Battery Fuse Location
Old 09-20-2017, 04:45 PM
poketad's Avatar
Car: 89 Iroc Z
Hey everyone, wondering where the main fuse is in my 1989 Camaro Iroc-Z 5.7L. Pretty sure it blew. No power to the car but my battery is reading 13v. Thanks in advanced
Old 09-20-2017, 06:56 PM
G.Penrod's Avatar
Car: 86 Iroc Z-28
Engine: 5.0 TPI
Transmission: Automatic
Re: Battery Fuse Location
Fuses are underneath by your left knee area.
Old 09-20-2017, 08:57 PM
OrangeBird's Avatar
Car: 1989 Firebird
There is no single "main fuse" that will kill every electrical device in the car . there are a few "fusable links" that control subgroups of components like the headlights , engine controls , and so on .
If nothing whatsoever has power then you have a bad connection at either battery terminal or at the starter (positive) or block/body ground . That or a bad (corroded clean through) battery wire would be my best guesses as to things that would kill all power in all circuits while the battery still shows voltage .
Old 09-20-2017, 10:06 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Fusible links near the starter motor are a point of failure.
