91 L98 just cranks sometimes starts
Old 11-24-2017, 09:01 PM
jorgeblancojr's Avatar
So the car has not ran for a while. Anyway, it's mainly just cranking it barely starts. At first it would start for a few minutes, but then die. Then, it would just crank. Sometimes it'll start and die right away. As of right now it's just cranking. It'll start with starting fluid, but die right away. I've replaced the fuel pump, fuel filter, spark plugs, and battery. I pulled out the fuel pressure regulator and there was no signs of tears or anything unusual. What could it be? I've never driven this car and really want to. Thanks
Old 11-24-2017, 11:07 PM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Re: 91 L98 just cranks sometimes starts
I know you replaced the fuel pump and filter, but have you verified the engine is actually getting fuel? If it'll only turn over with starting fluid, I would think that its not. Check the fuel pressure at the rail and see if it has any. With the key on can you hear the fuel pump priming?
Old 11-25-2017, 06:39 AM
I haven't had a chance to get my hands on a fuel pressure gauge, but I will today. Yes, I can hear it prime.
Big&BadGTA's Avatar
Location: *member since 1999, I think - just can't remember my old name, and the big site crash...*
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Have you tested the resistance in each fuel injector?
Old 11-25-2017, 06:40 AM
How can I do that? I have a multimeter if that's what I need?
Old 11-25-2017, 06:50 AM
Big&BadGTA's Avatar
Yes. Check each injector. Unclip the harness.
Should read 16 ohms at each injector.
Post your results in 15 min when done. Thank
Old 11-25-2017, 06:57 AM
With key turned or just off?
Big&BadGTA's Avatar
Key off
You are reading resistance across each injector pin and pin.,,
Old 11-25-2017, 07:06 AM
So I'm not any good with this stuff, but I have my multimeter on 20K ohms? There's 2000K, 200K, 20K, and 2000, and 200. Which one is it supposed to be on? It's on the ohm area. Also I'm touching one terminal of the injector with the black lead and the red on the other one if that's how you do it?
Old 11-25-2017, 07:15 AM
Big&BadGTA's Avatar
Old 11-25-2017, 07:36 AM
Driver side
18.0
06.6
03.5
10.5
Passenger side
18.0
10.5
18.0
18.0
Old 11-25-2017, 07:50 AM
Big&BadGTA's Avatar
2 of 8 are absolutely toast. 2 more are bad, and 4 are fine
Replace all eight (8)
I've used these on mine:
https://fuelinjectorconnection.com/c...l-injector-set
20% off sale, too.
Old 11-25-2017, 07:52 AM
20% off sale, too.
Thanks for your help. Wish I could afford those might have to go with rebuilds
Old 11-25-2017, 09:16 AM
mike_c's Avatar
I've had 2 sets of rebuilt Bosch IIIs in mine from FIC. I'm very pleased with them. I had stock size and then put in 32lbs when I redid the engine.
Old 11-26-2017, 01:58 PM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
Good info BigBad, thanks for sharing.
Old 11-26-2017, 03:07 PM
Big&BadGTA's Avatar
You are welcome!! I'm here to help!!
