baffled camaro guy
Old 09-26-2017, 07:20 PM
rongi3's Avatar
baffled camaro guy
i have a 1982 Chevy camaro 4 cylinder 2.5 l Chevy engine. The tbi fuel injector is pouring fuel into the tbi the car is literally being flooded. What I've done checked the grounds, new plugs and wires, changed the ignition coil,tps,map sensor,complete new distributor, fuel filters,checked the injector wire with a noid light. map sensor vacuum. the only thing left is a fuel pressure relay that i'm going to change now. if i'm missing something let me know .the problem started a year ago I was driving the car and noticed every time it got hot it wouldn't start. i thought it was the ignition coil I changed it and all of the above is what i've changed since help
Old 09-26-2017, 09:19 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: baffled camaro guy
The fuel pressure regulator and the fuel pump relay are two different things.
This sounds like the fuel pressure regulator.
Old 09-26-2017, 09:28 PM
W.E.G.'s Avatar
Engine: V6 2.8
Check out part 17 FPR diaphragm
Old 09-26-2017, 10:56 PM
rongi3's Avatar
is there a way to adjust the regulator or does the part need to be pelaced
Old 09-27-2017, 01:16 PM
W.E.G.'s Avatar
Engine: V6 2.8
No.
You have to disassemble it, and replace the rubber diaphragm to service the regulator.
Adjustable regulators are available as aftermarket upgrades, but you still have to disassemble them if the innards gone bad.
Old 11-23-2017, 11:26 AM
rongi3's Avatar
still baffled I have to spray gas into the tbi to get the car to start. Once it is started and warm it will start on it's own . any suggestions?
Old 11-23-2017, 12:09 PM
W.E.G.'s Avatar
Engine: V6 2.8
What did you do about part 17?
Old 11-23-2017, 12:37 PM
rongi3's Avatar
I'm going to purchase a rebuild kit on Friday November 24
Old 11-23-2017, 12:59 PM
W.E.G.'s Avatar
Engine: V6 2.8
That impresses me as a sound approach.
You have a fuel-delivery issue.
Step 1: Make sure the device primarily-responsible for fuel delivery is in proper working order.
These jobs can be time-consuming and rewarding.
I look forward to reports of your success!
Old 11-23-2017, 02:02 PM
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Yea keep us posted! We need more 4-cyl Camaro action on these boards!
