My 406 with long tubes and ground clearance.
Old 10-23-2017, 11:26 PM
Dscott's Avatar
Car: 89 Iroc street car
Engine: Fitech vortec 400sbc/T5
Transmission: Also 69 Chevelle, Nascar chassis
Axle/Gears: 700hp roadrace track day car
My 406 with Ebay long tubes and ground clearance.
I have a 406 with ported vortec heads and a XR270 full roller cam. We felt we needed more than shorties with 1 5/8 primarys for this engine. So after talking with a Dutch guy on here I ordered a set of these stainless OBX Chinese headers off Ebay with 1 3/4 primarys. They go by a bunch of different names like OBX these were "DNA"s for $267. With a little bit of notching on the K member and new stock motor mounts they give great ground clearance
https://www.ebay.com/itm/39113146941...%3AMEBIDX%3AIT
Old 10-23-2017, 11:33 PM
Dscott's Avatar
Re: My 406 with long tubes and ground clearance.
I run a WC T5 for now. For collector clearance my guy cut off the ear on the bell housing and installed this Howe hyd throw out bearing
Old 10-23-2017, 11:37 PM
Dscott's Avatar
He then fabbed a custom cross member.
Old 10-23-2017, 11:42 PM
Dscott's Avatar
He cut the 2.5" collectors off. Those are dual 3" Magnaflow cats and the start of the 3" Y pipe.
Old 10-23-2017, 11:50 PM
Dscott's Avatar
There is the rest of the system. The 3" Y with dual 3" Magnaflow cats then 3.5" all the way to the muffler which is a Spintech 3.5" in with dual 3" out and 4" tips. Yes I know you can make more power with a straight through muffler but I wanted dual tips
Old 10-23-2017, 11:54 PM
Dscott's Avatar
This is the lowest part of the system, back by the rearend. That cup is 4.5" high. The car has original (somewhat sacked?) stock springs.
Old 10-23-2017, 11:57 PM
Dscott's Avatar
Heres a pic on the car.
Old 10-24-2017, 12:02 AM
Dscott's Avatar
Here's a Youtube vid. Many thanks to Vic at Schmitt tuning north of Toronto for his hard work and vision. The Fitech has had no time to self tune. That is def water coming out of the pipes.
Old 10-30-2017, 09:46 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Sounds angry, what is shooting out those tail pipes
Old 10-31-2017, 07:27 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Looks and sounds good. I have the same headers waiting to go in myself. I am running a TH350 trans, so hopefully the install will be a bit easier over the T5.
Old 03-04-2019, 09:24 PM
Dscott's Avatar
ttt
Old 03-07-2019, 11:36 AM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
This is good to know as I've been thinking about these same headers
DSCOTT that looks good enough rear clearance as long as you stop picking up all those fat chicks
really though thanks for the pics ground clearance was/is a big peeve of mine
Old 02-27-2020, 08:54 AM
Dscott's Avatar
TTT
Old 02-27-2020, 11:19 AM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
TTT
why do you keep doing "TTT" ?
Old 02-27-2020, 01:16 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
although this is not all there is to it, the ground clearance is pretty impressive, especially for a 1.75" long tube.... any rattles or thumping?
Old 07-28-2020, 12:13 AM
Dscott's Avatar
there was some thumping but I tracked it down to the right side tailpipe after the muffler
Old 07-28-2020, 06:59 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Are you still running the FITech unit? if so, how do you like it?
