Raising the front suspension??
I was curious if anyone has tried some rubber spacers between the lowering springs to raise the front up even a 1/2" to 1 inch is all I need. Really don't want to buy a different set.
Thanks guys
Thanks guys
Re: Raising the front suspension??
Pad or spacer ?
https://m.ebay.com/itm/Rubber-Coil-S...-/231879393538
Car: 91 Firebird
Engine: 6.0
I've used a set of factory rear spring spacers to raise the front of 3rd gen before. The springs were cut stoopid short and I had the spacers sitting there. Seemed to ride/drive ok....
Pad or spacer ?
Also, as far as spacers go, they do make other types beside the ones you posted. http://www.speedwaymotors.com/Longac...xoCjnAQAvD_BwE
But they do change the spring rate.
