Factory belt tensioner
Does anyone known the factory part number for a 88 Iroc tpi car? Are they still available? The aftermarket ones look very different and I want a GM original.
Re: Factory belt tensioner
Rock Auto, it's the ACDelco that says original equipment. Double check the photo shows the pulley with guide lips for the belt. Most of the modern ones use a smooth pulley.
Alternatively, if it's just a crunchy bearing, the stock pulley uses a VERY common bearing. IIRC it's the same as a front bearing for a 10SI GM alternator, or something like that. Parts stores have the bearings in stock for under $10.
