just bad . Switch it out. Easy job if u have a trap door haha if not your gonna have to drop the tank or make a trap door.
Old 07-15-2017, 05:16 PM
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Are you having trouble with cold starts too? Leaking injectors seem to be spreading around the V6 cars on the forums lately
Old 07-15-2017, 06:12 PM
H8TRAFIC's Avatar
Yes my problem is only on cold starts. I hate to take a chance on a fuel pump because its such an involved job vs. injectors. Theres no way Im cutting in a trap door.
Old 07-15-2017, 11:24 PM
LiveIt!'s Avatar
You can troubleshoot the fp real easy, you can supply +12v to the G terminal on the ALDL, or jumper 2 posts (forget which) on the connector for the fp relay. You can find a diagram easy, you just need to jumper the ports so +12v goes to the pump
if if the issue is only on cold starts I'd place my bets on the injectors, they're a lot easier to pull out and check than the fuel pump :P
you might get lucky and just have some trash causing some injectors to stick open.
Old 07-16-2017, 11:44 AM
H8TRAFIC's Avatar
After a little more research the check ball in the fuel pump could be failing causing the pressure to drop so quickly. So now I'm thinking of that being the cause. I cant imagine the injectors would leak down that fast.
